Front brake upgrade on MK2 Fabia 1.6 TDI
The car I mentioned came on 14s not 13s. You do rather "inflict" your excitement about small wheels on a lot of other peoples' threads. Why not start your own?
That list ^ is also wrong with regard to 239mm brakes. Some mk1 1.2 64hp also got 239mm. I know because my partner owns one. Other mk1's with that engine also got 256mm, also not there. Why work with a list/site that's known to contain inaccurate info?
Air conditioning blower control prblem
Heater resistor. This video shows the replacement on a VW Up, and is on a LHD car so you'll need to mirror some bits for RHD. The amount of trim removal necessary for access on a Citigo, and the method of such removal may well be different too, but the resistor will be in the same position between fan and pollen filter. How to Remove Heater Blower Motor Resistor VW UP - YouTube
PR Code for brake caliper
- PR Code for brake caliper
OK, I've gotta make more use of screenshots! One moment..- PR Code for brake caliper
PR code is at the top of the info table on the right, data model column. If you're browsing on a phone sometimes some columns go awol. The other 288 version (in 2012) has red painted calipers and carriers, as per this page: disc brake - Fabia(FAB) [EUROPA 2012 year] (7zap.com) 1ZD PR code.- PR Code for brake caliper
Oh man, I just read aren't painted as are painted and deleted the previous reply! Re-instating: 1ZC floating caliper brake; brake caliper housing; cal... - Fabia(FAB) [EUROPA 2012 year] (7zap.com)- PR Code for brake caliper
And are the calipers coloured or natural?- PR Code for brake caliper
I'm seeing someother options for later mk2s so need to know the year also.- PR Code for brake caliper
Think it must be one of the two listed here: 1LN or 1ZH* floating caliper brake; brake caliper housing; bra... - Fabia(FAB) [EUROPA 2010 year] (7zap.com) Assume they are 288mm discs? What year is the car? *See further replies below, this isn't right- PR Code for brake caliper
Front brake PR code is often missing from the sticker; unhelpfully. I'll find out what you need though, from FN3, I think, 1 minute.- Rear axle knock?
Damn, that's unlucky!- Battery change
If they'd just driven a lap of the car park all those warnings would've gone out on their own, without all the faff.- Please help - coolant temp gauge issues
I presume you ignored my post because you don't have DSG gearbox?- Sump nut
Sump might even be plastic, as might the sump plug. Too new for my experience though. There's nothing quite like having a look though. Take a magnet with you, and you'll soon be able to tell whether it's steel or aluminium, if it isn't plastic.- Skoda Fabia MK2 exhaust manifold red glow....??? is that normal
Or DSG thermostat if you have that type of gearbox? Seems more common failure than engine thermostat. Easier to change too, I believe.- How deactivate door open sensor Octavia 2011
1 yes 2 no harm at all- How deactivate door open sensor Octavia 2011
Looking healthier. Maybe try not charging it for a few days and just measure voltage to see if it holds at a good level?- Stainless exhaust
I'd be surprised if it didn't last ten.- Stainless exhaust
Standard factory exhausts are a low grade stainless I think; is your concern longevity or looks?- Fabia Mk1 Gear / transmission oil viscosity and change interval?
One final suggestion. The fill plug is much harder to reach than the drain plug, so should be the first one that you loosen. You don't want to drain all the oil out and then find that you can't get the fill plug open to refill it. Both will seem quite tight if they've never been opened before.- Fabia Mk1 Gear / transmission oil viscosity and change interval?
Correct, with the fill plug being higher, obviously. Both at the rear of the overall gearbox housing though. Buy a pair of axle stands.- Fabia Mk1 Gear / transmission oil viscosity and change interval?
Cos it's right at the back of the housing.- Fabia Mk1 Gear / transmission oil viscosity and change interval?
You may really have trouble getting all the old oil out if you don't lift the front of the car. Examine the gearbox housing and position of the drain plug and you'll see why. - PR Code for brake caliper
