Everything posted by skomaz
You do realise Bosch and Varta batteries are the same and made in the same factory don't you?
the truth about electric cars
I'm guessing the extra 2ft is with the load bed tailgate down? Either way as others have said it's stupidly heavy and a stupid childish design. I'd be embarrassed to be associated with it in any way to be honest... Be that in relation to its design and engineering or just driving it.
- Heated Rear Screen Elements not all working
Boot not opening
sounds like a bit of lubrication is in order...
Car Park Fires, Transporters / Ships, any fires, any EV,s involved or not thread, were they the cause just there and so made fighting the fire harder.
That's fair... To be fair...🤣
To be fair to the others it was @lol-lolthat started the qualification ****ing contest from what I can make out...
Fob
Might be worth trying some of these variations as it definitely sounds like the fob has lost sybc
Fob
It may just be a case of resyncing the fobs. The instructions should be in the manual
H7 bulbs for projector headlights on mark 2 fabia?
If it's a projector light it probably has a single H7 bulb with a shutter in front of it that screens off the full beam when on dipped beam. Chances are you may be able to upgrade to a H7 hid burner like many did in mk2 Octavias
Boot lid holding and leaking water
The wiper arm seal was the cause of a similar issue on my Kodiaq - took some tracing but the some windscreen sealant underneath the wiper arm seal and the glass sorted it.
Skoda Superb Elegance 2015 Tailgate lock problem
I believe it should just pull upwards as it's on clips but not 100% certain
That striker plate is usually held in by two bolts / screws - one at either side of the pin - that are covered by the trim around the tailgate - you'll need to remove the trim to loosen them re-align it.
Octavia Scout 2015 - vibration at high speed and juddering on acceleration, when heavily loaded
I started to notice mine about 70k miles but it wasn't bad until about 90k. Fine under normal driving but bad when loaded or on the motorway in top at about 2300 rpm.
Can't find factory OEM tires?
They tend to fit whatever is cheapest for them in the right size. Do your own research and you'll probably be able to get a much better tyre than the original fitment ones
I'd guess rear propshaft coupling as well based on my experience with a Mk2 4x4 which was similar - what's the mileage on the car
Wheel spin
Oops.. Apologies I must have misread
Wheel spin
Location location location @J.R.... By my reckoning we probably had more than 14 days in the last two years where I live or if not certainly in the last three years. And by 'proper winter' I'm counting unploughed roads with pukka lying snow... Not those light dustings that seem to bring havoc to those in the South East...
Photography Thread
He he - love it - M1 J34!!!
Rear wiper gasket
I had similar and water pooling on the rubber boot seal. From what I could tell the water was getting in between the rubber seal and the glass rather than the rubber seal and the wiper shaft. This was backed up by the fact that the hole in the glass could be felt just underneath but very close to the edge of the rubber seal. I managed to gently pry the rubber seal up slightly and work some windscreen sealant under it. No more leaks...
Roomster 2012. Here's a repaired turbo assembly. Is this a Skoda repair???
OE is welded but not like that... It's neatly brazed down the sides. As far as I can see from the photo the end of the plate the rod is welded to is bent which may be causing the problem.
Sounds like an asthmatic Darth Vader is behind my dash.......
How's your A/C? That sounds like a case of low refrigerant level to me.
Anyone else ordered a new Kodiaq?
Thanks @ColinD
London Air Ambulance Octy 245's
From memory the non scout 4x4 suspension is the same as the scout - based on ours that had the rough road package. The only difference was is tyre size that gave a slightly higher ride height.
No oil pressure shown via OBD socket ?
Yours must be newer MX5 than mine then .. the older models got a pukka sensor.
Coolant temp on up hill?
Probably more likely to be a sticking shroud in the water pump.
