Everything posted by MikeTheThinker
Headlight range issue Octavia MK2 2.0TDi Laurin & Klement
Value of 2011 VRS TDi
Just FYI Parkers said this: Private Price £2,445 - £3,525 Dealer Price £4,050 - £5,005 https://www.parkers.co.uk/skoda/octavia/vrs-2005/20-tdi-cr-vrs-hatchback-5d/96/free-valuation/
Can you identify what model of car this is please?
Blame Google [tm] Lens[tm] if it ID'd the wrong car. It was an attempt at a humorous response but may have missed the mark 😞
Mitsubishi Colt 1995-2003? Rare left hand drive sub-aqua model being tested for refloating on the UK market.
Bi-Xenon Headlamp Beam Height.
Excellent link; many thanks!
Inner tyre wear Dangerous Anyone Else?
Is it possible the picture is showing the tyre tread becoming separated, just as retreads have been known to do?
'Garage fined by DVSA for installing illegal aftermarket car parts'.
https://www.am-online.com/news/aftersales/2023/11/28/garage-fined-by-dvsa-for-fitting-illegal-aftermarket-parts Also another related article on Evo about noise-detecting roadside cameras: https://www.evo.co.uk/news/22762/government-noise-cameras-aim-to-fine-drivers-with-loud-exhausts
Droning noise from front of car
If your wheels are out of balance you will feel some vibration via the steering wheel. The degree and type of vibration will vary depending on road speed, road surface, how warm your tyres are etc. You should be able to isolate the conditions where vibration is sensed and it should be repeatable (i.e. similar road surfaces, road speed, weather conditions etc.) Whilst such checks are not definitive they can help identify repeatable conditions so you can describe the problem to an appropriate engineer.
Fabia MkII headlight types
Thanks for that. I've ordered some and we'll see how they compare.
Do you have details of the one that worked and any ideas why the one that didn't, didn't?
Headlight electrical issues - in need of high voltage cable
The parts catalogue entry for an Octy 2 (2007) HID headlamp is HERE but it only shows one loom in the headlamp?
14 spoke wheels
Can't help you much with those, I'm afraid. There are loads of cheapo lightweight wheel trims on fleabay and amazon plus aliexpress and others if you don't mind waiting on delivery. One note for the lightweight plastic trims, however, be careful how you fit them as they can crack very easily (DAMHIK).
14 spoke wheels
Again a piccy would help. Are they alloys or steelies?
14 spoke wheels
Alloy wheel CEPEUS 17" pro OCTAVIA II Rim dimension: 7,0J x 17“ ET 54 Product code 1Z0071496 Color Silver Material Light alloy Rim dimension 7,0J x 17“ ET 54 Number of bolts 5 piece Tyres dimension 225/45 R17 Snow chains possibility No Weight 12 kg
The end of the road...
Hopefully (at least partly) at the cost of said Tesla driver?
Are you getting any vibration through the steering wheel?
I need new cable! whats it called or oem nr?
The engine wiring catalogue entry for a 2010 Octavia with CEGA motor is HERE. I don't know what prices are like where you are but it might be worth looking to a breaker for a used part.
So you're looking for an injector wiring harness? What engine code?
Water in the front Near Side Head light
There are plenty of good used headlamp units on fleabay, prices from around 30 squid upwards. Is it worth trying to track and fix your mystery leak?
Do Skoda Fabia mk2 can Sharing part with other car
The parts catalogue page for the rear suspension for a 2014 Fabia mk2 built in China is HERE and should go straight to the rear shock mount details. Note that without full details of your car it is not possible to guarantee that this is the correct part but as it is the only option listed it is probably correct.
14 spoke wheels
A piccy of your wheels would help with identifying them ...
Buying Advice ... vehicle / owners
Four registered keepers in 12 months is high but as @Rooted points out there may be situations where this is explainable. Were it me I'd be wanting to see the detail of the service history - ideally including service bills - and would try to follow up via the servicing dealer to learn more. Might also be worth paying the fee (10 squid) for a full car report as you can see more of the keepership history. Of interest in the free version of the report is the note that the current keeper has had the vehicle for 1yr 3months, so where do the other three come into it? https://www.caranalytics.co.uk/select-product/RJ22FHW
Both sidelights inop
Can you check the continuity from the bulb holder to earth? I'm not certain but think they may share a common earth connection.
Breakdown of frequency and types of service
I'm finding that as I age my memory isn't as reliable as it used to be so I want to build a spread sheet for service history for our cars - Octy 2 and Fabia 2. I can transcribe from the images you've posted but was hoping to make short cuts by downloading and editing content.
Do you have a link to the original content, please?
