Amunsden Plus Bluetooth and Microphone install "How to"
Hello,
I am about to complete this install. Is there anyone in North Wales with VCDS who could enable my bluetooth? I would be happy to travel to you, cover expenses, etc.
Thanks,
Jamie
  • Replies 342
  • Views 101.2k
  • People are getting confused here between the different head units. For a bolero or Columbus you need a box under the seat for Bluetooth. This thread is about the amunsden plus which others have confi
  • .........famous last words! ;)
  • Asked a local Briskoda member with VCDS to help out activating my vrs Blacklines Bluetooth, just took a few minutes, no problem. Ordered the mic on Sunday 3rd Feb from Car-systems, it turned up yester
Hello,
I would like to buy the microphone for this install. I wanted to purchase from Eddie-NL:- as some of the money goes back to this forum.  Please could he get in touch to let me know if he still has any in stock? I cant use the chat app as I'm a newbie on briskoda.net.
Thanks,
Jamie
Hello,
Thanks,
Jamie
Email me: [email protected]
Eddie, Thanks, email sent. Jamie
Great article, activated my bluetooth today, ordered mic, confident I can now fit. many thanks
Just wanted to say thanks to Eddie-NL Mic cable arrived promptly and was fitted and working in about 10 - 15 minutes.
  • 5 months later...
sorry for waking up an "old" thread but i can't find this tutorial. Has the link been removed? or I'm such a big noob and i don't see it.
  • 3 months later...
ok so i have the amundsen + unit fitted in my monte fabia and i bought the microphone and lead and fitted last weekend, friend of mine with vcds tried to set it up today and all we got was error out of range here are some pics of the unit so maybe someone can tell me whats going wrong ? there is no unit fitted under the seats but from reading this thread i didnt think i needed it !
last pic shows how i wired the mic is it correct ?????
these pics are from we tried to code it
Judging by the MAC address being all zeros then my guess is it won't work as there is no bluetooth fitted to the headunit.
Do a search on the forum as there is a post about which headunits will work.
Thanks to Eddie for my microphone. Finally installed it today.
It was a really quick job on a Roomster - completed in around twenty minutes in the car park while my daughter was at ballet! No need to remove any trim or panels around the dash, except to pull down the bit of soft soundproofing under the fuse area in order to route the wire.
Colin, your picture of the microphone connector in the RNS315 is correct.
I ran mine down the passenger side with the factory loom and across behind the top glovebox.
  • 2 months later...
Hi. I'm local to Worcester and have just bought an Octavia Blackline VRS and am looking to enable the bluetooth on the Amundsen stereo system as per this thread bit worried I may make a hash of it though. Any chance Tech1e or anyone else would be able to help. Thanks...
Yes shouldn't be a problem :)
Brilliant - Thank you Tech1e - I'll PM you as soon as I am given the privelege to...
Hello - very new Octavia owner here. Can someone confirm if this process can be done for my car - Skoda Octavia 2.0 TDI CR SE Plus 5dr?
I would be grateful if someone could say if they have done this successfully or not so that I can take it forward. Cheers.
The most reliable way to check:
- Do you have an Amundsen+ (not an Amundsen) or RNS315 (not RNS310)
- If you do, remove the headunit and look for a sticker which says MAC on it (like the one a couple of posts above)
- If it's 00:00:00:00:00:00 then no, if it's other numbers/letters then almost certainly!
If you have a Bolero, Amundsen (RNS310) or Columbus then you will need a separate loom and BT module as well as the microphone.
Yes it is an Amundsen but is there any other way to check the model? Removing the head unit is beyond my comfort zone and my old man (mechanic) won't be here for a few days...
If its just Amundsen without the Plus Symbol it wont work you will need loom BT module and mic as described above.
Ok thanks very much for the replies.
  • 10 months later...
  • 4 months later...
I've just tried to fit the kit that I bought from eBay, it's all wired in, got it up to the back of the stereo to find that the green block is slightly too large for the gap it's got to go into. I had to cut off one section on top as its a different shape to where it's going into.
The black connector piece slides out from inside the green cover, so I just need a replacement cover which is slightly smaller and fits the gap better.
Any advice appreciated as I don't fancy spending ages filing and shaping the piece I've got to get it to fit.
Can you post a link to the kit you bought off ebay, chances are its the wrong thing so even if you get it to fit physically chances are it wont work.
There are two types of green connector each having a different key hence why yours doesn't fit.
This is the one in the Blackline
http://www.carsystems.pl/img/products/38/7/15_max.jpg
Older style
http://image.dhgate.com/0x0/f2/albu/g1/M01/5F/25/rBVaGVRfB0CAJqboAAEogb17tN4534.jpg
You can buy the right connector as I think the pins will come out:-
http://g01.a.alicdn.com/kf/HTB10SLYKpXXXXXvXXXXq6xXFXXXe/VW-Original-OEM-Radio-Connector-For-Audi-VW-SEAT-SKODA-Radio-Bluetooth-8X0-035-447-A.jpg
Eddie_NL is the guy you need.
  • 8 months later...
Can someone find the pic for the guide
