MarkyG82
Everything posted by MarkyG82
  1. Normal behaviour.
  2. Can you share where it says 50k? Certainly seems too soon and not one I've heard before.
  3. One further feature on columbus I think is the ability to connect 2 bluetooth devices at the same time. Good if you have a work phone alongside your personal one. This may be limited to specific columbus variants.
  4. Calling @pab567to the thread. Another willing customer for you. @Umrelllaskithis guy is the guru.
  5. That's like blaming a non stock tyre. A joke if you ask me. I had to get a new cable soon after getting my car and never had an issue. Type 2 is a standard and, assuming it's genuinely certified, should work as designed.
  6. Did you do the obligatory willtheyfit.com measurement? If the wheels are narrower than the superb fitment they might work.
  7. Someone may correct me but electronic suspension is DCC. Maybe the garage you went to has never fitted aftermarket shocks to a DCC setup?
  8. Decision to stick to 1.4 for the PHEV platform was also tooling. Internal parts are different to the regular 1.4 so they have stuck to that specific engine to save making the same changes to other capacities.
  9. Can you use the ones from the Octavia? I went the other way as my stock size was 18. I fitted cross climates (to be swapped for full winters) to those when I first got the car. Then got a set of 19 Audi les mans for summer. Just make sure the 17s fit over the brakes.
  10. Just to confirm the above, DSG boxes are on mileage service regime and not time. So yours is 80k miles. The table in your link is 8 yrs or 80k (or the 4 yrs/40k as as you read which is for the other box type). It's not fair to expect the general public to understand which figure to choose.
  11. When my SAs die I'll be swapping out for B6 so maybe I'll be the first on this platform to try both. The issue I have with SAs is the inconsistency. They feel good when cruising. But then when below 50mph they might feel great and supportive or they go soft and wallowy. There's no telling which way they go. The firmer B6 is far more reliable in use. Not had any mechanical issues yet and that's with lowering springs and a stiffer rear bar.
  12. Just double checking: post above says 1.6. clip says 2.0. Either way sounds ok to me.
  13. This I'm not sure and haven't found a conclusive answer. It would make sense from a technical use case. But, some other decisions by VW (etc) have made this platform odd compared to others. Some of which make it a nicer car to drive. Gearbox for one.
  14. The stock 18 size is 225/40/18. Much lower profile than the 205/55/16. Hence why people are saying that they are a harder ride. That size you are looking at is way out of the realms of usable on the Octavia. Won't fit the wheel wells and the drivetrain will struggle.
  15. @tootI put 18s on my Octavia that had torsion beam rear end like the 1.5. Granted it was lowered and with B6 shocks but it wasn't that bad.
  16. Like those. Looks great.
  17. It's a personal thing. If you are not used to the car and you are new to driving (first car etc) then maybe stick to the 16s. They will be more forgiving and better on fuel. Toots idea to change the wheels at a more convenient time might be good too. For what it's worth tyre reviews in YouTube did a test with the golf with different wheel sizes and found the 17s to be the best compromise for comfort and performance.
  18. To answer the main question yes it does charge the battery. Pretty sure the car needs to be on as that closes the contacts to the 400v battery so will only charge when driving. Also to be clear, the battery you are referring to is 12v like all other car batteries. Not sure where you got 9v from.
  19. I knew it had a better name and ashamed to say I knew it was the waste gate. Need to brush up.
  20. Is that not the dump valve (probably has a better name)? It's used to regulate the boost pressure and actively opens and closes to modulate the release. Or, it's the variable vane mechanism on the inlet side but doesn't look quite right for that. Been a while since I looked at turbos so don't quote me on any of that.
  21. Very basic solution but I have used spring assisters that solved it short term.
  22. Comfort is a subjective thing and also more related to the damping characteristics. But you do need to complement the damping with the springs. If you are after a specific feel (in this order): 1. Dampers (for the feel) 2. Springs (to match the dampers and required ride height) 3. Roll bars (to control the roll to the desired amount) (be aware that this can add to the spring rate so going slightly softer on the main springs won't hurt.
