Everything posted by CJJE
keyfob battery failing with *no* warning
The central armrest box has a rectangular hole in the removable compartment that holds the key - as long as you haven't put it in a thick cover Chris
Flashing glow plug light symbol, first fault?
The Skoda website is showing Hawco ŠKODA SEE RETAILER DETAILS Harbour Road IV1 1UF Inverness as an authorised repairer. Is that any help?? Chris
New member, new Karoq
The manual recommends running in as follows: New vehicle - Running in the engine Driving style during the first 1500 km determines the quality of the engine run-in process. During the first 1000 km, rev the engine to max. 3/4 of the highest permissible engine speed and avoid using a trailer. Over the next 500 km, the engine speed can be slowly increased. Depending on driving style and operating conditions, the engine consumes some oil, up to 0.5 l/1000 km. Consumption may be higher over the next 5000 km. New brake pads New brake pads do not provide the optimum braking effect during the first 200 km, they have to be worn in first. Therefore, drive very carefully. New tyres New tyres do not have optimum grip for the first 500 km. Therefore, drive very carefully. When you collect it, make sure the wheels and body are undamaged, as it will be difficult later to prove you didn't do it later. Also, check that it has all its expected accessories such as the net system in the boot, the 'key' to remove locking wheel bolts, etc. Have fun, Chris PS: You can download a copy of the Owners Manual here: ŠKODA Owner's Manuals (skoda-auto.com) This is worthwhile to get a head start on the walk-through the dealer should give you (which may be abbreviated because of Covid) and because the printed manual omits any details about using the Infotainment system (ie radio, satnav if fitted, etc) Chris
My understanding (based on non-KESSY cars) is that the warning appears when you turn on the ignition, and disappears when you start the engine. When you're using a non-KESSY key, this gives you time to see the warning. But with KESSY, as soon as you press the Start button to turn the ignition on, the engine starts (hopefully!) So the only way to see the warning is to stop the engine starting immediately - with a DSG car you can do this by NOT having your foot on the brake pedal for instance. So it would be nice to know if the warning is logged by the car and visible later in the My Skoda app or on the infotainment screen. Chris
A few thoughts on the subject... My car should be safe for a while, but from what I've learned so far the dashboard warning can be missed with a KESSY car because as soon as you press the Start button it disappears. But does the warning get logged in the Notification and Vehicle Health reports in My Skoda? or on the dashboard or info screen when you turn the engine off? Chris
Winter driving, a few observations.
Reminds me of many many years ago when I was with a friend and his car couldn't climb a steep hill in North Wales. But the reverse gear was a lower ratio and we managed it in reverse!
USB SSD drive on Amudsen
I'm using this USB-C Flash drive ok. MyMemory 128GB Dual USB-C & USB 3.1 Flash Drive - 200MB/s £23.99 - Free Delivery | MyMemory There are also larger capacities. Is a SSD different, and add any features? Chris
skoda connect - worth it?
Sorry my mistake. I meant Focus of course.
Skoda Kamiq SE L (Mirror dip in reverse)
In Karoqs (and I think other Skoda models as well) this feature only works if you have mirrors with a memory function in them to return them to the right setting. And Skoda only fit these if you have the electrically adjusted seats (unlike VW). Can't see why you should have the option though in the settings menu. Chris
Virtual cockpit
With my Amundsen it's either / or. But for normal driving I've got the map showing in the centre of the virtual cockpit and the radio on the infotainment screen as my wife/co-driver is more likely to want to adjust the radio! Chris
KAROQ FUSE TYPE
I've just received the LED headlight set from Caffyns, and it is the official Skoda set, just sold at a bit of a discount from the normal dealer - but I suppose the P&P may have negated that! Chris
Low frequency noise in new karoq
This has also been discussed here: Road Noise - Skoda Karoq - BRISKODA But the consensus seems to be that while adding soundproofing can help, a full job requires it being fitted between the floor linings and the metal panels. However if it's mainly coming from the boot, then it is easier to add soundproofing in this area. Chris
MY21 Amundsen Map update procedure
I'm assuming your car is fitted with the new MIB3 infotainment system (with the USB-C sockets and no SD card readers), so it will be interesting to see if Customer Support have realised this yet, and that advising you to download a file of Radio Logos, load it on an SD card and plug this into the car no longer works! (Incidentally, the file you download from the Update Portal doesn't include the logos I wanted such as Classic FM, or Smooth UK etc.) The consensus seems to be that the new VAG MIB3 systems can only show logos if they are transmitted by the radio station itself in its data stream. So any missing or out of date logos have to be inserted or replaced by the broadcaster rather than Skoda/VW/SEAT etc. For instance, one of my local radio stations - Signal 2 - was bought last autumn and rebranded as Greater Hits Staffordshire. But when I tune into this station name, it still displays the Signal 2 logo, and the Amundsen in my car cannot find find an up to date replacement instead. The more complaints the better though, as it may encourage the VAG infotainment designers to update the MIB3 systems by adding back in a way of loading our own logos again as we could in the superceded MIB1 and MIB2 systems! Chris
As someone who helped implement such a system way back when it was a novel Japanese idea (which we at least called Total Quality Management (TQM) I would have hoped that the system would automatically ensure it captured all complaints! As an aside, there was a tale going round that a British company ordered 10,000 widgets from a Japanese firm and specified that that there should only be .02% defective parts. When the box arrived they found a small package on the top of the consignment with a note. "We have packed the 2 defective parts separately for your inspection." Chris
For MY21 Karoqs at least: - the eCall service is free for the life of the car. - the Proactive Service (Info Call, Breakdown Call, Automatic Accident Call, & Service Sceduling) is free for 10 years. - the Infotainment Online Service (Parking Spaces & Prices, Petrol Prices, Online Map Updates, Online Traffic Information, Online Route Calculations & Online Route Imports) is free for first year and then chargeable. - the Remote Access Service (Parking Position, Honk & Flash, Speed Notifications, Area Notifications, Driving Data & Lock/Unlock) is free for first year and then chargeable - but some of these are free via a Connect Lite dongle. The 2 Skoda phone apps have been merged into a single app - My Skoda - although some information about your car such as when it was built has been lost. I'm surprised by your comparison with Ford though as a friend of mine who wanted to update the maps in his Escort was told by his dealer that it couldn't be done, and Ford wanted him to buy a new car rather than going on using his once it was 2 or 3 years old! Chris
My letter was sent on the 22nd, so probably not received until after Christmas. I'd be hoping for a response in the next week or so, or I'll escalate to the Head of Skoda UK. My telephone contact has phoned me today to say they can't progress this remotely and asked me to take it to my dealer. But as we're now in lockdown, and it's not vital, I'm putting that off for now. I also think it's a design problem rather than an individual fault, so unless the dealer can update the software I don't expect much from them. As it's a VAG-wide issue, I wonder if journalists in Autocar, AutoExpress or What Car might be interested in taking it up? Chris
DSG Paddle after purchase
It might be helpful to add this to your profile in the 'Location' and 'Model' fields as we can give better advice if we know these things Chris
KAROQ FUSE TYPE
If you have LED headlights, you can buy a spare bulb and fuse kit here: Skoda Karoq Spare Bulb Set (caffynsparts.co.uk) for £19.95. It includes a range of three types of fuse and there is no mention of any price increases (yet). Chris
I'm sure they can - at a price. But... I never had them on my previous Golfs, and didn't see the need for them to be added. It's easy enough to flick the selector between drive and sport when you want to, and I've never found the need to go fully manual even driving on steep hills and mountain passes. I have them on Karoq as they were fitted as standard, but have never used them. (The two left hand stalks are confusing enough ) Chris
poor demisting
Mine has the film type and cleared the snow and ice last week very quickly! Not having had the luxury of a heated windscreen (and heated steering wheel) I'm very impressed! Chris
Collection Day
And there am I at 74, going from a Golf SV SE to a Karoq Sportline! You're as old as you feel! (But I gave up my Octavia for a Golf Plus because I found the extra height of the seats easier on my back and legs!)
Collection Day
My dealer only looked at my Golf from the outside when he valued it, and only seemed to check for scratches and dents and mileage when I P/Xd it. But it was 6 1/2 years old so I'm pretty sure he was just shifting it on to another dealer or auction house anyway! Chris
Updating SE software questions.
Is that the MY21 Bolero rather than the Amundsen? As my MY21 Amundsen shows Device part number: 3V0035820B; Hardware: H22; Software: 0270. If your Info system is permanently online, then officially it should update itself online when you press 'Update software'. On mine at least that then gives you an option of three things to check for update. But having said that, the only update mine has done was chosen and installed automatically. (Don't know what it was, but it didn't take long, so wasn't the map update.) If however you have the MY20 systems (with SD card slots in the glovebox, you can update it yourself via the Skoda Update portal and an SD card. Chris
Karoq 1.5 SE L Tyres
If you look at the Black Circles website (for example) they will quote the basic parameters for all the tyres on sale - fuel consumption, drive past noise levels, wet grip dry grip etc. AutoExpress and Autobild both give regular tyre tests. (My browser will auto-translate Autobild pages, usually pretty well) Chris
Don't know where you live, but I'm a huge fan of All Season Tyres for cars in the UK. Sure winter tyres are even better in the weather we've had recently in the Midlands, but I find All Seasons a good compromise, and save changing wheels over every six months. Continental All SeasonContact or Michelin CrossClimate + are both well recommended, if they come in the size you need. (I've only checked that I can buy them for my Sportline when the time comes.) Chris
