Footwell Lights
as u can c from the image posted earlier, even at that awkward angle, the front driver footwell is still lit up nicely.
but i prefer something more solid - hence why i'm going to pursue the hard plastic, next to the air vent holes.
i haven't driven the car since enabling it via vcds. but based on the maxidot settings, i believe it will remain on, at 30%, while driving with lights on.
otherwise, they operate like the standard interior lights, including dimming.
  • Replies 265
  • Views 79k
  • so i've finally finished wiring it all up - front & rears. thanks to all ur help - definitely made my task easier. for those buying the footwell lighting kit from boldsport, the wiring (routed v
  • alright.....things r looking positive now. thanks to RainbowFire, i removed the top storage compartment, and was able to see a clear path to route the wire across from the drivers side to the passeng
  • Just finished fitting mine, like JR RS said hardest part was removing trim and cutting holes The kit i got from ebay (VW Shanghai Parts) had no issues with length of wire, i went the route of JR RS's
Very nice, all you need is leds to look better.
Under seat, just put the wires between foam and metal sheet and give at front the slack enough needed when the seat is moved .
Well thanks to JR RS I've sprung for a pre-wired set from bold-sport.com. Fitting them to my poverty-spec O2 Ambiente from 2006 is going to be a challenge, but I'll find a way :)
surley if you just tap into the interior light wire they will work that way. no need to mess about with the maxidot.
Do you get the adjustment options in maxidot if you do this on a pre-fl?
i'll eventually need to wire up the passenger side. i had difficult sending the wire across from the driver's side to the passenger side through the back of the centre console, or behind the radio. removing those side carpet cover thingys r the sticky point for me now. they not budging despite my best efforts.
one day........
When I ran some wiring in, I removed the stereo, and used a straightened metal coat-hanger through a gap in the fusebox, straight through into the hole where the stereo sits. From there I ran (by hand) into the glove box.
Can't see that where you want to run the cable from/to being a huge amount different. You'll just take a slightly longer, but easier and quicker (and less swearing) route. ;)
But they will then only work when the doors are opened and you will not have the option of dimming them or having them on whilst driving at night.
Not to mention running the cable to the interior lights is probably harder than doing the job properly - as factory fitted.
Agreed, but what about having the correct convenience control module installed? Which MY did footwell lights first appear in the Octavia brochure?
I don´t think any Octavia was ever fitted with this.
It´s a copy of other models within the VW group, mainly the Golf
It's going to be interesting to see if my car (poverty spec 2006 O2) will show the footwell lights in the (retrofitted) maxidot...
but why would you want foot well lights on when driveing,
The only thing I can tell you is that onced on, you won´t want to turn them off
@vwdan1986 - i'm pretty sure its much much easier to connect the footwells OEM style, than it is to cut/splice into the interior lights wiring.
i didn't have to cut/splice/solder any wires. simply plug'n'play.
as i said earlier, its removing the trim that's tricky. but once u know how to remove it, its easy.
@RainbowFire - it was a pain in the a55 trying to get the columbus unit back in after installing my bluetooth unit. the additional quadlock connector made it so frustrating.
i eventually got it - hence my reluctance to remove it to send the wiring for the footwell behind it, and across to behind the glovebox.
i guess if i don't have any luck with the side carpets, i'll have to remove the columbus :(
Ah, I see. Could go a slightly different way then: Pop the top touch-box off instead. There's plenty of space to see the coat-hanger come through (enough space for me to get my hand in there to stick my CK7W Bluetooth control unit down), and enough to push the cable down the side of the glove-box to the passenger foot-well. The touch-box comes off easily enough and leaves the Columbus untouched :)
@RainbowFire - do u have any specific details with regards to removing the top touch-box (storage)?
i can't find any screws.
does it simply pop up?
No screws, just a three large, chunky trim-clips. I usually get a blunt instrument and lift the front first:
Once you've got it to this point, just pull it forward and clear of the dash. Disconnect the hazard lights (squeezy connector). Refit is reverse.
What you've got with the box removed is this:
Watching this one with interest, as I've got some OEM footwell lights somewhere!
Good tip about the storage box access, for cabling - additional advice would be to use a trim removal tool to pop the box up. I've seen people damage the soft trim underneath it by using a screwdriver or similar.
Ii no what your saying, i think im just getting abit to old to be getting under dash bords and under seats it realy dose my back in,
Edited by vwdan1986
I've just ordered the parts to fit to my 08 pre-FL estate, and have ordered some green W5W bulbs to match the green switch illumination. Hopefully will get this installed at the weekend -- interested to see if it appears in the retrofit maxidot.........
Mike
Lovely job Mike - I'll bring mine up once you've finished yours then! :p
Mike
No-one answered my question earlier on this thread, but if you get this linked in with your maxidot somehow, let us know fella. :)
Hopefully it'll add itself within the Lighting section on the pre-FL Maxidot, where Coming/Leaving Home lighting lives, etc.
Possibly, just waiting for someone to find out... :)
Yep, someone has to be the first!
To be fair, there's probably quite a few out there who'll be happy with it even if it isn't linked to maxidot cos they'll just think it's swish, regardless, so I don't think it'll be long. :)
I too am now watching this thread with interest.
