Breezy_Pete
Sponsor
  1. Sorry, I'm not well informed on this, I just read the sticker for you. 😊
  2. Yes, your engine number is 618901 and it appears to have been manufactured on 17th January 2012.
  3. How many miles has the engine done? Was the tensioner changed with the timing chain? As a matter of routine I'd suggest close inspection of the brake servo vacuum hose particularly either side of the non-return valve. Also any flexible rubber parts of PCV pipework.
  4. I reckon he might mean the bearing carrier.
  5. Run the engine with the lid off the expansion tank, see if hose no. 13 here: coolant hoses and pipes; flange; reservoir - Caddy(CA) [EUROPA 1998 year] (7zap.com) is trickling a little water back into the tank, more so when you rev the engine.
  6. Check the expansion tank for returning flow as an indication that your water pump hasn't given up?
  7. Don't have wiring from before 2003, but I think this may be the resistor: BLOWER RESISTOR VW SKODA 6U0 959 623 HEAVY DUTY OEM SKV GERMANY 5901947318751 | eBay Wait for someone else to confirm that this could be the problem though, that's expensive to take a gamble with.
  8. Usually a resistor (actually 3 in series) that fails open circuit. Speed 4 bypasses the whole resistor thing, so is unaffected. Not sure if I have any Caddy wiring info in order to check this theory, will have a look.
  9. I expect the housing is cracked near that bolt. Part number 028121132B superseded that part number way back in 2001, which may improve your odds of searching out a replacement. Plenty of aftermarket parts on ebay, so probably also obtainable by a decent motor factor. 028121132b | eBay
  10. Just a case of one part number superseding another I think mate. Checking here, both of those part numbers appear under the Skoda part number heading near the top of this page: Relay 645 Germany 4H0951253A (skoda-parts.com) I think any of the part numbers in that line will do the job.
  11. Yep, direct
  12. Pin 1 at sensor blue wire to pin 112 at engine ECU, pin 2, brown wire to ecu pin 104.
  13. Year of car? ASZ or BLT engine?
  14. Not sure if this page helps any more or not? Skoda Workshop Manuals > Yeti > Heating, ventilation, air conditioning system > Heating, Air conditioning > Air conditioner > Climatic, air conditioning system with manual control > Removing and installing the evaporator vent temperature sender G263 (workshop-manuals.com)
  15. Sorry, forget that about LHD/RHD.
  16. I'm not 100% sure, but I think you should have two working reversing lights. Black/blue wires feeding into pin 4 of the connector each side.
  17. You are about to receive a private message with a photo that may help you.
  18. Very interesting link, thanks.
  19. So, who watched the show? Someone must've?
  20. Your engine code is needed to find this. See link in my signature about engine codes.
  21. Wiring tends to be as thin as it possibly can be, and gets heat-cycled and vibrated whenever the engine is run. It's also now 15 years old. Careless workmanship during maintenance or disconnection without understanding of the latch mechanism are also risk factors. Always worth a quick look in the vicinity of the connector cable entry.
  22. Heated and electrically movable, yes.
  23. I was afraid that's what you'd find. So none of the necessary wiring inside the car is going to be present, in the main part of the cabin, at the a-pillar connectors nor in the door looms. Hard to be balanced in my opinion as I haven't tried 'Fabia life' without them, but are you really sure you need this?
  24. Could be either of the last two wiring diagram versions, but they're probably the same anyway. See if the cabin fuse position 38 has 0, 1 or 2 contacts installed in it as a first step.
