Eddie-NLs Octavia Vrs Estate 170CR
We need full car photos!!
  • Replies 218
  • Views 61.6k
  • New Octavia 3 Gemini Wheels fitted today, will get a distance pic up when the car has had a wash       TPMS High Version also fitted   Valve   Maxidot display o
  • Scirocco Mirror
  • That's one modification that even Eddie might struggle with!
will do when I get it washed
Ed, just need to graft in a colour VW highline display. Since changing to a VW Tig the colour display just makes the maxidot look so boring.
It is 4x Tyre Valve sensors and a module with a loom.
Fairly easy to fit the wiring, I got the garage where I bought my wheels from to fit the valves
Where does the module go?
Does it still have a reset button on the dash?
I know
If the circuit board was the same it would have one now
I think the Yeti has a colour one as an option, but they are like mk6 golf clocks so have the same problem with the shape
Module sits outside behind the rear bumper
There is no reset button, you fix the issue and the warning goes away automatically
I know
That's a real shame mate.
good!
  • 2 months later...
awesome amout of nice kit on this car, you must really know your stuff, think i need to leave my car with you for a few days and let you do some stuff!!
Any pictures or part numbers? I'm struggling to find info on fitting this one.
Eddie, your retro fitting skills still amaze me. Loving the new mods
Unreal mate, you should open a garage for retrofits, you'd make a fortune!
New Update
Tried to fit Park Assist, unfortunately found out my ABS pump doesn't support it. Luckily I tested it with the sensors taped on the bumper.
I didn't want to change the ABS Pump so settled to fit front Optical Parking
Here are the results
Eddie. I already have front and rear OPS fitted as standard on my 2012 octavia but I don't have the activation button. Do you have a how to fitting guide with all the bits I need. I popped the climatronic panel out and there is no wiring for it - which I was hoping there was.
How can you have OPS front and rear sensors without the button? The system wouldn't work
It has sensors on the front and rear bumper but no button, I thought it was strange because when I pulled up towards something I went to push the button and it was not there?
How did you install the button - where do the wires go ?
Have you had the car from new?
When I was looking for my car I also looked at an Octy vRS that had front and rear sensors and it had the button to turn them on and off like I have on my Superb. Could it be that yours have been retro fitted by a previous owner?
So how do you turn them on other than having to put the car in reverse? I can switch mine on via the button when I need to check how close the front if the car is to something.
I had the button on my last car but I have only just bought this one. Apart from putting it in reverse I can't hence why I wanted to retro fit the button.
pm'd
Sounds like the system has been retrofitted then rather than being a Skoda option.
It looks factory fitted.
Eddie's looks like it was a factory fit too even though it isn't.
I am going to have to have a better look in the light. Do you know how to retro fit the button.
Mine is factory fitted but I'm sure Eddie will be able to assist you with it.
it can't be factory fitted, the reason is simple
Factory kit won't work if one component doesn't work (sensor, button, buzzer, switch) failure of any single item will knock out the system.
My install is full factory retrofit, works like a factory one
I am going to have to do more investigating, I am not even sure that the front sensors are even wired up now.
