Show us your winter wheels
Am I the only one that thinks Winter Tyres are pointless?
In this thread, yes - that's highly likely to be the outcome.
  • Replies 630
  • Views 125.5k
  • Fitted my winters today - bbs rd 256 newly refurbished in audi "titanium". Gave it a quick wash too - looks ok?
  • How can anyone put steelies on ther vRS? It makes me sad :( My winterwheels
  • Think we may be drifting off-topic with this one - seeing as no winter wheels photos are being shown Can we agree to disagree and take it to a fresh post if we want to discuss wheel aesthetics?
Ahh, too many Wardy's, I was wondering why you were talking to yourself :giggle:
I do that sometimes, but in this case it's that same old problem.....
No...Just this post
Yes!   :moon:
Nokian WR G2 XL 205/60 R15 95H M+S, on 15" Skoda Avantgarda steels with Avantgarda wheel trims.
Tyres purchased from Pneus Online, currently £62.90 delivered. Steels/trims purchased from dealer (who also fitted the tyres to the steels and swapped over the summers/alloys, which now rest in my garage on a tyre tree  :thumbup: ).
AUDI A4 A6 16" ALLOY WHEEL AND TYRE 8D0601025C 7JX16H2 ET45 205/55/16
Hi.........Have a few options now & these were one of them...just wanted to confirm that these will fit ok...........thanks
5X112 PCD
7JX16”
ET45
Are a perfect fit, you may want to check inside you fuel filler cap that 205/55/16” is an approved size for the scout (it is for non scout Octavia / Superb, not sure about the scout)
Watch the following video and then see if you can explain why they are pointless:
Note the second half that shows benefit in cold and wet conditions, not snow.
(You can debate cost/benefit, but to suggest there is no advantage from fitting winter tyres is absurd.)
Edited by Ultrasonic
Check they are 112 and NOT 100 stud diameters
Have checked the filler cap and they are listed to fit both the 103 & 110kw. Also they are the correct pcd .......Thanks again for all your help.Just got to get them at a reasonable price now.
Here are my winters with old Audi A4 alloys in good nick from ebay at £78 and some new Kumho KW27 tyres. The centre caps should be the big saucer ones but as they're harder to find I used the small ones recommended but ChrisRS (thanks again).
Not the prettiest but do the job. Easy to clean not too shabby.
Edited by paddypaws
  Audi A4, A6, A3 Alloy wheels with Pirelli 210 Snowsport winter tyres 205/55 R16 91 H.
Tyres are with 3.5 mm/4mm tread.
        Managed to bag these for £190..(Not sure if these tyres are any good) but tyres look good for another season at least. Just need some wheel centre stickers now. The current plastic Audi centres look to have the metal Audi emblems fixed to them. Are people grinding them off, then attaching Skoda stickers ?
I've just been sticking with the Audi centres on my Winter wheels
They look pretty good I must admit.
I have both, gets you through everything
Agreed... :thumbup:
I've found some Golf alloys* with the correct spec for the Octavia II estate (6.5J 16" 112 ET50) : two questions
1. is the  wheel centrebore dimension OK (57.1)? (and can you fit a Skoda badge?)
2. can you use the existing wheel bolts?
many thanks
John
* http://www.myturbodiesel.com/1000q/wheels/16-vw-wheel-gallery-5x112.htm     VW bioline
Yes the centre bore is correct, badges will however not fit, you need to get creative to have Škoda badges on VW and Audi alloys.
To my knowledge ALL VAG alloys use the same bolts.
Many thanks, most helpful. BTW, I rang Michelin yesterday to ask about the recommended relationship between tyre width (e.g. 205) and rim size.  Somewhat to my surprise they said that a 205/55 tyre can be fitted to rims from 5.5" to 7.5", nominal being 6.5J.  So the nominal ratio is about 80% (rim/tyre).
205 55 16 is correct to maintain the same diameter as your summer wheels
Avon Ice Touring STs fitted to original elegance alloys (205 55 16) by mobile fitter. This is their third and final winter. I'll leave them on and see how the grip/wear is in the warmer 2014.
Original white worm inserts re-fitted. The replacements (half price outside warranty Skoda goodwill) are in the garage until spring.
IMG 7917
IMG 7919
Edited by Web Ferret
Not an Octavia, but I also own an Octy if that helps (parked on the drive behind the Superb :giggle: ), and the Superb forum is soooo quiet!
17" Audi TT alloys (£200 eBay) and 225/45 R17 Avon Ice Tourer ST's (£100/corner fitted).
My winters (rear in 1st pic) are identical in size and profile to my summers (front in 2nd pic) yet they seem tiny. Hopefully the suspension still needs to settle after being jacked up!
  • 4 weeks later...
How is the winter tyres going for everyone?
Temps are consistently high for this time of year !
