Oil advice and recommendations here!!
  • Sponsor
The passat will need an oil that meets the VW507.00 spec and these tend to be 5w-30. There are plenty to choose from here VW - Engine Oil - 507.00
It will be a bit over kill but the same oil would also be suitable for your SDI.
Guy.
  • Replies 301
  • Views 67k
  • I have read that the Fabia VRS requires 4.3 litres of VW 505.01 oil. Is there a fully synthetic Oil that comes in 5 Litre cans, cos I don't really want to buy 2x4 litres
Thanks Guy.
Having read a few guides i figured the Passat would want the VW507 since its so expensive.
Its 10W40 that i've been using for topping up the SDI as t uses about a litre between services. I got it in a 1L bottle foc from the mechanic that does my servicing. Given the prices i've been seeing for VW507 oils, i dont think he'll be giving me any free oil once i start taking him the Passat :(
Hello Mr Oilman sir.
What do you recommend for a 10 year old, 100k mile V6 Mondeo? Could you do a bulk pack (maybe a 20l drum) for a reasonable price? ;)
Tom.
Sorry, can I bump this one Mr Oilman sir?? :P
  • 4 weeks later...
Helllo
the gear box oil qty,how can i find for Fabia 1.4 MPI
Akos
  • Sponsor
2ltr according to my book:)
  • 4 weeks later...
Here is the product sheet for Mobil Synt S Special V. You will see that it is 5W-40 oil with VW505 01 approval. I cannot find any mention of a 5W-30 version of it. If you let me have more details of the Shell oil, I will look that up too.
here it is mate, from the Mobil uk web site
Mobil Syst S Special V 5W-30
enjoy
Thanks for that. I have added Mobil Syst S Special V 5W-30 to the list of 505 01 oils for the Fabia vRS. Interesting that it is the only 5W-30 oil on that list.
The Shell one is called Helix Diesel Plus VA 5w/30
it also comes as a 5w/40
cheers
Help....confused.
What oil should I using in my '53' reg Octy1.9TDi 90bhp?
I asked the garage I got it from (a Skoda Dealer) and they say the 15-40 Turbo Diesel oil would of been put in at last service, (its on 10,000 fixed servicing) showed me the bottle, it was red with red label, non branded. Will it be ok?
  • Sponsor
Depends, do you know if you have a PD Diesel engine fitted?
Guy
Guy
I'm sure its the non PD engine.
  • Sponsor
15w-40 will be a bit basic, usually they are simple mineral multigrades. Better choice would be for a 10w-40 semi synthetic or better still 5w-40 synthetic.
Guy.
Help....confused.
90bhp engine is not the PD engine
VW505.00 is the spec you need
it usuall comes as a 10w 40 or 5w 40 though
non branded oil tends to be non approved oil so worth checking
the older engines are not as oil critical as PD engines but they still need high quality oil in them to help em live longer.
Thanks, I was thinking it wasn't really the right stuff. I'll be checking with the garage if i take the car there for servicing...
Can you advise me what the OEM oil is please?
I can get oil sampling done for free and the more info I can give them on what they are sampling, the better the report is.
Engine is the latest 118kw 1.8T Octavia
thanks
  • Sponsor
Its probably a Fuchs oil, but I am afraid I do not know which one.
Guy
Oilman,
Would the castrol "edge" Turbo diesel oil i have be ok for the vRS. now i am not thinking replacement just if i ever need to top up ?
I plan to have it serviced at the required interval so its just as a backup really.
  • Sponsor
Yep the TD 5w-40 is the one to go for.
Guy.
Hi chaps, what grade of oil is recommended for a 2003 1.4 16v (100bhp) Fabia? I just want to keep a bottle for 'topping up' not for a complete oil change. Thanks for your help.
  • Sponsor
I would go for a 5w-40 synthetic, you could also use a 10w-40 semi synthetic.
Just stick to a quality brand.
Guy
Hi folks,
I am wondering if anyone knows if Duckhams Q (synthetic based) (API SL) 5W-30 oil is suitable for my 2001 110bhp TDI Octavia (130,000 miles) and my wifes Toyota Corolla 1.4 vvti petrol (80000 miles). I have always used a semi synthetic 10w-40 in both up to this but now I have some of the Duckhams i am wondering if is suitable for the cars with that mileage etc? Thanks in advance:thumbup:.
  • Sponsor
What VW specs does it meet?
Guy
Hi. My O2 has 57th km. In August during a long trip outside the country the yellow oil pressure appeared. I stopped on the highway and bought the best oil for diesel, that is the 5w-40 Shell Helix Ultra - fully synthetic. Only now I see that it's 505.00 instead of 505.01. I put around 300ml inside. My oil is Aral Tronic 431 (505.01). Should I now rush to the service and change the oil? I will go again for a 3200km trip, so some guys on other forum worried me 505.00 and 505.01 are not at all compatible and that means trouble. What should I do?
Personally, I'd just keep on driving.
300ml in a 4L sump wont make any difference at all.
