need a we bit of help
i bought myself a set of hid xenon lights.
now i have had a few in the past never had any problems.
But the set i fitted om monday the lights sometimes only one come on so i turned them of and on again then they both worked.
a couple of times they went of straight away but come on when i turned lights of then on again.
i also noticed the drivers bulb is alot lot brighter than pass light.
on way home from wrk today the drivers light dint come on and it wont come on at all anymore.
any ideas as company on ebay said Sounds like a canbus issue. but how can it be if only one light works and one WAS brighter than the other?????
Dodgy ballast? or maybe a loose connection?
get a relay wiring kit from ebay about £4~7 takes a signal from the oem light socket and direct power from the battrie
i thought it was a dodgy ballast.
i was looking at the canbus resistors would they work.
Im going to take bulb out the morn that's not working and try it on the other ballast to rule the light out.
just noticed your in Scotland where abouts i might be able to come and assist
