Footwell Lights
Agreed, but I'm just checking from the guys who've bought it that there's no issues with incorrect wire lengths or nonsense like that from our wacky Eastern companions. :)
  • Replies 265
  • Views 77.6k
  • so i've finally finished wiring it all up - front & rears. thanks to all ur help - definitely made my task easier. for those buying the footwell lighting kit from boldsport, the wiring (routed v
  • alright.....things r looking positive now. thanks to RainbowFire, i removed the top storage compartment, and was able to see a clear path to route the wire across from the drivers side to the passeng
  • Just finished fitting mine, like JR RS said hardest part was removing trim and cutting holes The kit i got from ebay (VW Shanghai Parts) had no issues with length of wire, i went the route of JR RS's
i had to "lengthen/extend the wiring" - probably cause of the path i took for the rear footwells, and i wanted to leave plenty of slack.
some pics here of my install.
i wired mine as so......
Edited by JR RS
Is yours the Shanghai kit then?
The kit i got from ebay (VW Shanghai Parts) had no issues with length of wire, i went the route of JR RS's Plan B above and they were long enough
Took a few pics with the phone will upload them shortly
Just have to wait till its dark now,
I also got a 12v to USB plug charger off the same ebay seller as the kids are always charging their android tablets in the car, so pics of that too to follow in a new thread :)
Dallan
Pics:
Kit
All the trim out
Routing the wires, its a little difficult as the connectors are already on
Front ones were straightforward
Passenger side finished
Testing before fitting last bit of trim on drivers side
On the pre-FL there is a lock bar on the connector, open then put in the wire and lock again, there is a similar bar to lock all the connectors in place also
Connector B Pin 7 on pre-FL
Edited by Dallan
Sweet. Good work fella. To be honest, from having removed all my interior carpetry when it got wet before, I'd be likely to just undo the four bolts for each seat to help route the wire thorough. Made it much easier when I had to do it all last time.
Looks like I'll be getting one, especially since yours is a pre-fl too so exactly the same as mine. Let us know how it went during the night when you tested it for real. ;)
Can you change the bulbs with these kits to led bulbs?
If the lights are the same as those in the boot (W5W) (which I suspect they are - the units look the same) then yes :)
All you need now are leds to look best instead of the yellowish colour
Was thinking of getting green bulbs :)
Will leds dim properly though? possibly they might flicker when not on? Only one way to find out
Yes the metal cover on the back comes off and there are w5w/501 bulbs in there
LEDs will dim. I've got some in the interior lights, still get the dimming when I lock the car in the dark :)
awesome :yes: still need to fit my boldsport kit
I've ordered the Ebay set as well, I am intending to remove the seats to install some ICE cabling so will get everything together and do it in one hit.
I retro fitted the footwell lights on my 8P A3 as well - nice mod.
Next up decide if I want to install the handle illumination in the doors whilst I have the door cards off.
Paul
nope.
i used the bold-sport kit.
I personally have single led bulb in white as is enough to illuminate the floor, reduced to 20% at night. I tried the green ones single but did not like it at the time, on these they were at 70% intensity. Yes canbus friendly unless if ticked off to not to be monitored via vcds.( no error will show on dash without canbus)
Edited by alberg
I have non canbus LED's in my interior lights and have had no warnings? If the footwell lights work in a similar way I can't see that they are monitored as we technically can see them not working unlike the exterior ones?
Hi
I've assembled footweel light (front only).
I've coded BCM module
LC 12,5
LC 20,0
Lights work Ok, but I have no menu on Maxidot.
Just after coding I had that menu "Footweel Lights" for 3 seconds - but it disappeared before my eyes.
I made coding again and again, but menu did not appear again.
My car Octavia II FL, BCM module 1K0937086G
Any idea what to do?
This might be a daft question, but how do you know which pin is number 50, are they numbered or do you have to count them?
Fitted mine today.
about 3 hours. Just need to get coding sorted now.
Coding sorted last night. Really pleased with these.
Thanks for the guides and link to buy items.
Did u use a bold sport kit? Still plucking up the courage for mine!
Took the plunge and ordered that chinese kit off ebay. Arrived yesterday, just gotta get round to fitting it. :)
cool, what method did you use? remove seats, run cables around edges?
