Breezy_Pete
Sponsor
  1. Without a fault code read, I would say you're probably wasting money and time swapping sensors out on a hunch. If it is the knock sensor, I'm pretty sure a fault code would be stored. Find a member near you with VCDS and get it scanned.
  2. Hmm, it would be a lot easier to get at from below. You'd probably have to remove inlet manifold, fuel rail, injectors and all sorts to do it from the top. Fault lights on?
  3. Is this on your BZG? What makes you think it needs replacement? Tenth photo in this listing shows it just below the plastic coolant pipe going across the back of the engine: https://www.ebay.co.uk/itm/SKODA-FABIA-5J-MK2-07-14-1-2-PETROL-1198CC-BARE-ENGINE-BZG-03E109211F/114141497188?hash=item1a935d0764:g:Eg4AAOSwZJReYOTa
  4. Hi Rob, welcome aboard. 😊
  5. I've yet to do a belt on one of these, but it sounds like you know what's right and what isn't; and currently it isn't.
  6. I've thought of a compromise on the 'if the car will make it back' issue. If I set out at roughly the same time in my Polo, with VCDS laptop on board, and tools/spares in abundance, we should meet somewhere in the middle after a bit over an hour (provided we agree on exact route!) and can continue in convoy for the remainder of journey. Think she might go for that, and I'd be a lot happier that way. Gonna practise my endoscopy on my Polo later on today.
  7. Dunno, to be honest. It's the simplest explanation, and they often turn out to be right. Why was the cambelt changed, just routine preventive maintenance? No issues before then?
  8. I expect they'll just be QR codes before long.
  9. I just watched a youtube video that set me back on the right track. Bloke inspecting valves with an endoscopic camera. My mistake was trying to use this tool to look upwards. The right way to do it, is to use it (with dinky little mirror at 45 degrees) to look sideways... If the car will just make it back here...
  10. I think it's high time I worked out how to get an upwards view inside these cylinders, especially no. 2. I know I could get the head off in very little time, but it'll take me ages to get it all back together, and I'll be so upset if - when I get in there - there isn't any sign of trouble that would justify the removal! If it wasn't for the silicone sealant everywhere, cam cover to head, timing cover to everything, sump to block and timing cover, it would be much less onerous.
  11. Interesting thought, thanks. Would be easier, for sure.
  12. Yeah, you're right on that. Trouble is, I'm really unconvinced that swapping in another coilpack is going to have helped, cos I've already swapped in different (spare) coilpacks into cylinders two and three, a few days ago, and left them in there. So that can't have been the issue before then, and now. Can't help thinking she'll have recurrence(s) of limp mode on the way back on Sunday, due to real fault (whatever the hell that is). I want to drive out to where she is* in my Polo, swap cars with her and come back in hers. She won't hear of it though cos she has breakdown cover, I don't. Plus it's no less likely to break down with me at the wheel, really. Just don't want her having the stress and anxiety. Already taught her that cycling the ignition may kick it out of limp mode/cylinder shutdown, at least temporarily. Aaaaaaaarghhh! *2.5 hrs away
  13. @jd03 All mk1 Fabias have electrohydraulic PAS, so you don't have a steering pump driven by the engine. The pump is part of the module under the reservoir. This image may be useful to you:
  14. No, 12V supply from blue/red on loom connector, but fuel pump relay needs to be on, so at least ignition on, not sure if that's enough.. Yes resistance from 3-5 of sensor connector, with it unplugged from loom. TBH, any fault here would generate a fault code, I'm near certain.
  15. Here's the wiring: Z19 is the integrated heater in the sensor G39. Continuous 12V goes onto one end of it at sensor pin 5 (blue/red), PWM controlled ground connection from ECU pin 5 to sensor pin 3 (brown wire) to heat as required to get desired temperature. I seem to remember the little external resistor (rectangle between pins 1 and 2) is some sort of 'select on test' tuning thing fitted as it's tested in the sensor factory. Lives under that cover that fell off yours I think. Google will probably be able to tell you far more than I can about what the four thinner wires do. Some current is varied by the ECU to keep something static, and the oxygen content can be inferred from the size of that current, is about the extent of what I remember. Test instructions for heater resistance: - At ambient temperature the resistance of the heating element should be approx. 1...5 . The resistance increases considerably even if the temperature rises only slightly
  16. You're not wrong. I wish I understood a hell of a lot more about how all this stuff works, in detail. I can tell you the wiring details shortly, and some test info. Not sure there's much you can do beyond measuring heater resistance at ambient temperature (from memory of reading about it).
  17. Food for the 'Chuckle in your day' thread?
  18. There's a click together/pull apart connection just the engine-bay side of the firewall.
  19. Rear washer water feed, I think. Could go through same hole. Make sure you put a fuse near the battery for any added wire - current rating as per what the wire is rated at. Fire-risk otherwise.
  20. Its super-hot environment ought to be sufficient to keep it functionally clean. No particular reason to replace as a pair, but I would hesitate to suggest replacement at all without much better evidence. You should see specific fault codes related to misbehaviours, and having just falsely thought I'd fixed one of our cars by doing just this, I am extra-wary. Expensive things too, usually.
  21. I think actually sep, these wideband sensors start doing their job within a very few seconds of start-up (that's what my logging suggests anyhow). The second sensor, after both cats, can compensate for duff/non-existent info from the first one, so will try to keep things on the straight and narrow as much as it can, which won't be enough for long in the complete absence of input from the first. After getting the lambda connection to stay put, try running it without the cover/air filter fitted and see if symptoms change, there's a common fault that leads to the engine only being fed pre-heated air, which isn't good at this time of the year. Is the weather quite hot where you are Martin?
  22. I wonder...I've always assumed that the misfires that go with exhaust valve trouble are due to gas leakage during the combustion event, (why) would that cause misfiring?. But another possibility that's only just occurred to me is that the valve(s) is/aren't actually leaking much at all, but is staying so hot due to damage or just poor seating and consequent poor heat-conduction path into cylinder head; so it triggers pre-ignition?? Is that what really happens? Seems a bit 'out there' to me, but I have very little knowledge of the details of combustion cycles, and what goes wrong with them.
