Breezy_Pete
Sponsor
  1. Check the ports they connect to at both ends too, especially for the small hose; if you didn't already. Easily blocked in the narrowest parts I imagine.
  2. Hehe, I thought "wow, look, they even found oval bungs that exactly fit the exhaust ports!", but then looked closer and saw that they're just round ones squished to fit. It was very nicely extracted and prepped for shipping and fitting though. Whole loom still intact ready to just plug in at ECU and 14-way. bay connector, and so many bits left on,
  3. It wasn't a daft question Lee, it's been running since Friday 5pm, just the pictures posted finished Thursday evening.
  4. Yep, very pleased with it. I think the dogbone mount is 'code F' though, and am waiting on a new one, probably Wednesday arrival/fit. I think then I'll really be able relax, put my feet up and say to the missus; "There you go, all good for another 100k+ miles... ....FFS don't crash it tomorrow!"
  5. The replacement engine came from a Polo, so has oil level and temperature sender. I wonder how long I'll be able to resist adding the necessary wire to the cluster to get that to do something... Not sure whether the cluster can display oil temp if coded right, but oil level warning facility might be useful if that at least could be enabled.
  6. You replied to me as well. Don't feel you have to though.
  7. Thanks for your contribution.
  8. Yeah, as and when. No heated shed so won't be for some time... I've never taken the bottom end of an engine apart so not too sure what order to do things, nor what to look for. Expect to see trouble with bearings and/or piston rings I think.
  9. You mean the seatbelt? That came on the replacement engine, so I figured, it's already worked. Engine plus pallet plus free tyre was only 95kg according to the shipping info, so well adequate. Should've seen what I used to lift the old engine out...
  10. A small selection of photos: Front of car off, ready to extract old engine Replacement bolted in, lots of connecting up still to do at end of Thursday
  11. That is a very neat repair.
  12. With engine idling, fully warmed up following a twenty minute drive, I looked under the bonnet and removed the engine cover so I could see around the area better. There was no glowing of any colour, even when I looked from the sides to see under the heatshield. I took this photo horizontally from just in front of the battery, looking across towards exhaust manifold/cat : Ambient temperature was a chilly 0.5°C though.
  13. I'm not very familiar with your engine type, but two rubber hoses, one thicker than the other; close to oil filler cap at one end, from memory. There are others who will be able to help better later, I feel sure.
  14. I seem to remember that the o-ring seal for the cam sensor is available as a separate part, which should save money. Have you checked that the breather hoses and their connection points are all unblocked? Oil leaks usually only happen because the engine breathing isn't working properly.
  15. Cam sensor; too many wires for an oil pressure switch. My go-to parts lookup site is offline just now. Will check back tomorrow.
  16. I promise I'll have a look this evening after dark, I have to shuffle cars around anyway before the morning.
  17. Yes Lee. Seemed easier that way with the facilities I had. I'm not fond of peeing about with driveshafts when working near ground level. Last-minute snag with a fuel hose leak, only apparent once running, but solved with a foot of fresh stuff from a local factor.
  18. It's in and working nicely. Didn't arrive til 11.15 yesterday, but things went pretty well thereafter. Might chuck some pics up tomorrow.
  19. Buy 1Z2941015B halogen twin headlightsfor gas discharge bulb Audi, Seat, Skoda and VW genuine OEM part (oemwolf.com)
  20. Dunno, sorry. @langers2k is the kind of excellent fella that might know though.
  21. No probs. The first two fuses mentioned are in the engine bay fusebox.
  22. 21 CANL to gateway pin 6 23 CANH to gateway pin 16
  23. Pin 1, red wire permanent 12V from fuse 4 Pin 14, red/green permanent 12V from fuse 16 Pin 20, black grey ignition 12V from cabin fuse 2 Pin 26, brown/black chassis/earth. CAN to follow
