Heater fan and headlights not working
Try it with the ignition switch turned to the first click round, one before the position where warning lights come on.
Varaderoguy - disappearing off into the sunset
Hope you get over the illness promptly and find a new and better job too. All the best.
Rear Brakes
XZN-headed bolts have size descriptions that sound like thread-size descriptions (M5, M6, M8 etc.) but confusingly there isn't actually a 1:1 correlation between bolt thread size and the tool sizes that fit in the heads. The two measuring systems on this page give alternative ways of determining which size XZN tool you need: triplesquaretable.pdf (metalnerd.com)
Emissions high
This is a petrol engine, isn't it? Must be something very wrong to be putting out 6-7% CO at idle. Never be in an enclosed space with engine running before that's sorted.
Brakes dragging/locking up, master cylinder does not release pressure
It would be easy enough to temporarily remove a fuse or two to make sure the ABS system was inactive, and see what changes? Would you like me to see which fuse(s) are relevant?
Window motor repair service
@Nivek74; why not send me the (Polo) module referred to here https://www.briskoda.net/forums/topic/499167-electric-window-problem/ and I'll check it over for you to see if it has the problem I expect. If it has I'll extend my 20% off offer mentioned above to you. If not I'll return it FOC. Do check that fuse though.
Electric Window Problem
No luck retrieving your original module?
It's as I thought. Would also be a feed to the mirror heaters if fitted. Feeds 12V to pin 2 of the 6-way connector at drivers window module.
I'll check in a minute, but from memory it's an ignition 12V feed that wakes up the drivers side module.
Was fuse 11 one of the ones checked?
Going to look at mk3 superb in red....
Accessing the fault light to obscure it is one possibility... Did the seller have an explanation about how that situation was resolved?
Possible indication that the needles have been taken off, and that one pushed back on too far, so it rubs/catches?
Ask when you get there, and review receipts for the work done following that MOT fail. Have a good look at the brake discs,
Maybe they scanned car to see why light was on, fixed the cause, now all good?
Fabia, AC heater problem
A VCDS autoscan, or simple scan of the HVAC module (08) may indicate a fault with the V68 motor. This controls the flap which chooses whether incoming air is sent through the heater matrix or bypasses it. Giving the flap motor a 'workout' by turning the temperature control from one extreme to the other several times while the system is running. See if that results in any hot air at any time.
No engine light, no start, no fuel pump noise
If the 20 amp fuse in position 56 has metal contacts accessible to probe while still installed, see if it has 12V on both sides of it when the ignition is switched on.
Maybe someone has obscured it? Do you see the warning light 'self test' as you turn the ignition on?
changing oil spec
If your engine is a PD type, the important part of roottoot's chart is circled here: Using any oil that isn't rated to 505 01, or 507 00 will cause rapid cam wear on a PD.
Can anyone advise how many glow plugs are in my Skoda Fabia Scout 1.6TDI?
Glowing reports or glowing plugs?
Location of spark plugs on 2007 fsi 1.6?
Have you taken the cover off the top of the engine?
I believe your engine has no such clearances, you have hydraulic 'equalising elements', item 8 here: camshaft, valves - Fabia(FAB) [EUROPA 2012 year] (7zap.com)
Underneath the ignition coilpacks.
Fuses 17 (5 amp) and 56 (20 amp). I suspect fuel pump relay if both of those are OK. What year was the car built?
Just 4, and if it was only 2 months back it should be a free warranty job IMO. Possibly a misdiagnosis both times.
Has my timing chain skipped? Any easy way to check?
Well done fella. Having tried both rebuilding and engine swapping, I'd say swapping in another engine is about a quarter of the difficulty. I was dead lucky to find a very low mileage engine that turned out to be a cracker though, for relatively little cash. Always going to be an element of gambling there.
