Breezy_Pete
Sponsor
  1. Yes, looks like wiring or bulb holder contact problem.
  2. I don't think you can put the new gas in old systems or vice versa, but not too sure.
  3. Interesting comparison. I'd read that the new stuff leaks more, so that seems to be confirmed by your data.
  4. In the cabin, because that's where the evaporator (item 15) is. Sensor is Item 29 here air-conditioning system with electronic regulatio... - Yeti(YET) [EUROPA 2016 year] (7zap.com) (view on computer, not phone) Somewhere near to the pollen filter, seemingly. Sorry I can't be more precise.
  5. I think the radial-seal cap o-ring may not be applicable to Felicia, having looked at some google images. An easy test that may well indicate a HG problem is to check for residual pressure in the expansion tank several hours after the car was last driven (overnight for example). There should be no such pressure.
  6. Yes Have you checked for wiring damage near the connector plug?
  7. Actually, digging deeper suggests various other suffixes have come along and will do. See next to 'Skoda part number' here: Throttle Valve TDI Germany - OE producer 038128063F (skoda-parts.com)
  8. Your part numbers are a digit off, it should be 128 in the middle, not 129, according to ETKA. (item 3 here: vacuum system; exhaust gas recirculation - Fabia(FAB) [EUROPA 2006 year] (7zap.com)) The suffix G part number has been replaced by suffix L, no idea what suffix M fits. Buy 038128063G controller lid Audi, Seat, Volkswagen genuine OEM part (oemwolf.com)
  9. Look at the cap and where the sealing o-ring is. If it's like later designs, it seals radially outwards against the inside of the neck of the tank. The point where it presses on the tank neck may be worn/indented due to years of pressure and heat cycles. Fingertip may feel this. I'm not sure that the Felicia cap is designed this way, but easy to see.
  10. I would advise against this, generally. Oil pressure is proportional to rpm up to a point, and low oil pressure in the crank lubrication area whilst requiring significant engine torque is a recipe for faster wear. Fourth gear up to at least 30mph, maybe even 35 is much kinder to the engine mechanicals. Keeping revs higher, especially in winter, also gives the alternator an easier task generating the necessary current to recharge the battery after cold start, heated rear screen etc.
  11. Do you know if your car was made after or before May 2006?
  12. Is it the original expansion tank the car was built with? If so, check the neck of the expansion tank with a fingertip, feeling for an indentation where the cap's o-ring has been sitting. It may be that there is such a groove, and it is leaking because the o-ring has more of a gap to fill than it was designed to.
  13. View this page on a computer rather than a phone, or you may not see all the info. Item 41 looks like the seal you are interested in, and item 24 is the return pipe screw. Google images suggests this is an XZN type head fitting rather than torx, which may be why the originals have been chewed up. exhaust gas turbocharger; exhaust manifolds - Octavia(OCT) [EUROPA 2010 year] (7zap.com)
  14. There's nothing to be gained by wiring it in. In fact both will be very slightly dimmer, and the fuse and switch are more likely to fail.
  15. No foglight on nearside is normal/correct, there's no wire to it. Brake light, swap bulbs across so working offside one is on nearside and vice versa. Check now what works/doesn't.
  16. @AnnoyingPentium has given you an excellent suggestion. The MAP sensor is fine just clipped in, screws will not change anything. When were the spark plugs last inspected or changed?
  17. Look at the 7th and 8th characters of the VIN. 6Y=mk1 5J=mk2 Pretty sure you'll find 6Y, as I don't think BME engine featured in mk2.
  18. I don't think you will need different window motor modules. Only on earlier cars does the electric mirror wiring go via them. On a 2006 car it goes direct, I believe.
  19. If you mean whether more voltage will make much difference, I'd say certainly. Brightness goes up with the square of voltage applied, from memory. But you maybe meant, "if it's an option to adjust"?
  20. So the voltage at the bulb connections is ~88% of what could possibly be there if full system voltage were being supplied losslessly. I think that does suggest it's being throttled back actively. Can't really imagine 12% being lost otherwise. So maybe can be de-throttled by suitable coding adjustment.
  21. Send me your address and I'll buy you a set for Christmas... 6'' LCD Digital Vernier Caliper Micrometer Measure Tool Gauge Ruler 150mm Silver | eBay
  22. What do you see across battery posts in same conditions (engine running lights on)?
  23. M18 x 1.5mm usually, I think. Put a vernier across the new one's thread to check the OD is about 18.
  24. For anyone who likes to see the ins and outs of things.
