Everything posted by skomaz
What's your quick interior clean methods?!
If your going that far... Leaf blower??
Photography Thread
Bempton cliffs is amazing isn't it... I e never seen so many birds in one place. Was there any sign of the Albatross?
For the interior you can get 'long fibre' microfibre cloths that when wet do a great job of lifting dust and dirt, even out of books and crannies.
Photography Thread
We used to get the woodpeckers in our garden at the old house and did occasionally see a few here at the current one, until they built a 70 bed care home on the greenspace just up from us - which wiped out the majority of the local wildlife (bats, birds, badgers, foxes etc.)
the truth about electric cars
It's all just a bit soul less though isn't it...
New Elroq - Just arrived at Dealers! Tips?
Giti is the trademark of GT Radial tyres as I understand it - Singapore based and manufactured but German / European design and tech. They supply OE to VAG and Stellantis. Mid range brand but usually with better than mid-range reviews. Which version are they?
Which all season tyre?
Oops... Hadn't realised it was that old 🤣
Looks like they are a Singapore based tyre manufacturer... Which would tally with the car being made in Thailand.
Moved from a Dacia to a Kamiq & comparing 3 cyl engines
Can I suggest the OP checks that they don't have other issues like dragging brakes - as my understanding from friends with a 1,0 TSI in a Kamiq is that it's more than capable of lifting it's skirts and getting a wriggle on.
Faded Black Trim
What did you wash it with to get it like that? Looks like something very abrasive wa used
Vibration from rear end
My understanding is that it should be possible to replace it in-situ without removing the propshaft. Space is tight but I've seen comments that there is enough movement in the parts available to allow the coupling to be removed and refitted.
I'd still suggest it's the flexible rubber joints / donuts in the propshaft that are failing. They can look fine but the outer ring can come loose and unbalanced and the rubber will be affected by temperature and could 'soften' slightly after a drive which might tie in with your observations that things change after a short drive, or on a cold start. They are available separately from the propshaft at about £100 so would have probably been cheaper to try than everything else you've doe so far.
Who's at fault?
I'd suggest it's the Merc's fault for not looking but, it being a private car park, where 'normal' rules don't apply I'd expect their insurance to push for 50/50. This is based on previous experience where someone on a petrol station forecourt did something similar to us many many years ago trying to queue jump to a different pump that had just been vacated.
Propshaft bearing
When the metal / rubber coupling goes it's generally a loud low droning noise coming from the rear of the car that increases with load and is louder in higher gears - so under load at just over 70mph and 2300 RPM or thereabouts in top seems to be when it is at its worst. I think some have also experienced the metal 'ring' coming oose from the rest and moving that could be a more metallic grating type sound.
Is Dacia the new Skoda?
Cat N... Avoid IMHO. It's an economic write off so repaired and may be fine but will probably suffer from increased insurance costs and is it worth the risk?
Interestingly when I started work a LONG time ago at Dowty in Cheltenham I was put up in a B&B at John and Betty Cleeveley's house... John being the founder of Cleevely Motors and who's sons took over the business and subsequently also started Cleeveley EV's.
Have to say I keep reading this thread every now and then and have visions of Heath Robinson arrangements for batteries and solar panels at @lol-lol 's house and him running around morning and night like Scrooge unplugging and plugging in all his electrical appliances to his batteries and panels...
Isn't that a re-badged Mitsubishi L200?
I have a wet belt engine!!
For info thier engines have wet CAMBELTS. Your doesn't have a wet cambelt, as I mentioned above.
It's not a wet belt in the traditional sense of it being a wet cambelt which is an issue. The 'wet' belt in your engine is a small belt separate to the cambelt in the sump that drives an oil pump. There have been no reports of issues with it over many years of use
Skoda Octavia Scout 2015 TDi 148bph build - whine gets worse at higher speed.
That does sound like it ticks all the boxes for the propshaft coupling... In terms of driving it - yes you should be OK - the one on our Octavia II 4x4 TDi started to go at about 75,000 miles and then got progressively worse and louder but it continued to 'work' (albeit noisily) until we had about 113,000 miles on the clock at which point we moved it on and bought our Kodiaq.
Does it occur at a specific rev range / speed? and does it appear to come from underneath / towards the rear of the car. If so and it's occurring at about 75moh or 2300 ish revs and is worse in higher gears and your mileage is anything above / around about 70,000 miles then I'd suspect it is probably the rear guibo (doughnut) flexible coupling on the propshaft just in front of the haldex unit that is worn and getting out of balance. Octavia 5e5 2.0 TDI 4x4 Propshaft coupling - 150 hp Diesel 110 kW 2012 - 2020 CKFC ▷ AUTODOC
That's an additional cost but again isn't answering my question... So again... what areas of our lives we have looked at more closely as a result of the war in Iran and why and what transport will be different because of it in the future. If you don't know or can't answer just say... But then also stop making brash broad brush statements about fundamental changes in transport that isnt going to happen... After all is finished we'll still import goods by boat and plane, move them by train and lorry and travel by car, train,bus, bike and legs etc.
No not missed that news. You didn't answer my questions though... I asked you to clarify what areas of our lives we have looked at more closely as a result of the in Iran and why and what transport will be different because of it in the future. You response above is just deflection and whataboutery...
I did know that but it's not really a full blown Gulf War is it... It's Trump and Netanyahu being aresholes. And yes fuel prices are high at the moment but I was wanting an explanation as to what the long term knock on effects would be. I can't see it making such huge changes as we're implied.
