skodalads VRS
Here is the engine bay the day I picked it up.
Here it is today, not painted or smoothed yet.
It's getting there now, just going to reroute the fuel lines as I'm not happy with them,
Below is the panel I have had made by a mate to cover the junction box,
This will be painted and bolted on. The underside will be lined in a min conductive material and
Underneath the junction box will be the same so it can't arc onto the body.
In other news my car fell of the jack and knackered my sill. Mint.
And I test fitted my new wheels
  • Replies 897
  • Views 99.3k
  • So, another day and more updates, the car is being painted tomorrow so these are the last prep pictures! The bay all masked up I opted to have VW rubberised spray sealer under the wings and ski
  • The car should be ready for me to be pick it up tonight! These pictures are from this morning       Spray sealer on the inside of the wings         Might have some some more interes
  • Another big weekend on the fabia!    My fuel for the weekend started with this 40oz mixed grill     Got all my boost pipes back and inlet too, now with v-bands welded too
Keep trying to do a bit in the car when I get chance. I relocated the ECU earlier which has cleared up the firewall nicely, re routed the power cable for battery too!
I have now insulated underneath the junction box so it doesn't short out on the body
It is very nearly ready to go for paint! All I need now is a new fuse for the junction box, new and safer battery terminals and that's it!
You just bodging the top part of battery cover to lay it flat?
Pip - there were 2 spare m8 captives where I have wound 2 long bolts through and locked it in place with a nylock nut. I then wound another but down the thread to where I want the cover to sit, if you look in the picture where you can see the rubber, that is the bolt. Then a polished dome nut to hold it in place, there is also another under the headlight that it hooks into no bodging here haha
No i mean for your actual connections.
Ooo I see what you mean, the junction box is cable tied down, the main reason for the cable ties is so I can quickly get it off if anything goes pear shaped
I might just copy you then. Ive made up some fuse holders etc but struggling to fit crimps big enough for cable into them. I have a spare battery holder to butcher up. Get us some more pics [emoji38]
Yeh I will get some pics man, it's literally just 2 cable ties haha
Just how youve placed it all down etc.
  • 4 weeks later...
So its been a while since an update! Loads has happened, finally got my wheels sent off to Belgium for the full ceramic polishing treatment!
Interior is booked in for the colour change, new dishes have arrives from the US for my wheels, and the car is at the body shop for the smooth bay!
Pictures
New dishes and center caps
What most of my nights are looking like ATM
I lost one of my gearbox mount bolts so I sourced new ones from skoda
Now the exciting stuff, the first plate welded in, aswell as all the little holes welded up, some factory lines left In
All ground down and ready for filler
The junction box cover all sprayed up
Whilst all of the interior is out, I will be laying this down everywhere. Silent coat, 30 sheets of it! Inside the doors, boot, floor, try to improve the ride quality and cut down on road noise
New vents as the old ones had broken slats
And last but not least, trying to settle my mind, In case me or my mates get into the ****!
Edited by skodalad
how does filler hold up in the engine bay right beside the engine mounts, doesnt it crack over time?
The filler will be fine as its a flexible filler, and also its only a light skim.
So I managed to get all of the sound deadenin fitted, the boot and all of the doors.
I also had my mother-in-law remake the material section that screws onto the scuttle shield, no more unneccesary holes, as I have relocated the ECU and a longer section that covers more things
Also to help bleed the coolant system up as it is a nightmare ATM, this is just a bleed tap for the heater hoses, should help
Edited by skodalad
Brilliant thread!
Keep it up.
Cheers mate, i should have some pretty nice updates in the next few weeks hopefully!
Edited by skodalad
Why not sack off that black padded thing? Spray the black metal section behind it colour of car. Will look so much neater surely? [emoji38]
I have often though about this, but a lot of the fastenings on it are chrome plated also, all the unnecessary holes removed so it does look really clean now, Unfortunatly i don't have the equipment to take the engine out, if i did things would be very different haha
I still need to get a picture of how the junction box is secured for you! i will remember lol
Looking very nice mate.
Thanks mate, it will look better soon ;)
How much sound deadening did you use for the front doors & rear doors?
Roughly around 2.5 sheets per door rob
Finally getting there with the bay now, all the wires are run, extra bleed tap fitted and everything painted.
To show you what's under the cover
it's looking good buddy
Thanks mate, just trying to get everything 100% before the front end goes back on, found a split hose earlier and I have had to reroute the small coolant hoses that go over the top
So I didn't get accepted for UD, Tried 3 times and failed 3 times. Never again :no:. Which means I have another 45 days to get it how i want want it! Early edition it is.
Whilst trying to reroute the coolant hoses to make room for the bleed tap I discovered that the Break vacuum hose was split!
So straight to my local Skoda garage and ordered a new one!
And no my name isn't Finnikin
