My favourite Youtube health video
A new favourite as of today. It's a long listen, but apart from the two product placements within it, is all very worthwhile: (it's about ultra-processed foods)
2008 Mk2 1.2 HTP - Reviving help
Are the contacts of fuse 30 clean - not corroded, and is the fuse a good fit (not loose) in the fusebox contacts?
the truth about electric cars
No. Basically, all the carbon atoms in the hydrocarbon fuels become carbon dioxide, and all the hydrogens become water. The efficiency is irrelevant to what the reaction products are, just affects how far you get per litre burnt.
ABS ring
You have the smaller discs (front brake PR=1LB), so the part number to buy/match is 6Q0 407 621 CB. The more common one, for 256mm discs has a larger hub section that won't fit inside your discs, Is the fitting kit you have suitable for Gen2 wheel bearings?
ABS ring
Be careful when buying bearing, there are two different ones depending on brake system type. I'll grab correct part number via your reg in a minute. ECP and their ilk will probably offer both correct and incorrect parts.
ABS ring
It's part of the wheel bearing, unfortunately; and not a simple job to change that either.
Slipped timing chain
If it's the twin cam 70 bhp one, valve damage is extremely likely. If it's the single cam 60 bhp, slightly less inevitable.
Fuse 14 problem
That fuse covers interior lighting as well as central locking, apparently. Expands the search area a bit. Sorry, don't know enough about mk1 Octy enough to help any more than that.
Fuse 14 problem
What year is the car?
1.2 TSI Engine (exhaust?) light came on, then EPC came on and limp mode. No warning lights after restart
Depends how many drive cycles occur without the fault(s) re-presenting, after the lights showed. In this case, yes, something seems likely to be readable.
AC not working
First one I listed in the cabin was fuse 8, not 5. 👍
AC not working
Yes, on cars from May 2011 build it is listed as vacant. Yours was built 24th Sept. Was used in some earlier time periods, and again in some later ones. Owner's manual and generic online info usually struggles and fails to cover all such variants. Battery fuseholder looks like this, with the relevant one highlighted. Measure for 12V on the nut that holds the cable to it. *Confusingly the numbering on the fuseholder itself differs from the numbering in circuits, due to the missing one being counted in the car, but not in the diagram* (I seem to remember, please confirm/deny when you've had a look).
AC not working
There are four cabin fuses shown as involved in your A/C system, Fuse number (Fuse rating) 8 (5) 9 (5) 22 (7.5) 39 (30) There's also the 50A strip fuse in battery fuseholder (2nd from right I think) that feeds the fan control module. If all of those are intact, I would be checking the wiring to the compressor control solenoid, and checking that the compressor shear plate hasn't lived up to its name and resulted in the pulley spinning but the compressor shaft not.
AC not working
Reg plate number or VIN to enable detailed spec to be accessed would be key to me helping here.
Voltage drops & ABS issues
I would be quite doubtful that it is worth replacing the fan control unit. The resistor in the fan is a much more common failure. I think the fan can be removed from above as long as you can unplug the connection, and reach the three Torx screws that hold the plastic 'tripod' that it mounts onto.
- 7 replies
- 1.4 16v
- 16v
- abs
- alternator
Tagged with:
Blue load wire broke
This guy has a good idea with the screwdriver, but omits to push the connector first, which does increase the risk of breaking the latch. The reason for this is that there is a seal within the connector which needs to be compressed to remove the friction in the latch parts.
@EMF push connector body towards alternator then lift the latch in the opposite direction while maintaining this push. You should hear the latch click open, then pull connector away. I don't think this is the same situation as described earlier in this thread though. In the mk1, it always seems to be 10 mins until ASR light appears when DFM wire is broken. 20 miles must take longer than that, I hope.
I think the low speed resistor within your radiator fan has burnt out. Test by unplugging the fan from car and measuring between the connector pins with red wires. You should be able to measure a small resistance between these pins, I think you will see no connection. Replace fan, or repair with an external resistor, but at your odometer reading, it may be best to replace. I think there may be more wrong than just this, but it should help both temperature and voltage stability if you fix this.
- 7 replies
- 1
- 1.4 16v
- 16v
- abs
- alternator
Tagged with:
6 years with my fabia vrs estate
https://www.briskoda.net/forums/subscriptions/
Part Number source failure
Yes, I think you've understood correctly. 👍
Cam shaft sensor
^ That's for a different engine, I think.
Cam shaft sensor
Take it off, measure the o-ring, buy and fit a new one?
How did the MOT go? I can look up part numbers for you if you supply reg plate or VIN. The 411-000 page does exist on LLL, if you go up one level and then look for matching page numbers in the lower right corner of each thumbnail, but the other two - 010 and 020 are missing, as you say.
Self levelling rear lights? MOT failure.
Could do with a comma between Rear and Headlamp, to be fair!
Sounds like someone has mistyped your fail certificate. Can you post a photo, with fail code?
