Fabia/Octavia MK1 Cruise Control
Hi guys,
As title, I bought this but never got round to fitting it!
£40 posted
Anyone?
What else is required to make this operational, other than the plug in at the end....
Depends on your particular vehicle, most are a case of install and code with VCDS
isnt there also a wiring loom that has to be pinned into the fuse box and somewhere under bonnet and spliced into ecu wiring? Then vag-com and vcds
Yep. You're right
Phil
From the research I have done, there are 2 scenarios and it all depends on your ECU/Engine code - one needs a wire through the bulkhead and one doesn't
1.8t needs two looms for sure, some diesels only require one loom. They all require activating via VCDS.
Would this work on a mk4 Ibiza?
No that wont work on a MK4 Ibiza. They have a combined switch like the MK2 Fabia.
The above switch will work fine as a replacement switch for a cruise vehicle. Other than that on any model you will also need the wiring looms.
Would it work on a MK 1 Fabia 06 plate?
Mine is 06 and that's what I bought it for but never got round to fitting it! Am moving house now so need to clear stuff out - less to move!
Can anyone recommend what is required to fit it to a pre facelift mk1 Fabia vRS? I had it on my last vRS but that was a factory fit.
Geoff
Think you would have to check, as previously discussed, some just get fitted and coded, some need additional wiring that can be found quite cheap on the bay :thumbup:
To fit any MK1 Fabia vRS you need that switch and the wiring.
Geoff
If you were to buy this gentlemans switch I could make a loom for you and fit it.
Geoff
Let me know guys, can send tomorrow...
would say id have this but id need a loom too :/ how much is it to get programmed and im guessing from skoda?
Any idea if this will fit a polo 9n gt tdi?
No, they have a combined stalk like the Ibiza and Fabia II
Tried PM but not accepting messages.
Mmmmm strange, sent you a PM!
Update to help you guys out a bit...
VW/ AUDI INDICATOR COLUMN SWITCH (WITH CRUISE CONTROL)
FITS:
Audi A2 2000-2005
Audi A3: 1996-2007
Audi A4 1999-2001
Audi A6 1994-2005
Audi TT 1998-2008
Ford Galaxy 2000-2006
Seat Leon 1999-2005
Seat Toledo 1999-2005
Seat Alhambra 1999-2010
Skoda Fabia 1999-2007
Skoda Octavia 1997-2004
VW Bora 1998-2005
VW Golf IV 1998-2003
VW Passat B5 1996-2005
VW Sharan 2000-2010
OE NUMBER:
8L0 953 513J
where could i get the loom from do you know? thats if i boguht it..
Dealers should have access to them...
