Dash Cams
Ok, so I've received my Mobius camera and have an intention of using this as a rear camera. I've wired a number plate reverse camera up to the boot light as a power supply before which seemed to work fine but I seem to be struggling with the Mobius doing the same.
Can anyone recommend a suitable wiring point in the boot space to hitchhike off (ignition live) - or will I need to run a wire from the fuse box?
  • Replies 704
  • Views 82.6k
  • It's funny. Before I found this site, I would never have dreamt of doing mods or even considered buying a dash cam! A bad influence you lot are!!
  • This picture should sum up what I got around to today and what element to this task went wrong after I returned from an extended test drive for a comparison video v the Blackvue.........     chrisw
  • Because you'll have a dead phone after a while from it constantly writing to the flash memory, unless you use a replaceable card.   Because you can leave the camera in the car when parked up to catc
Ran another feed from the fuse box. Quite a neat install and a lovely little camera. Might swap the mobius to the front and the dr32 to the rear.
Yea I would swap them, keep the better quality at the front  :thumbup:
I am tempted to run a line through to make a 12V socket inside the boot since Skoda refused to put one in the hatch.
only problem with the estate is that the rear one is permanently live
hahahahah bonus that has cheered me up having felt like I was ripped off! :D
The centre console one is too I believe.
Yea it is on mine, I don't tend to use it as I hate wires hanging about the place.
This is why I wired a USB in the top box
I hate them too, never once used mine!!!
chrisw880 made this pic to mock me after I told him what I did.......
1305475_10201969491988312_1685668353_n.j
Ooops!!
Does anyone know why the Mobius won't work with a usb hub? Its fine off my hard wired usb, but if I put a mini hub in the port first, it doesn't work. The thinking is to allow a phone to be charged off the usb as well as run the cam.
It seems odd as the hub is only a wiring splitter as far as I can tell.
Adam
May depend what amp input is required by camera and if the USB hub is lower or just splitting it down due to multi outputs.
I think there is more than enough current available. Also I was only drawing current with the cam with nothing else connected which is why I was surprised it didn't work.
I have a 12v to 2xUSB thing I use for company vehicles and it wont charge my phone, another one I have will and will charge my tablet too.
So its probably a quality thing with the hub then I guess. Thanks.
Adam
Weird as my Möbius has worked on a griffin dual USB and the el cheapo unit I got from China that gives 2 USB and 2 cigarette
The guide on the Mobius actually mentions not to use a non powered usb hub. Just can't see why really as it is just a simple connection.
Do you have a link to what you are trying to use? USB can be a mixture, some are just cable of transfer and then others can charge
I guess it will be down to power mate. My £3 Chinese one was a bargain by the sounds of it
Sorry it isn't working, could just be a PC only one compared to those that go in the cigarette lighter and split
Yeah pretty sure its not designed for a 5v DC supply boo.
Anyone able to send me or post up the instructions for this? Mine came without any!!! :(
Kit :)
Kit :)
Which one did you get?
The mobius one, cant even see where i can get into the Msetup.exe (found out about this on the RC forum) to see what the settings are!! Have it plugged into the USB to charge it but cant seem to see where to go from there!!
K:)
K:)
Here ya go all you need is on this page when in the program (with camera plugged in via USB) you can update the firmware (I did this first thing) the program will see if it's out of date and offer you the new one but to install it you need to save the new F/W file to the memory card and turn it on and it does it automatically and auto removes the file after complete but takes a few minutes. It's all in the English instructions.
http://www.mytempfiles.info/mobius/index.html
English manual .pdf
http://www.mytempfiles.info/mobius/MobiusManual.pdf
Software for camera .zip
http://www.mytempfiles.info/mobius/mSetup.zip
I would leave the settings alone as much as possible and change the little bits you want, you will need to invert the date/time if you are mounting it in a car and I would leave on the recording indicator otherwise no lights come on and you have no idea it's working unless you touch heat sink and smell burning flesh :D
