Shadows Entity's MK1 stage 2 + r32 setup
eventually but I want my number plate where it is still as not keen on it too one side
  • Replies 162
  • Views 24.2k
  • Shadows Entity
    Shadows Entity
    Pictures that Clive sent me when it was in progress         This is what massively delayed me getting my car yesterday....       Yes that is a horse box on it's side and a landrover
  • Shadows Entity
    Shadows Entity
    Got some new wheels thanks to vRSy which imo are millions better and nearly new so not all corroded like my old ones, tyres on them are insane as they're Falken road slicks feels like you could go rou
  • Shadows Entity
    Shadows Entity
    Got the car back yesterday.... doesn't even feel like the same car, Clive has made it into an animal. 5th Gear actually does something now, don't even have to drop down to overtake just a twitch on th
not really possible matey,the plate will cover any hole you make lol
i went for slight smaller mouth left the rub strip uncut
Flybikeslee left his plate in situ but drilled 4 or 5 holes behind it. Looked standard but on track etc still got the flow to the cooler with the plate removed
Extra pipes needed ordered got them from autosiliconehoses with 15% off use promo code ASHHOSE
did that at first then cut the whole recess for more flow. left bits either end for the plate still to mount to. painted black so it's hard to see.
420948_10151381031665072_1314291885_n.jp
576031_10151928316840072_1138461140_n.jp
picture before it was painted
fitting Black carpet and arm rest tomorrow and will take pictures including the black seats I've already put in
good good :thumbup: you fitted seats before carpet?? gonna have to start again :yes:
should have nice big tasty update soon
yea I did put seats in first but to be fair it takes 5 mins to get them out.... 4 bolts and a flat head screw driver and done
pictures tomorrow, managed to do it but it was dark...
picture before it was painted 32208_10150184613460072_4732248_n.jpg 169078_10150372253465072_7268703_n.jpg
Lee every time I see pics of your car I cry a bit !
So here's the pics of carpet change + seats + arm rest
Some may say the seats are a downgrade but I prefer them and they are actually comfier and lighter despite having air bags in them
Carpet was pretty clean anyway but I gave it a clean any way before I put it in as it's the only real chance to get to the bits that normally are hard to get too.
One thing I did do which makes it a lot easier to get in and less hassle is cut a line in the middle from were the convenience module is as there's a dash support bracket in the way and it doesn't adversely affect it as you can't see it and the carpet still sits fine... Also makes taking the white one out easier
Sunlight makes them look grey but they are black
Armrest in place
Is there much more lateral support? I *HATE* the vRS seats, me arse cains after a drive and when I throw it about, it's like I'm driving a park bench. Doesn't help I have a fat arse so am desperate for something better.
Also looking good :)
Edited by V8 Dave
Finally finished the FMIC and it actually works after a bit of testing and chopping and changing... so here's the pictures. Changes a bit throughout to the final set up.
Garage full of bits and tools although I ended up ordering more
already had fitted the fmic in terms of placement not plumbing in
got an ouchy
Bits off
BAM inlet
To fit charge pipe you have to use BAM fuel rail as you can see the old AUQ placed ontop goes directly out but BAM is shorter and goes down
In place but had to be rearranged
Charge pipe in place with my modified OEM bracket to support it and stop it rubbing fuel lines
Driver's side pipe work which ended up not clearing the bumper
Modified to clear
Another shot of the pipe, as you can see brake servo pipe isn't ideal but still waiting on pipe work to route it properly so just had to make it work
Modified throttle body pipe, problem is getting something wide enough, short enough with a dv outlet so this is what I came up with
Had to chop a bit off the corner of the battery tray to clear it but the battery still fits fine and the tray is in place properly
didn't take pictures of it all but it goes 90 degree from the throttle body then couples onto a map pipe adaptor then couples onto a long 2" 90 degree then onto the next picture
Final finished product
Went for a drive and at 6500 in 2nd it blew a pipe off... was the driver side small red coupler you can see in the picture above so replaced that with a longer one and tightened everything back up... took it for another drive got to the same rpm and none stop boost :) so I'm happy with that and finally got it done... Took me a while and the result was a very ****ed off GF.... least it's done now :)
Pipe for brake servo turned up today :)
well car was dropped off at Clives yesterday so let the magic begin :)
they were busy busy tearing it down when i arrived,gonna be good :yes:
yea Clive sent me pics got gear box and my front end off already
post em up then :rofl:
Can't until Monday as I'm not home, don't mind if Clive posts them on here
The car is getting:
Single mass flywheel conversion and new clutch
Turbo studs renewed and down pipe refitted
R32 front end conversion with 25mm ARB
AP Coilovers
Cambelt kit
Stage 2 remap with n275, n112, Evap and 2nd lambda deleted
And a couple of weeks ago me and Terkin fitted the rear AP suspension and neuspeed 28mm RARB
Can't wait to get the car back :)
Get my car back today woop woop :)
Well??
wont hear from him today,he will be to busy out killing everyone :giggle:
He is just on his way home
Let's say he enjoyed the test drive
Handles like a dream :-)
