The dreaded (apparently) electric window issue.
Check fuse 11 too if you haven't already. I don't think the comfort module (J393 central convenience) has much to do with the operation of these, although this is a generation on from the type I have most experience of. Driver's side module talks to passenger side module via a LIN comms wire, but there are no data connections to other modules, I believe. It being a mk2, the likelihood of this being a wire breakage within the door bellows is very high, so double check every wire.
Excessive oil leak and no oil in the engine at all
This is a petrol car, right? No DPF involved.
Pinout details for Solenoid Valve Block connector
Other wire 12V not ground, same 12V as any other solenoids, probably off fuel pump relay.
Low oil pressure in morning.
Did you check it again to see if the new fuse has blown?
No luck cos it blew again, or which warning light are you seeing, both? As far as I know the red one is only to do with the pressure switch, the yellow/amber only to do with the level/temperature sensor, so you may have two different issues; which would be surprising.
Rounded wheel bolt!!!!
Yep, I edited my previous post to acknowledge this.
Loosening the locking bolt first has the advantage that if you can't undo it for whatever reason, you abort the whole mission a bit earlier and with the wheel still securely attached. Battling a reluctant one with a possibly dodgy worn key, possibly on a widow-maker jack with all of the other bolts out is a bit of a risk if things come tumbling down.* I'd always bin them off for standard bolts on a daily of mine. *afterthought - the car's still on the ground at the point of first loosening, so this is probably all nonsense. Fits in well in this thread, I feel. 😁
Well I have to be honest, the permutations of cars, engines and ECUs is baffling my brain this morning but looking at an Octy wiring diagram for a 2006 BXE, the N75 valve is driven by ECU pin 29.
Check cabin fuse number 4 and replace if it is blown.
I'll see what I can do tomorrow morning, if no-one else chimes in first.
What car, what year?
Fault codes
Note that I was laughing about it, not crying about it.
Fault codes
Make up your own mind fella.
Fault codes
Such a rude man.
Fault codes
Letters in front of engine number on your V5c.
Honey as part of your healthy eating.
The explanation seems very muddled. "[Useful] Hormones are fuelled by fat, so we'll put glucose in instead" (paraphrasing a bit brutally). My understanding of metabolism says that the body only 'runs on fat' when excess glucose isn't available in the bloodstream, so I don't see how adding it helps. Not saying it doesn't work, just sounds a bit backwards, as explained there.
coolant flow diagram
Generally into rad at top hose, out at bottom one.
Thermostat is here (item 6): coolant pump - Octavia(OCT) [EUROPA 2003 year] (7zap.com) Seems quite likely to be at fault, especially if 18 years old.
Fault codes
Crank sensor fault, according to my Google. What engine is in your mk2?
Rear air vent removal
Getting kicked as people cross the car in the back?
Tensioner pulley has come adrift
Actually, maybe not, do you mean the tensioner has come loose, or just the pulley?
The SDI is ASY engine code, so item 24 here? connecting and mounting parts for alternator; pol... - Fabia(FAB) [EUROPA 2004 year] (7zap.com) View on computer not phone to see all the info.
What does this switch/button do?
Fabia?
Grow up.
