Seasider
Everything posted by Seasider
  1. But if I remember correctly, the instruction manual says it does not detect slow punctures.
  2. The TPMS operates when there is a sudden deflation of a tyre compared with other tyres, so it doesn't monitor slow punctures, for instance, although it will spot the difference once the difference between the tyre with the slow puncture and the other three is noticeable. The system isn't foolproof, however. For example, I have had a cuple of false alarms which seem to be related to uneven road surfaces, If this happens a number of times, ask the dealer to check the TPMS sensors settings. Interesting about that little rattle as that appeared on my 2020 Fabia recently with 20,000 plus miles on the clock. Intermittent and doesn't last long before disappearing.
  3. I have a stowage box under each of the front seats of my 2020 SEL, but they slide out from the front of the not the back. They don't hold much either, certainly less than the similar layout on my 2011 Fabia.
  4. Presumably the oil thins as it warms up and it is the measurement at that temperature that's important. If you measure it cold, it may be below the m inimum mark and so if you then top it up it is too full when the engine is warm.
  5. Do other members get this message when trying to connect, and when they can finally connect, do they find any of their travel data missing from the period when they couldn't connect?
  6. I had an issue with my garage over where they were unwilling to recognise a couple pf problems so eventually I raised the matter with Skoda UK via online chat asnd this had the desired effect.
  7. The automatic start/stop usually only works for me when in town and I've never experienced it on a hill. I would have thought the immediate solution if the auto stop/start didn't start would be foot on brake and into P, ignition off and then with foot still on brake, restart. If this doesn't work, then handbrake on, into P, ignition off and then restart might do it. As to the cause, well.......
  8. In my experience with my 2020 Kamiq when a message about a software update appears you just tap on "Update software" when the car is stationary.
  9. Mine is a 2020 SEL with the 1 litre engine.
  10. I'm on my second car with DSG and I've always found that as I lift my foot off the brake pedal and gently press the accelerator the car begins to move and once it's moving it will continue to speed up without me pressing the accelerator further. The exception is when the engine is cold and so is revving higher and then the car will move off when I lift my foot off the brake pedal without me having to press the accelerator. If in those circumstances I also press the accelerator, then it does move off more quickly and may need checking by lifting off the accelerator and maybe even applying the brake.
  11. Ditto until recently when a faint light metallicy rattle/vibration appeared from the steering wheel console area. Some days there, some days not and always disappears in a few minutes, so for the moment just waiting to see if it goes away.
  12. Me too. I wasn't happy with Lane Assist initially but either I have adjusted to it or it has adjusted to me or both. Certainly, I find that if you are gripping the wheel, then the tug is harder, but then you shouldn't be gripping the wheel. I found, too, that when I had a wheel alignment check done after clouting a kerb to avoid a heavy lorry that had decided to drive on my side of the road and the wheel aligner (not a Skoda dealer) actually misaligned the wheels, then Lane Assist became more violent.
  13. Try a hard reset by pressing the on/off icon on the screen housing for 2-3 seconds.
  14. For some years I was a volunteer photographer with the local fire brigade and visited a retained station on the edge of the moors which, at that time, had the only 4x4 appliance in the brigade which had been transferred there from elsewhere. The "station" itself was basically a large garage and when the machine was moved outside for me to photograph I commented on the narrow clearance between it and the top of the door frame, a matter of millimetres. The driver then pointed out to me that the apppliance's tyres were half worn and that when new ones were fitted it would be impossible to get it inside, so there would be no problem about getting it out!
  15. Job done in aboyt 15 minutes by my dealer while the car was in for another job.
  16. I went for the standard wheels then, so 16 inch.
  17. That must have been a very short standard item as when I bought my present SEL in 2020 they were an option.
  18. I've found the Skoda satnav routes the same as the RAC and AA online ones.
  19. I've found with the DSG that about town it sometimes tends to hold onto lower gears longer than necessary. To deal with this, I switch to manual, although sometimes just switching to manual and then back to drive causes the DSG to hold the higher gear. As regards using D, I've found that you can "coast" on the level, down hill and up hill. Indeed, on occasions I've had to brake the car when going up hill in a stream of traffic at a steady speed when the engine has switched to D. Going downhill, I tend to switch to manual and use the brakes to control speed rather than braking while using DSG and causing it to select far lower gears than necessary, it improves economy no end.
  20. I think page 93 comes under D for Driver Assist
  21. It's your extra height that does it. As I've said in another post, I use a Tempur seat cushion which helps with the problem. Maybe the MC seating is different to the SEL.
  22. Ah, two inches taller than I am and it would certainly help. I've solved the seat height problem after a fashion by a Tempur seat cushion.
  23. I had DSG on my Fabia and had no problems in 90,000 miles.
  24. I had a Fabia for 90,000 miles with no problems with seat height and parking. The Fabia scuttle line was lower than the Kamiq's, hence the problem with the Kamiq.
