Breezy_Pete
Sponsor
  1. Fuseholders. Each has a plastic cap that hinges open to reveal a mini blade fuse.
  2. Just inspect it for any change in appearance over the next year or so. I wouldn't worry particularly, unless changes are visible.
  3. 8Nm + 45° turn may well equate to something close to 17Nm. Torque plus angle is just a more accurate means of getting a given pre-tension in a fastener. Working out theoretical equivalence is tricky, because friction is so dominant, and unpredictable, in traditional torque-only specs.
  4. Discs (front) are 288mm, PR-code 1ZE, current part number for genuine discs is 5Q0615301H. Front pad set has current genuine part number 5K0698151B.
  5. Hold my beer...
  6. What's the reg number or VIN, please?
  7. First engine problem noticed yesterday afternoon. Took it for a dual carriageway and motorway run to clear out some cobwebs, and even after 45 minutes the indicated coolant temperature still hadn't climbed past 70°C. Stat is tucked behind/below alternator, so not a 10 minute job. Have asked the garage doing the MOT to quote for it, but expect it's going to be too much, so will probably DIY. Amusingly, staring at the engine looking for stat location was the first time I'd realised that the engine is a different way round to what I'm used to; longitudinal.
  8. Nope. NJ as characters 7 & 8 of VIN does indeed mean it's a Mk3.
  9. As in a pic? Not much to say about it, appearance-wise. "It's a car, in a boring colour" 😁
  10. It's mine now. I got the rear brakes done today. Thought for a little while I wasn't going to get the new discs in without taking the carriers off, but managed it with a bit of bodgery. 😁 MOT booked for Thursday.
  11. Fronts 5Q0 411 105 HC - £82.40 + VAT each. Rears 5Q0 511 115 Q - £98.60 + VAT each currently at Skoda dealers.
  12. Good timing, was just about to head back out to a half-finished job. Front and rear springs, yeah?
  13. Possibly the door open microswitch, which is the one on the outside of the lock, or as I've seen personally, cracked solder joints where the connector solders to the circuit board within the lock module. 20200910_155143.mp4
  14. Well done, no need for reward, but keep me in mind if you have any electric window trouble, or hear of anyone else needing repairs. 🙂
  15. Pre-cat oxygen sensor is wideband; so if anything, I'd expect that one to be steady mid-swing most of the time and the post-cat binary one to flick between lean and rich values.
  16. Those suit the BMD (6-valve) rather than BME, according to the catalogue. These are the suggested ones, bottom 4 part numbers are all options for BME: All BME ones except the economy one are superseded by 101 905 617C, but it doesn't say anything about them.
  17. Yep, as per my edit, seems S3 are all (and only) right side front.
  18. Unlikely. You need to have a diagnostic scan done, to see why the light has come on. Any action before that is just guesswork, which can prove expensive and fruitless.
  19. Sounds like a similar situation to being 'a bit pregnant'. 😁
  20. £20.60 + VAT at a Skoda parts counter, if you don't fancy chancing an aftermarket cheapy.
  21. Yep, yours should be the green one 036 919 081 D
