What did you do to your Skoda today?
Booked into skoda for headlamp condensation issue (should be covered under warranty?).
In celebration of your purchase, you could join Freedom, then amend your slightly confusing username..... :)
Anyway......
As it's an 09 it won't be under the original manufacturer warranty, unless you mean whether it's covered under any warranty that was given from where you bought it?
To be honest I wouldn't bother taking it in - I'd just remove the headlamp units and bring them into the house overnight. Open up the rear covers and allow them to warm up and get rid of any moisture. Then refit the back covers and make sure they're on properly.
Some condensation is within spec though, as the units aren't totally vacuum sealed.
  • Replies 7k
  • Views 513.8k
  • Picked up the new VRS: 2013 Fabia VRS by Graeme_Smith, on Flickr
  • Popped to the garage at lunchtime to swap coolant temp sensor. I don't think it's the problem but it can't hurt. Going to swap O2 sensor later for the spare I have. Went well, all sorted in 5 mins. T
  • modified the cup holder     It's now a hobnob holder
Gave it a well needed wash wax and rainex. Topped up with oil and coolant as i have a small coolant leak :/
Sent from my GT-I8190 using Tapatalk
Anyway......
haha I'm starting to enjoy the little digs at me now and then :)! Have been contemplating the freedom, now that I've got another vRS.
Yeh I was referring to the warranty given with the car mate. How difficult is that to do then? Is it literally just trapped moisture under the headlamp or something more technical than that? I'm going to my local independent VAG specialist on wednesday anyway, so maybe I should just ask them to look at it for me.
Just take them out and put them in a warm space overnight
Job done
You're not the one who gets PMs and contact from people asking me what new Skoda I've bought!!!!!!!!!!!!!!
Scraped the ice off the windows and put my sticker in the back window, it was too dark to take a photo of it when I did it so I took one after work this afternoon instead:
Got 2 kumho ku39s fitted. Feels good to have front end.grip again. Also fitted some osram nightbreaker extremes. Can actually see my beam pattern on the road now. Never realised just how bad my previous ones were getting :lol:
Sent from my GT-I9000 using Tapatalk 2
Left her with the garage tonight for the annual MOT tomorrow.
Slowly turning my silver Octavia into a black one. Nearly 6 months since tesco cleaned it. If my 21 year old self could see me now, he would be very disappointed  :think:
:o  :no:  :x
Holy cow! Get yourself into the Car Care section and guilt yourself into getting that sorted!
Oh, and do it yourself - rather than some random with a dirty sponge in Tesco's carpark :thumbup:
:o  :no:  :x
It's having the time to do it these days, either doing house work, sleeping or looking after the children so the car suffers, well the outside does. I've got some time off soon so maybe I can dedicate half a day to making a good job of it
Make it an extension of the house work; job done :)
I know the feeling though....
Put it into the workshop for an intermittent fault with an injector.
Not today but switched over to the high torque map of my Faboka remap!
it appears the fault on my superb is the fuel pump giving up, which is sending everthing up in the air including my injectors me thinks its gona be an expensive one.
I debated thrashing mine with a big hammer after fitting a milltek 3inch downpipe and 2.5inch stainless cat back system few hundred mile later 3rd 4th n 5th gear im getting clutch slip at 3 - 3.5k rpm dunno if this is common with the extra ponies its gained ? P.s its had rtecb stage 1 map for last 2 year and been fine
I'd get the map adjusted, to take into account the downpipe especially.
But with an older clutch it might be nearing end of life, then with more power, beyond Stage 1 an uprated clutch tends to become more of a necessity.
But drove fine for few hundred mile definitely had more power so wondering if the extra power as just finished it off as its done 137k and loads of history with it but no receipts to suggest clutch or flywheel as been replaced in past
Im only staying stage 1 mate I bought the car already mappedb
Sure, your map's at Stage 1, but with the addition of the downpipe you've changed the spec from which the car was mapped with. As you've noticed the car will have access to more performance, with the better downpipe. Plus you'll need the map adjusting to properly take advantage of the better downpipe anyway.
So get the map adjusted and a new clutch fitted, preferably uprated. And if it's on the original clutch it's done pretty well anyway :)
Any recommendations on clutch ? Im going towards g60 flywheel vr6 clutch conversion ? Gonna try clutch and if still not right a trip down to see nikki at rtech will be on the cards
I think that's quite sensible and seems a good option for the Mk1 boys :)
Maybe put a thread up in that section and check?
Thanks for the advice wardy much appreciated
Copy cat  ;)
Gave the 18" Neptunes a rough clean in readiness for loading them in the car to take to the wheel refurbishers tomorrow
Watch this space!!
Guest
