oxygen sensor in exhaust
Need to know engine code as well if you would like me to try to look up wiring info. A quick glance at a guessed CUNA engine circuit suggests there are two oxygen sensors, which surprised me, and possibly the garage that may have replaced the wrong one?
Parts list
@mczakk were you able to navigate the parts catalogue link I supplied?
P0170
Follow the hard plastic pipe from the brake servo (behind brake fluid tank) towards the engine. At each point where it connects to the one-way valve, look and feel with finger tips all around it for cracks. If there is another connection of hard pipe nearer the engine, check there also.
P0170
Manual or automatic gearbox?
P0170
Can be because of a brake servo vacuum hose that has developed cracks and is leaking air. Which engine size does your car have?
Parts list
https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT
Explanation for Fuse-Relay box configuration
Breezy_Pete replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanSome of these things that look like just relays contain circuit boards which make them 'control units' rather than just simple relays. Usually the outer cover can be unclipped to reveal these extra components.
Radiator fans on constantly - even with ignition off, cold engine.
No need, the number you suggested is correct.
1J0919506M is your fan controller part number, I'm pretty sure. Has two relays inside, one powered by that fuse 8, the other by one of the strip fuses. It hangs off a bracket on the nearside chassis leg, quite near to the thermoswitch. Stuck relay will be the problem, another module swapped in should fix it.
Timing chains
Four teeth of slippage sounds like major damage that will require a major rebuild. Dubious that it's worth it. Probably cheaper to swap a known good engine in, trouble being finding one that's known to be good at a decent price.
Fabia stalling, sort of misfiring, fault 16555
Maybe check cylinder compressions?
When was the car built, and how many km has it covered? Has the fuel filter ever been changed, do you know?
Funny issue with Aircon.
Acoustics of a big wide hole in cabin letting sound of fan motor out better? Will be less pumping loss too, not having to pull through bonnet vents, so will probably run quicker also?
Passenger Window Motor
Start by replacing passenger door switch.
It goes through the pollen filter in either mode on Fabias. Yetis too I think?
Clutch cruise controll switch Need help
Same thing.
I believe in English English there are only two esses in gases.
Select reverse gear and the A/C switches to recirculation mode. Stops you breathing your own exhaust.
Super easy, once you get the lower dash trim off in the driver's side footwell. There's a good guide to doing that in the guide for changing evaporator temperature sensor. https://www.briskoda.net/forums/topic/61180-fabia-evap-temp-sensor-how-to-with-pics/ Download the pdf version to see the pics. Clutch switch just turns 45 degrees to release from above pedal, opposite twist to fit new one.
Which oil for CKFC engine?
Yep.
Windscreen Wipers - One side malfunctioned
Just a hard push to fit, from memory.
You can get refurb kits but a whole new replacement linkage is probably not much over £30 for aftermarket/pattern part.
Yes, 507 00 is correct. Beyond that, it doesn't matter.
Octavia 90cv electrical door problems
Can also be dirty and/or corroded connections at any point. Green copper corrosion residue can be the clue to look for.
2016 Skoda Citigo Front Subframe MOT failure
