DIY Guide: The 'elephant hose CCV (catch-can) mod'
oh yeah, this tank has got a drain plug in the base too. use a 12mm open ended spanner to undo it.
  • Replies 393
  • Views 177.6k
  • I bought the same setup, but found that the tank contained zero filtering material, so the catch can wasn't exactly catching much and because the vent was under the bonnet, the cabin always used to sm
  • Well, let's just say that he's the king of modding Fabias......
  • Thanks Ross - you're quite right of course - but I wanted to avoid any hot air at all coming into the intake.
Thats brilliant, think it would fit with a pd160 ;)
Yeah, I think it would work with a PD160, need to find a cheap one!! : )
I used self tappers to fit it to the intake initially, but there seemed to be too much vibration which I wasn't happe about, so rummaged around and found those bolts, not aesthetically pleasing, but with wide washers and nuts it seems quite secure.
Joel, Like the simplicity of your breather/filter set-up.
On my old polo, I just used a breather on the rocker cover, and it used to stink under the bonnet.
I used this catch can set-up on the Clio, and it worked well, as with the K&N induction kit, the breather pipe went back into the intake pipe, but vapours used to waft out of the cone filter, and used to stink again!! This type of set-up sorted that, and no more oil gunk in the filter, or bad oil smells.
Edited by jonnyvrs
added text
Here's my 1st run at getting the layout and the connectors right on a pd130 Octavia.
Comments Please
22954.attach
22955.attach
22956.attach
22957.attach
22958.attach
Nice filter position.
Did your can come with a bracket?
I used the original 90° pipe for my coupling, and cut the ends. then reused the fabric sleeve just as a finisher on the hose ends.
It was a bit of a mission fitting a reinforced PVC hose into a hard plastic coupling pipe of the same diameter. I had to slice along the hose, then dip it in boiling water to soften it, and gradually work it inside and out the other end, then I just cut across the pipe to get rid of the sliced area. I was pleased with the end result though.
could you not have just removed the original pipework and slid the new hose onto the crank case vent and secured it with a jubliee clip?
Is this advisable to do on a car still half way through its warranty period?
those catch cans are a nice job........but make sure actual pipe going into catchcan is not to narrow....mine looked wide enough on outside but the final diameter was quite narrow...which could cause back pressure......i felt i had to widen it......drill it and stick to 3/4 copper inserts instead with adhesive...
not using in present car though...just going to atmosphere
Wouldn,t really advise that mate on yours.
It wont do any harm not too.
Just keep the original pipework and when it comes time to take it in just swap them back over. No one will ever know
Yes, Mine came with all but the oil hose and the filter and I popped down to Pirtek to get some offcuts of hose etc to make up the joints for the crackcase.
Forge Motorsport | Alloy Fabrication
Your's looks very neat and tidy
I have run this mod without and now with a catch can.
Without a catch can, the car steamed heavily, especially when the ambient temperatures drop, in the summer it is nowhere near as bad. This was to the stage, where at traffic lights etc the steam was coming up from underneath the car and misting the windows. Other road users were flashing to point this out. I could not be doing with this, so i fabricted and fitted a catch tank.
With the catch can, the car feels to run better IMHO, does not steam and in the last 2 months i have not collected any oil in the can.
The car definitely seems to run better with this mod and the intake pipe looks to stay much cleaner than before but i personally would recommend a catch tank.
Alex
Alex
Steam?? What does your car run on - water?
All mines does is drip a little oil
Unfortunately not, the fixed vent point on the rocker cover was too big to slide the hose over, and the inlet joint was waaaaay to big, as the hose would have gone inside it. The pvc hose cost me £3 for 1.5m from hosequip.com. I was trying to think of ways to do it which didn't invole me chasing around for couplings and multiple step up/step down sizes of hose. I was pleased with the way it fitted. not exactly OEM, but at least the hose fixings were!!!
The part number for the 90° elbow vent pipe is: 038 103 493 M. Cost is about £10. Just thought, I could have spent that amount trying to find the right size couplings, so prob not that much lost cos I cut it.
So the hose that came with the catch can was too small?
OK Oil Vapour/steam whatever you want to call it. Both mine and my mates did exactly the same
alex have you venteed it to the air from the catch can or back into the inlet?
Well the catch can was used on my Clio, so the can inlet/outlet and hoses were matched to the breather pipe on that engine, which was 12mm diameter, so 12mm internal hose diameter IIRC.
The fabric sleeves shown in my photo were once one sleeve covering the 90° elbow. They are not needed, just thought it might make a better 'finish'.
I can takes some more pics and mail them to you if you want or pm me or something! :)
Ah ok, the one I've ordered is 15mm I think
I've vented it back into the inlet, i find the car runs better this way
Have you all filled your catch tanks with anything? I've read that some are filled with wire wool type stuff
Anyone tried this mod on PD170?
Kind regards
The tank that I bought comes with a mesh filter 3/4 of the way up the tank
Hmm mine is just empty
Filled it up with some steel wool pan scourers inside the end of a pair of tights haha
