My Furby has new suspension
Eibach -30mm springs (TDI ones, not vRS) and Koni adjustables
First impressions - the ride height is improved but there is still quite a gap - I suspect it will take a while to settle
Body roll - hurray - cured - no more sea-sickness
Ride - firmer, but strangely better - rides uneven surfaces very well. Seems a bit choppy at high speed on poor roads - might have a play with the Koni settings
Overall it feels like a hot hatch now, not slammed or ridiculously stiff, just sporty :thumbup:
I'll post a few pics once its settled in
  • Replies 59
  • Views 5.5k
Nice one! Now go and enjoy. :D
Springs were
How much for fitting?
How is the ride height? You say its still a little high, but is it even front to rear? Mine took a little while to settle at the front.
Glad your happy with the ride though. Give it a little while then have a play with the settings on the Koni dampers.
Pics please :)
Mate who works at a garage did it for a tenners worth of beer :thumbup:
IMO not a DIY job - the front shocks need a lot of force to seperate from the thingeybob near the brakes
It took them 2 hours
How is the ride height? You say its still a little high' date=' but is it even front to rear? Mine took a little while to settle at the front.
Pics please :)[/quote']
Front vs rear is fine - very level
Front feels a bit softer than the rear, even though they are all on softest settings - I'm going to stiffen the fronts up a bit
Thats what ive done, might tweak the backs up just a bit when I do the rear brakes.
But if I were you id let it all bed in before adjusting.
YOUR ALL EVIL!!!!
i need suspension... and remap :o
Anymore pics fom earlier in the day Colin?
i do.. but they aer rubbish quality due to sonyericsson rubisshy fone... cant see the hight difference :rofl:
1679.attach
YOUR ALL EVIL!!!!
Yes Ok Colin you've got some nice wheels (which I haven't got) do you have to post that pic everywhere. At least post different pics :D
Must stop myself from going to halfrauds for that 20% off deal.
Dam you have posted some different pics.
I cant be @rsed to upload the others and blank out the plate..... will take some more after ive cleaned her tomorra :D
EDIT.. just for you: ;)
Colin, all you need now is mobtob's suspension and job done.
Would the Konis be good enough to handle the vRS eibach springs that are allegedly much harder?
Isn't he nice :D
Can't wait till I get my eibach kit (vRS springs and dampers) now.
Looking good Colin
Got some bricks if you need em :)
Well they have been on a couple of days now;
A lot of my commute is on very poor country roads, and the car is now miles better - more comfortable :D :eek: , much better cornering ability, more planted as I think Ross said before.
I have a small issue with the front end - feels a bit too bouncy, especially on smooth roads with large dips, but I'm going to leave it a while before I tweak it. Hopefully stiffening the front shocks will cure it
Ride height - close up there is still quite a gap in the arches, but stand back and the car is more squat, very nice. From inside the car it feels a lot lower - very odd :confused:
Hopefully I'll be able to post pics tonight
I found the front end a little bouncy at first, half a turn on the front top adjusters and it was all in check.
Funny you should say that, thats what I did this evening, and after a quick drive it seems much better :D
Its good to hear that the ride does not suffer with the upgrade, I will likely be looking to upgrade this in the future, at least I will if I intend to remap (if not I likely wouldnt bother), and I did think that the ride would suffer with a suspension upgrade.
Yeah I was a bit worried about ride quality having lowered cars before and had fillings falling out, but the quality of the kit (especially the Konis' damping) is superb - but do bear in mind I have the TDI springs, not the vRS ones - I believe the vRS ones are a fair bit harsher :confused:
Well even if the vRS springs are harsher, it sounds like the TDI ones might be a pretty good compromise on ride / handling.
