Everything posted by travs
2012 to 2019 Superb Refresh
I’m sure everyone can take a mo to calm down. It’s easy to read things in the wrong tone. Plenty of knowledge to be shared which makes the forum greater. Cairus has a wealth of knowledge particular to these models. You clearly have lots of knowledge too but seems more general. Both have their place but I’m sure nothing was intended to be a p***ing contest 👍🏼
- Bixenon Headlights auto-adjustment problem
So the crash repair is the most likely issue. Might be a long coding issue which tends to tell the car which items are installed. If the car doesn’t think it has self-levelling headlights it might not be listening to any level sensor if that makes sense. What’s the make model and year? And do you have DCC?
Ah yes you did say that. How did the sump crack?!
Have a link to the higher mileage one?
MIB3 is fine on the later firmwares which can be sorted on here. Colour is bright, and possibly not metallic either. Slightly too dark for Nogaro I think but close. Could always consider a wrap instead of paint correction? Go for a colour you like and will solve all problems. By the looks of the power that’s a DNUA engine - EA888.3 with the GPF so a 272 rather than 280. Looks clean on the inside and the mileage is very low. I wouldn’t write it off completely.
Is DCC important?
Definitely much cheaper without it!
Is DCC important?
I like it - it gives the car a completely different feel. They didn't the settings quite right being far too soft naturally, which the DCC Slider Mod resolves, but it really adds to the character of the different profiles. Comfort really soaks up rough road, while Sport makes it much firmer and it responds really well. But if a great car came up and it didn't have it, it wouldn't be a gamechanger. Its nice to have variety but we ultimately tend to hone to what we like and leave it at that. Try with and without and see what you think.
Not something you could have sorted? Was it all over? How was it bad?
RogueWagon - 2018 MK3 Sportline Estate
My 2p: Plates: Get motorsport plateholders? They usually come with a million different positions; not sure if you can get ones for shorter plates though; unless you mean without the welsh badge, in which I'm sure you can. I had some nice ABT ones on an old Audi I had and might consider getting some of those again. If you're looking at wheels, look for a reduced offset instead of spacers - saves cost of getting longer bolts and faffing. I'd also not bother so much with 245 tyres although appreciate you're looking at 8.5" wide. They were a thing on the standard 19s due to lower price for a greater footprint, but tbh I never found any real impact and prices have changed now so that 235s aren't any more expensive. Early call: I'll be surprised if you stop there...
Superb Mk3 Estate 190PS TDI DSG MY2015 SE L Executive - Moon White
So is this a pre-FL thing where the interior light is a torch? Mine is just a fixed light although its a cool white rather than yellow. Only downside is because it sits on one side only as soon as you put a big bag on that side you can't see anything else in the boot in the dark. Would be good to replace it with a couple of short strips under the parcel-shelf supports (hatchback only I appreciate)
Gandalf's Evolution
#engineswap Yeah Gandalf's a bit of a beast but done with lots of attention to detail.
19” vega alloys advice
Love that - something different is always good.
- R600 Plus Pikey mod Skoda-specific?
The fronts are 19”, the rears are 20” so a set of 4 fronts fits perfect. I think Gallardo wheels fit too but I’m not convinced they fit stylistically. I tried to buy a set of non-badged centre caps (happy not to have emblems) but after 2 sets (albeit Ali Express) neither of them fit so I gave up.
That’s the one @Binx1310 Ditto @RogueWagon . This is a great colour as is the Royal Green on the official Sleeper version. And the 5-cyl has a very similar resonant note to a V10. Very envious.
The Motec's I saw were used on the Superb 2.5 on instagram (green/gold estate with the 2.5 RS3 5 cylinder). Looked lush. I have a feeling they may need a spigot ring to get the right the centre bore. That was the beaty of the McLaren's I have - correct CB, correct PCD, slightly lower offset to give a tad more poke. Half the weight. Look up App Tech.
Skoda retail prices are incredibly effective at financially justifying aftermarket parts.
In which case, just as easy (and you’ll save on labour cost to buy new wishbones/control arms seeing as they almost all come with the new bushes and ball joints in.
Yep that's a decent go of it. The opening of the hole is the main thing. The mygolfmk7 guy did some testing on the ducting and found negligible difference but he was marking that against the claims of lower intake temps and % increases in power/torque. Either way, it looks like you're on the right track making sure the air moves up and into the airbox which is the best you can do. You're right about the grill too - I was wondering about whether a neat job can be done with a dremel on opening up the gaps a little more to allow for flow while keeping it standard but the honeycomb grill looks good and plenty open too. So is it right you've got the r600 and intercooler done but no remap yet? You'll enjoy that when its done then!
Most upset, my V3 L&K written off after a cretin drove into me.
@Tankdave Too I believe…
Did they say which bushes?
2 things to bear in mind: They weigh a ton Whilst they do look natural, they sit beautifully proud of tyres inviting the most exquisite of lovetaps with any and every kerb. My advice, get something that is a little lighter and also that sits flat or dishes in slightly. Also not a fan of diamond-cut given its propensity to give up the ghost so easily.
