Everything posted by Frenchtone
Yeti eating H7 bulbs by the bucket load
are they all kaputt? try testing on the battery!
Sat nav seems to think I am in Germany
Have you tried rebooting it, I think fuse 8 in the box under the bonnet needs taking out for 5 mins , reinstall and try again ---- check the fuse number though as i'm not certain!!
- Wonky C/Control
Mont Blanc to Calais
^ ^ ^ ^ yeah but it is downhill from the alps to calais :-()
Door strips
depends how much you use!!! ;-)) Also, I used gutter sealant in the track to try to ensure the wheel arch trim did not come loose, I also removed the other side and gave the same treatment, that was about 2 yrs ago still rock solid!!
Tinny sounding tweeters
Ah ok, I only have an Amundsen + installed --- thanks for your info, it will maybe help others! Ta!
So how did you code in the surround etc? I realise by VCDS, are there any posts with an idiots guide?
Maxidot "internal Lights setting
Wasn't it only available with xenons as standard? My SE was a pre FL without, and the current Adventure was a 'runout' with some extra goodies, but not that!
Ambition was equivalent to SE here a la frog!
Airbag light.
Or find someone nearby who will probably sort you out for beer vouchers!! ;-))
Boot strut failure (Fabia Mk3)
I think I got a price reduction as my car was the guinea pig for the struts!
There is a supplier in Derbyshire who make replacements, maybe someone on here will have a name or link, they made 2 a long time ago for my Yeti - the first they had done, they worked well. From memory cheaper than the Skoda ones! Found 'em --- SGS Engineering, google 'em
Battery replacement 2010 Yeti
How about sorting all this out behind the bike shed at playtime?
Problems with updating sat nav on 2013 Yeti
^ any links?
Glow plug warning light flashing
I think there is an O2 sensor on the top and behind somehting on the left of the engine, that causes the glowplug lamp to light when it fails whats the mileage? I was informed anything over 80k and it can happen!
mine has V9 apparently later versions worked fine in europe ie ver 10 but were unreliable in the uk sphere, it kept rebooting - i never pursued later versions so wouldn't know the situation with 11 / 12!
^ you need an sd card, look on ebay, they are about £30, and do it yourself, do an amundsen+ update search on here!
That is an Amundsen+. There are sd cards available on ebay, from poland or the like, they are around £30, I have used one earlier in the year without problem, cannot remember if it was a copy of the latest software as problems have been reported of regular rebooting, Rustynuts will probably be able to assist with that info! -- good luck!
Amundsen sat nav settings.
Hay-on-wye --- have you tried it with dashes as per left <-
^ not around me!
When my car carried UK plates I regularly got waved through roadside inspections etc, but now with french plates it's a different story! Alcotests are also carried out in the morning rush hours as well! regular occurence by/near me! Also traffic infringements here in Finistere are normally stopped by young gendarmes, gaining street cred i suppose!
^ But when using in France do you use proper names, ie with accents etc
How to properly wash our beauties
^2 just salt!! ;-))
New used Yeti owner, haldex spin on launch?
can you find a local sandy surface to test the haldex operation, starting from stopped, just floor it and quickly stop say in 4 - 5 feet, look at the displaced sand, should be across all wheels! I use a local beach!
No 3 could be a regen in process so this would be sort of normal, Is there a general hot smell around the car?
