Amunsden Plus Bluetooth and Microphone install "How to"
Enabled my BT today with a vagcom 11 lead from hong kong.
All working on head unit but no sign of menu in maxidot.
Should there be ?
  • Replies 342
  • Views 101.1k
  • People are getting confused here between the different head units. For a bolero or Columbus you need a box under the seat for Bluetooth. This thread is about the amunsden plus which others have confi
  • .........famous last words! ;)
  • Asked a local Briskoda member with VCDS to help out activating my vrs Blacklines Bluetooth, just took a few minutes, no problem. Ordered the mic on Sunday 3rd Feb from Car-systems, it turned up yester
Should there be ?
Turn the ignition off and wait about 30 minutes. Mine wasn't on maxidot for a while after enabling it but eventually appeared.
Thanks for the advice. It's now showing. Just need to get the mic now
Woohoo! Finally! I have mine fitted.
A big thanks to Alex (on here) who kindly offered to fit. He's done a really good, careful job and the result is perfect - no echo and facia back as new. He even
persevered in the rain early this morning when he probably had better things to do.
Must say there are some nice folk on this forum, feels like a good group here.
Thanks Alex.
hmm i wanna give this a bash over christmas leave, need try get the bluetooth unlocked, whats this digi speed everyones talking about, any pics ?
Yep cheers I got it sorted a week ago just waiting for my mic to arrive ..... Probably not until the new year
Any recommendations for someone in the North West to fit and code this?
I was going to spend £240 ordering the Bluetooth for the swing, but if I can get this added onto the Amundsen for cheap that might be better?
Is it a similar job to get the microphone fitted on a Fabia II - I would assume it's the same part as I have the Amundsen+ unit fitted? Just wondering as I did a search and couldn't find anything in the Fabia section :)
Hi there,
I already noticed that this thread is all about VRs and Amundsen+ but it seems to be the right thread to get an answer to my question. I just collected a new SE+ with Amundsen+ which already has BT enabled and a microphone installed however I am confused regarding what options in the MFD phone menu are supposed to appear.
ClemUK and Chapper could you please confirm which options do you see in the Maxi-Dot? I do not have any options to set up a connection from the MFD, also I do not have options to sort contacts by 1st name.
Thx
Pretty much the same yeah. Alistair at Unit18 is local to you (old wolverton) and should be able to help.
My mic took 3-4 days to arive via UPS.
Got it fitted in about 35 minutes flat at MS Autos in Reading. VCDS coding complete in 2 minutes flat.
How much did they charge if you dont mind me asking? I live near Reading so sounds like a good option as if I do the mod dont fancy doing it myself. Did you supply the mic and loom and they did the rest?
Pip, it should be really straight forward mate. The guide is spot on and should save you a couple of a quid
I think if i do it i'll see who in the area can so the vagcom stuff and maybe get a mechanic friend of mine to help me install mic and loom
I currently have vag com (loaned from a mate) and based in Basingstoke. I do need pointing to which byte and bit I would need to activate for you
Also I've installed my stereo and parrot kit a couple of times if you need some help
Thanks zeffania thats a kind offer
Not a problem, just read the first post that points to where it needs activating so can do that so you can stream music before you get a mic sorted
Pip, I live in Reading and did the Microphone fit myself in about half an hour (including drinking tea). It's not hard and my trusty fish slice is to hand if you're not sure.....
Great How to. Thanks
Goaty do you have VAG COM? Likely to have the car in a week or so, would be good to get the Bluetooth enabled soon after.
A mate of mine has agreed to order the mic and fit it for me when I see him next; if that falls through might have a go myself but might need a hand.
Don't have VCDS I',m afraid. If I'm about I don't mind helping you out though.....
First point of call is the VCDS owners map to see who's near you. I'm around half hour or so from Reading if nobody is nearer I'm happy to help out.
I'm in Basingstoke or Henley during the day
Morning all. All ordered if anyone fancies fitting for me for some cash I am in Aldershot hants.
Thanks in advance.
Matt
Sent from my Nexus 7 using Tapatalk 2
Thanks in advance.
Matt
