Skoda Fabia 1.2 AZQ Timing Help
Are you using a new chain, or the original one?
Help need with Code P0118
Maybe examine the connections at the engine ECU ends of the wiring, and measure the resistance of each wire. Pins 104, 112 at the 40-way connector. And maybe look at the loom run between engine and there, looking for any signs of damage. Wondering if an intermittent short to some other random wire might be responsible.
Battery not charging under 1500RPM
Hmm, sorry that didn't work out for you. If you fancy one more go, try it without locking the car, but otherwise everything the same. The reading jumping about may have been a flashing LED in the driver's door lock button (signalling "alarm set") if there is such an LED on your car? Was it jumping between two numbers about 5-10mA apart?
Leaking Panoramic Roof - The Cause and the Cure
Now that you've mentioned that possibility, some junior engineer at VW/Skoda will be tasked with investigating the feasibility of that tomorrow morning.
Ironically and disappointingly, this is probably much more expensive for the manufacturer to achieve reliably than to have a system which routinely dries the incoming air in response to a sensor saying "ooh it's a bit damp in here".
Where's the humidity level sensed? Don't think I've ever seen reference to a humidity sensor in these systems?
Considerations for removing the battery?
Yes. Tayna.co.uk are very swift at delivery usually. May as well try charging though, nothing to lose. Be persistent though; may take a few goes.
3 One-touch electric window function will need resetting. Do you know how old the battery is?
Strange Alarm/Door problems
The two window regulator units have a direct data (LIN) connection between themselves, as well as connections back to the central convenience unit (J393). Not sure how that is relevant, if at all; but it might be why the two units seem to 'swap faults'? The logic of the door open switches is such that disconnecting the lock from the window regulator will be the same as the door being closed from its viewpoint. The door-open microswitches short to ground when the door is open, and break the circuit when door is closed.
The circuits say that the (non-ground) connection from the door open switch goes to both the window regulator unit and the onboard supply control unit. If it's possible try viewing the doors' status (open/closed) in measuring blocks of both J519 (module 09) and J393 (module 46, I think). See if they disagree when the window reg unit is unplugged. I wonder if the fault with the passenger door lock remains, and is actually the ground connection to the lock unit, as I found on one last summer on our mk1, rather than the microswitch itself. The microswitch wires go into the board at the bottom of the photo and the left hand (ground) one can be seen going to the dodgy joint of the connector. 20200910_155143.mp4
Octavia mk2 1.6MPI cranks but won't start
Compare compression with other cylinders.
intermittent glow plug light
Relay is the same thing as the control unit. It's all solid state now, no moving parts.
exhaust blowing issue
Do you weld?
Octavia 2 1.9 tdi not starting
Check fuse 15 under the bonnet. Your engine code would be a helpful piece of information in getting to the right wiring info.
New battery, new problem
When you say you've changed the battery, do you mean DIY, or you had it done by a garage/dealership?
Steering rack replacement
Consider investing a little in the VW tool set that allows removal and refitting of the subframe-plus-consoles without losing the alignment of the consoles relative to the chassis: VAG Subframe Locating Pin Set 4 Pc Subframe Alignment Tool Golf Audi Polo 6189 | eBay I think that's the right tool, but double check before buying. The point is that the two relevant holes on each console that the M12 bolts go through to hold it in place on the chassis have 17mm clearance holes. This is how the front alignment is set up in the factory, by the waggle room within those oversize holes. I haven't done the job but I think the idea is that you remove the M12 bolts - one at a time - and replace with one of these, which when tightened up gives a 'dowel' effectively for the refitting of the consoles. When refitting you slide the consoles up onto these dowels, and remove one at a time to replace with the bolt. The fatter parts of the tool can slide relative to the thread axis, which is how they fix the original positions when tightened up.
Skoda Fabia 1.4 mpi Rough Idle, Seems like it wants to stall.
LED, so unlikely. May have been nobbled though... Voltage-related faults can be just battery disconnection, if you've done that at any stage?
New Remote Fob - 315 or 434 MHz
I think 434 is the answer, but if you take apart your current key/fob, you should find the info printed on it somewhere, e.g.
- Drivers door lock issue
A little example of such a broken joint. I think it's a mechanical wear and tear thing with years of door shutting and consequent flapping of the loom near the connector. This one wasn't easy to spot initially because of the conformal coating painted over the solder joints: 20200910_155143.mp4
suspension spring colour codes?
Skoda Catalog [europa] (7zap.com) That's what I'd use. Don't try it on a phone. they tend to reduce the number of columns of info, often dropping important ones.
Blower motor / Aircon
Have you definitely checked the right one? Sometimes Skoda fail to differentiate clearly between LHD and RHD fuse layouts, leading to confusion. The correct one is 25 Amp rated.
VRS ECU PIN 88 ( t40a/88 ) - Whats it for?
Have a look at the 'basic equipment' section of the circuits, particularly the ignition switch. Terminal 75 is one of the outputs of the switch at pin 2, going to the load reduction relay (J59) coil, the onboard supply control unit (J519), and anything commoned to point A33 in the circuits. It seems to only be powered direct from the ignition switch at the first position of clockwise rotation. It's not obvious to me just now what's going on with this. J519 can presumably maintain/control this A33 rail independently of the ignition switch. The connection of this to the engine ECU looks a bit like a 'wake up and get ready' signal? Looking forward to understanding this better!
What is Positive connector (73) ? - Fabia VRS
EGR delete is it an MOT fail
The OPs' car in this thread is a turbodiesel, so the likely impact of EGR delete on real world emissions would be significantly more NOx, marginally less CO2 and probably lower particulates. What's your stance on NOx and its impact on human health in the immediate term? Interesting and somewhat forceful first post. What vehicle(s) does your family drive?
