P0118 Issues
Drastic action considering I've already explained that it shouldn't fail MOT! (Unless the default map with no coolant temp input makes it too sooty for the emissions). I reckon there's a strong chance the wire is bust near the engine, but check the loom for scuff damage wherever possible, and yes, don't be shy of exposing copper at either end of the wiring to help with pinpointing the fault location, or having said that, poking a pin/needle through the insulation to minimise damage while allowing probe connection to said item.
Electric vehicles and charging
I've got a bit of cable arriving shortly to upgrade my outdoor wiring to provide for overnight visitors who might want to charge an EV through a 13A socket. Got caught out last weekend with a friend driving an ID3 who struggled to find vacant public chargers locally. Felt I'd let her down by not having anything suitable near enough to a parking spot.
P0118 Issues
Run a separate wire between accessible parts of the existing wire to prove the fault goes away when you splice that in. Then decide whether you care about appearance.
Steering issue/concern
Yeah, that's probably the simplest explanation, or someone read the 20Nm + 90° tightening spec and didn't understand the last bit, so didn't do it.
Ooh that could've been bad if the last bolt had gone. An illustration of why those should be replaced rather than re-used, perhaps.
P0118 Issues
P0118 Issues
Yeah, I'll get you a screenshot of pin layout. Was the sensor end connector moist inside?
Biceps tendon rupture, anyone 'been there'?
Almost a year on and I thought I should update this in case anyone ever reads it and wonders what happened. The NHS route proved to be a bit messy, eventually getting offered an ultrasound scan somewhere in north Wales and declining it on the basis that so much seemed to be stacking up in favour of just leaving it and doing nothing. Private consultations and scans were priced up but not followed up on a cost/benefit judgement. Back to the gym tentatively in May when things started opening up again, and finding to my significant surprise that the right arm still worked just as well as before! No right shoulder pain (which used to be a chronic problem) and apart from the bulginess when working hard, no pain or other obvious deficit in the right bicep. No cramping. My sports massage guy reckons it has re-attached itself to something, possibly the other 'cep', without any active measures. Sailboat racing has also resumed without any apparent issues, in fact I've been winning more than usual. Stronger winds in the coming months may be a tougher test though. Overall I think I'm better off than before the tendon rupture. Who'dathunkit?
Mounting a new gauge set on Fabia that doesn't have oil gauge?
All fuel injected cars have a coolant temperature sensor.
Oil light
I'll try asking this again; what (exact) oil is in the engine? Is there anything to make you think the engine might be running hotter than normal? Put the A/C on and check to see if the rad fans are working.
Oil Filter
03D198819A, item 14: oil pump; oil filter; oil dipstick - Fabia(FAB) [EUROPA 2013 year] (7zap.com) That includes the big o-ring that seals the top of the housing.
Brake pad confussion
It seems to be the norm with VW group, possibly policy to dissuade amateurs from mending their own cars. Obtaining the full 'car data' from an obliging parts department employee, or yourself via erWin for a small fee (<£10) is the solution, and will give you all of the PR codes, far more than what is shown on the sticker.
Low Voltage Problem
This test should really have found this problem, I'm not sure why it didn't improve things; can you remember what thickness the parallel cable was, and length? When you say 6mm cable do you mean 6mm² cross-sectional area? If so that sounds thinner than I would choose if I were fitting a replacement cable. I would go for at least 10mm² if not 16. Well done for your persistence and eventual success.
Welcome to Briskoda. I don't think any Fabias have an oil gauge, other than some that may have a digital oil temperature readout? I speculate that you actually mean a coolant temperature gauge, as shown in the image below? Changing instrument clusters may be tricky, with coding needed, so I suspect it'll be more trouble than it's worth.
Help! Wet pollen filter
Scuttle area drain exits tend to be behind the front wheel arch plastic liners on models I'm familiar with, which doesn't include yours unfortunately.
P0118 Issues
Yep. Pin 1 of the sensor connector goes via a blue wire to pin 112 on the ECU connector, pin 2 at the sensor connector via brown wire to pin 104 at ECU. Look for signs of fluid inside the connector housings at both ends, as well as any sign of dirty or corroded contacts. I know you'll want to fix it regardless, but it shouldn't actually be a problem at MOT if the light stays on. Note the last sentence here, your car is too old to have the MOT test care about the MIL status: Engine malfunction indicator lamp (engine management light or ‘EML’) Turn on the ignition and check that the engine malfunction indicator lamp (MIL) illuminates and then goes off. On some vehicles it will be necessary to start the engine before the MIL goes off. You need to inspect MIL fitted to diesel vehicles with 4 or more wheels and first used on or after 1 July 2008. From here: 8. Nuisance - MOT inspection manual: cars and passenger vehicles - Guidance - GOV.UK (www.gov.uk)
New Member hoping for advice
Keep checking it each time you get in the car, before starting the engine (or even putting the keys in the ignition). If the numbers are always above 12.2 say, and stay consistent from one day to the next, things are OK. If you see a downwards trend in the voltages from one day to the next for a few days, and it looks like it will dip below 12.0, try to do a journey of a few more miles to give it a bit more charging time.
It's the figure shown before you start the engine that is the one to really keep an eye on @Vanwin. What do you see at that stage?
Oil light
Not that I can see on wiring diagram.
Skoda Fabia 2003 1.2 HTP (117000 miles) - Engine turning over quickly but not starting
Yeah, almost certainly not worth it.
The 12 valve 64bhp version is definitely interference. I expect the 6-valve may be too.
Catalytic converter and exhaust for 2005 Octavia 4x4 petrol 2.0 FSI engine, code BLX
Part seems to be the first item 1A here: exhaust pipe with catalyst; ----------------------... - Octavia(OCT) [EUROPA 2005 year] (7zap.com) (view on a computer, not phone to see all the info). Part number 1K0254500QX. Superseded in Aug 2012 by 1K0254506HX apparently Buy 1K0254500QX exhaust pipe with catalyst Skoda, Volkswagen genuine OEM part (oemwolf.com) Not sure that helps massively though. Welcome to Briskoda, by the way.
failed MFSW(Multi-function steering wheel) retrofit
I can only speculate that you have read the pin numbering wrongly. On mk2 Fabia I think the LIN connection at pin 17 should be found to be a grey/white wire.
Oil light
I think the spec for 2000rpm is 2 bar minimum at operating temp, that's about 29psi. Edit: according to this page I'm wrong about that 2 bar, for this engine, it is 1.5 minimum at 2000 rpm Skoda Workshop Manuals > Fabia Mk2 > Power unit > 1.6/55; 66; 77 kW TDI CR Engine > Engine lubrication > Removing and installing parts of the lubrication system > Testing oil pressure and oil pressure switch (workshop-manuals.com)
Oil light
This suggests there may be a real problem with the pressure, I fear. What pressure was measured at what rpm by the garage? What oil is in the engine and when was it last changed, along with the filter?
