Everything posted by MikeTheThinker
Stolen grey mk2 Octavia estate FN07 WCF Preston area
Help identifying/naming a tube
It looks like an air intake duct from the filter box, and depending on your engine it should be shown on HERE or HERE.
Octavia estate for sale, very poor condition, MoT until October, please read.
As you may see elsewhere our daughter's car has just been nicked and is unlikely to be seen again, so I'm definitely interested in yours. I'll PM my mobile number. Regards, Mike
Some scrote(s) nicked our daughter's Octy estate last night from the Brookfield area of Preston, Lancashire. Car is a 2007 Octavia mk2 Estate in dark grey/silver with roof bars and a towbar. Baby seat and odds and ends inside. FN07 WCF if anyone around notices it; please let me or the Plod know. Cheers, Mike PS Piccy added a few posts down.
Can you replace only the flexi exhaust section?
I don't know what your engine code is but if you take a look HERE you can see all the exhaust options for an '07 Octy 2.
Automated gates
As risk of possibly mentioning the obvious but are you the trip in question is sound? It is not unknown for trips to false-trigger.
Oil going from air intake to engine
It looks like the problem is part number 038 103 493 P VAG Hose, cylinder head cover breather. Initially I'd give it a good clean and then check on a regular basis to confirm where the oil is misting from. You may also be able to smell the sour engine oil smell in the cabin. Parts diagram details HERE. BTW your forum details are showing as a 2006 mk2 Octavia, not a mk1. Is this correct?
Rattle on startup - likely to be camchain stretch and worn tensioner (1.8TSi)
I've not listened specifically to a worn Octy cam chain but in my general experience worn cam chains 'rustle' rather than rattle. Your random tapping noise could be tappet-related instead. There are a number of threads on here regarding worn cam chains so a forum search would be of interest.
Saying hello!
Hi Gary Whereabouts on The Wirral are you? We're over in Heswall for the time being while I work on my folks' house for (eventual) sale. Regards, Mike
Estate boot switch fault..?
I had this problem on our 1.9tdi estate (2007) as it had stood for some time before we got it. In our case, repeated use of the 'unlock' seemed to free off the works and we've not had a problem since. You could try removing the lower plastic trim from inside the door and dosing the lock works with a ptfe spray.
New key case and board ??
If you change the immobiliser and also (I believe) the board you would have to recode the key to the car. I've never had to do that but there should be plenty of 'howtos' on the Tube.
Are you sure you need the 'innards replacing? You can find replacement shells online and just transplant your old innards and key into the new case.
anyone had trouble with message " KEY NOT FOUND" when you have the key in the car with you ???
As a suggestion have you checked that the battery in the key is good?
Gearbox manual issue on skoda vrs mk2 z5 facelift. ccza engine
Have a look at the options sticker either in your service book or under the carpet in the boot. That will tell you the engine type, gearbox, paint code and all the other options on the car. In the above case the car is a 1.9tdi ambiente with a JCR gearbox, 9154 paint and a BXE engine.
Mk2 rear sub frame
Search on fleabay for "octavia mk2 rear subframe". There are at least 2 listed at the moment. A new one from the likes of Autodoc is around 150squid plus carriage.
Mk2 rear sub frame
As far as I can see (see links below) all the mk2 rear subframes are the same but they are different to the mk3. 2007 mk2 rear support frame parts diagram 2013 mk3 rear support frame parts diagram
Gearbox Oil
Did a quick Google[tm] on "GQQ gearbox oil" and the links below came up with some commentary about oils, viscosity and how to ensure the box has been fully drained: https://www.vwaudiforum.co.uk/forum/showthread.php/197081-1-9-tdi-GQQ-gearbox-crunch-in-2nd-gear https://forums.tdiclub.com/index.php?threads/changing-manual-transmission-oil.379338/
Gearbox Oil
Don't have the relevent Skoda manual for your car but Mr. Haynes quotes 1.9l for a 5-speed manual box.
Tow bar
It could have been fitted AFAIK to you model/year but you would have to check the option codes on the sticker in your service book or under the lining in your boot. Without the Skoda magic yes, all connections can be made in the boot.
Tow bar
I bought both of mine from ebay, shipped from Poland. Fitting was straightforward but fiddly; it takes a bit of ferreting to locate all the bumper mounting bolts. I went for a euro-13 socket but it's a lot cheaper just going for the UK 7-pin version. Electrics should come as a magic box and wiring, just follow the instructions. BTW if you want to add the Skoda "towing magic" options (assuming they're available on your model) you'll have to fork out for Mr Skoda's expen$ive electrics. Footnote: make sure you order the correct tow hitch - especially if you have parking assist on your vehicle.
Advice please; small-medium sized hatchback for my sister near Blairgowrie in Scotland
My sister has had a small windfall and is looking for a small to medium hatchback car for local running about. She lives in the hills north of Blairgowrie so poor weather performance is relevant. She has been looking at Audi A3 / Golf / Fabia models and has found the one below; a bit over her preferred budget of £2k but it looks clean enough. https://www.autotrader.co.uk/car-details/202206277208445?radius=100&include-delivery-option=on&advertising-location=at_cars&sort=relevance&price-to=3500&year-to=2022&onesearchad=New&onesearchad=Nearly New&onesearchad=Used&postcode=ph107jp&annual-tax-cars=TO_30&page=9&percentVehiclePriceDeposit=true Any advice out there, please? (BTW @AnnoyingPentium, @Breezy_Pete, @roottootplus any others welcome to leap in
Drivetrain Noise... Your Opinion.
Is it possible that the noise is still coming from the front hub area but disappears when coasting as it's no longer under load?
Octy 2 noise pulling away
My money's on a cv joint ...
Buying a replacement front bumper for Octavia Estate II A5
How extensive, and particularly, how far back is the damage? I replaced a front wing and headlamp plus bracketry on our 1.9tdi and had some fun with the small brackets that connect three ways at the back of the headlamp mount. They connect together the inner wing (welded onto the chassis), the back of the headlamp platform and the inside of the wing. Great fun working out whereabouts in 3D space everything should go and applying some kinetic and torsion persuasion to the piece of the inner wing that had been pushed out of alignment,
If you're hunting for e new bumper you need the version described as "bumper cover for vehicles with parking aid", part number 1Z0807221B, catalog entry HERE. From my own experience of playing bumpers I don't believe you should have any problems starting with a plain bumper and drilling the holes for the parking sensors; the difficulties arise when you're working with a bumper that has headlamp washers fitted. Given that you will have to respray a replacement bumper blade if you buy new, I'd go hunt the scrappies for one in either your colour or close enough that a rattlecan respray should work OK. If you're going to do the replacement yourself remember you will need the plastic rivets as they're not reuseable. BTW have you checked for damage to the bumper mounts also? The two plastic top supports that run between bumpwe and wing can be a bit fragile. Part #7 in the diagram.
