Oil advice and recommendations here!!
  • Sponsor
Agreed, its only a small amount and will be fine.
Guy
  • Replies 301
  • Views 67k
  • I have read that the Fabia VRS requires 4.3 litres of VW 505.01 oil. Is there a fully synthetic Oil that comes in 5 Litre cans, cos I don't really want to buy 2x4 litres
Can you please confirm that the Fuchs Titan GT1 LLlll is fine to use with my new Octy 2.0 TDi 140 PD DSG L&K please :)
And any other recommendations also gratefully received :thumbup:
  • Sponsor
Yep its fine, you can find other VW507.00 oils here VW - Engine Oil - 507.00
Guy.
Many thanks Guy - just out of interest what is the difference between that and the Fuchs Pro-C3 which is
  • Sponsor
Other than approvals not much!
Guy
Cheers!
What oil would you recommend for use in a 2001 Octavia 1.9 90bhp tdi? 75k on the clock
Mark
  • Sponsor
Is it on the fixed or variable service schedule?
Guy
At moment I am changing every 6k miles. Prefere to do it that way.
  • Sponsor
I would go for a 5w-40 that meets the VW505.01 spec.
Any of these are suitable VW - Engine Oil - 505.01
Guy
Guy,
Welcome to Briskoda. I'm an existing customer (previously owned a S1 Elise and currently own a GC8 Impreza and an Octavia II 1.9Tdi PD 105).
Looking on your website I see you are selling Fuchs Supersyn LL Plus 0W30 at a discounted price. Would this oil be a better bet than the newer (but slightly more costly) Fuchs GT1 Longlife 5W30. The oil is for my Octavia, however, in a few months time I will be taking delivery of a new Superb II equipped with the same 1.9Tdi PD 105 engine as in my Octy.
I travel 30k miles per year, mostly on motorways.
The Octy is on a variable servicing regime, normally requiring a service every 18-19,000 miles.
  • Sponsor
Quality wise it makes no odds to be honest so if the LL Plus is on offer go for it.
Guy
Guy,
you have to be careful if the car is still under warranty
0w-30 probably will not be 504.00 507.00 approved as its the older type of variable oil
every vag engine that was using variable 0w-30 LL2 has switched to 5w-30 504.00 507.00 apart from a couple of engines like v10 diesel
it's probably on offer because eveyone is buying ll3 oil
you have to use the 5w-30 504.00 507.00 type in both the octavia and the superb
i'm presuming that the oct is still under warranty
The Fuchs TITAN SUPERSYN LL PLUS 0W-30 is VW 506.01 spec, which as Guy confirmed is fine for variable service intervals in a PD Superb.
Does VW507/VW506.1 offer better protection than the VW505.1 oil?
If cost is not an object is there then an advantage to using this on fixed services such as reduced engine wear?
  • Sponsor
I wouldnt have said so, they are longlife oils so are designed to last longer, not protect better as such.
Guy
you'll have to check in your manual when you get the new superbII
i think it will almost certainly be 507.00 only as the 506.01 is now not used in the modern skoda engines
Edited by wonkydonkey
depends on what driving style you have mate
have a look at this link and decide what plan is best for you
Volkswagen Servicing Plans : Volkswagen UK
505.01 is for pd engines on fixed 10000 intervals
507.00 is for pd engines on variable or for the fixed 10000 interval pd engines with particle filters
Can you advise me what the OEM oil is please?
I can get oil sampling done for free and the more info I can give them on what they are sampling, the better the report is.
Engine is the latest 118kw 1.8T Octavia
thanks
Shell is 100% first fill supplier to VW's most important engine plant in Salzgitter
https://www.volkswagen-media-services.com/medias_publish/ms/content/en/pressemitteilungen/2007/12/30/the_volkswagen_plant_in_salzgitter.standard.gid-oeffentlichkeit.html
dont know whether your engine was made there but there's a fair chance
best regards
Have 1.2 HTP 70 H/Back 7500 miles-am thinking about asking for an extra oil change in the Spring and changing from the current semi-synthetic to a full synthetic oil(at the dealer's).Which oil would be best?:confused:
Any fully synthetic that's 502.00 approved will be perfect
Motul VW specific 5w-40 is a good one
best regards
best regards
Many thanks!:thumbup:
hi,
I got a 2006 Fabia Classic 1.4 tdi pd, this is my first diesel and I'm not a car-person, I'm just another driver... A week ago, the flashing "Oil" warning appeared on my speedometer display, then I kind of panicked and went to the nearest gas station, and the guy over there recommended me 10W-40 Shell Helix Plus Diesel. So I agreed (it was the most expensive oil in the shelf:
Edited by Arda
Hello,
It might be a simple question but can you help me find the right oil.
Car 2004 Mk1 VRS Octavia combi with 120k on clock.
Service interval QG1, oil spec VW50300.
I see from the table that I should be able to use Castrol 0w30 fully syn, but my local Skoda said should it be 5w30??
Please help!!
Best regards
Ant.
Edited by sandyland
