So how fast is an AMD'd Fabia ? This fast
One of the guys i work with saw me watching that from over my shoulder, and he said "what the hell is that in?" so i told him, and said it was wet and slight wheelspin. I dont think he believed me :D
:rofl:
  • Replies 61
  • Views 6.5k
Diesel Power Eh ! :D
Did you use full throttle in 1st and 2nd?
i cant due to wheelspin :o
Err Yeh and it spun like a mo fo even with traction on.
Isn't the light on the dash mean the ASR is off?
Yep, but I suspect Ivan did a few runs with t/c on and off to find out which was fastest ;):D
Chris
Yep' date=' but I suspect Ivan did a few runs with t/c on and off to find out which was fastest ;):D
Chris[/quote']
Yerr I did it makes it about .5 - 1 second slower but it still spun up :eek:
Time for some Eibachs and some bigger tyres to maximise traction ;)
Chris
Chris
As highlighted in my thread somewhere.. youll actually loose a lot of performance with bigger wheels! i estimate that my kahns were a extra 5kg each over std wheels.. which blunted performance quite dramatically. based on the theory that every kg of unsprung weight is worth 2kg... so thats equivalent to 40bhp :eek:
Yep and the fact that a large wheel will require a bigger turning force in the first place. Decent tyres are whats needed TBH as I have the standard solid plastic tread ones on there :rofl:
Yep, but not an issue if you get bigger (ie wider) *tyres* on the standard wheels ;):D
You could argue the wider tyres could cause more friction though ;)
More traction ;) At the moment you're wasting energy generated by the wheels spinning as friction (heat) anyway ;):rofl:
Btw, forgot to ask, are you seeing an increase in fuel economy with your remap? ;):D
Chris
More traction ;) At the moment you're wasting energy generated by the energy as friction (heat) anyway ;):rofl:
Btw' date=' forgot to ask, are you seeing an increase in fuel economy with your remap? ;):D
Chris[/quote']
Depends on how he uses the loud pedal :D
Well in that case No ;)
Is it faster than the wind though?
As fast as mine? :D
As fast as mine? :D
Has your belly recovered?
May be having belly trouble later :D
I got 6.9 on my G-Tech Performance Meter when my car had only done c.1000 miles
I would trust AP22's etc not "stopwatch and vid" for accurate timings, true start of timing on movement and true 60mph when timing ended.
Ivan fancy lending my AP22 :D
Yep, AP22 / G-Tech / VBox for accurate timings.
you got a ap22?
can i borrow it? :D
And you lot wonder why your clutches are dying...lol.
Agreed Ross and the 0-60 was a once of to show the remapped Fabia's potential.
