230v power tool to 240v mains?
devonutopia
Recommended Posts
Trying to find out if this is possible, but I think it is
Locally I bought a 2 pin plugged drill from someone emigrating. Was cheap and I assumed at the time it was a 110v one and needed a transformer. Today I noticed it said 230v, so I assume its a mains powered drill designed for use in Europe. So, I assume I just need a 2 pin to 3 pin converter and job's a good 'un? :) Drill isn't a monster thing - just a 550w hobby drill really.
Google is not helping when trying to answer this
Link to comment
Share on other sites
what he said. SWMBO came over from Germany with two pin kettle, coffee maker, iron etc. I just topped the plugs off and changed for UK ones and no probs. Some stuff is even earthed.
Link to comment
ah - well, I've spent £3 on a ebay converter before thinking about the snipping option - I have some spare plugs too/ D'oh! Will see how the converter goes and if need be, cut and shut a plug on it later
  • Like 1
Link to comment
UK 240v is +/- 10%, so 230v is well within tolerance.
MOST equipment these days is 220v anyway, as that is European standard voltage, and it all works fine here in the UK.
The only thing to watch out for is US stuff, as it is 60 Hz and not 50Hz; some things will work, some things will go too fast and some things will catch fire or explode!!!!
Link to comment
Mostly Rubbish - lets get a few FACTS correct.
1. As gadgetman says the Standardised voltage(s) for the UK used to be 240v / 50Hz, and that of most of the the EU used to be 220v / 50Hz. It was standardised across the then 11 members of the EU at 230v +/- 10 / 50Hz in 1996.
2. USA voltage is 110v / 60 Hz
For God's sake don't plug US equipment directly into UK supplies - it will explode or catch fire.
Link to comment
UK voltage is 240v PLUS OR MINUS 10% - as an effing industrial electrician I know what I am talking about.
Therefore the voltage can legally vary from 264v to 216v. European voltage is 220v +/- 10% - 244v to 200v. The KEY word when reading the voltage specs is "Nominal", no country changed its voltage, just adopted the 230v moniker as a piece of legal jargon.
YES US is 110v (+/- 55v), but you cannot simply run mains power equipment through a transformer because it ALSO uses 60hz frequency which can bugger up timing and/or deliver too much power to devices without suitable power regulators.
A lot of modern electronic equipment WILL work, because most modern electronic equipment uses intelligent power supplies; the manufacturers figured out years ago that it is a lot cheaper to make one slightly more expensive standardised psu, than make cheaper psu's for each different voltage/frequency throughout the world; if you dont believe me, go and read the blurb printed on the power block for most laptops built in the last 10 years, it will say "100-240v 50/60hz"
Link to comment
Have to be careful with electrical things from China, the company I work for has done a bit of importing from there and they tend to fail in short order in the UK if they were built for Mainland China where the voltage is (legally, technically and anything else either) 220 volts. Heater elements are a favourite for failing, tend to work for 2 or 3 months before dying.
Link to comment
That is more probably because it is badly made tat then the voltage issue. Stuff my wife brought with her is still working perfectly - over 14 months after we arrived in the UK, and a friends wife has stuff she brought over 5 years ago that still works. On the other hand, a cheap Chinese-made USB charger I bought through a UK company a few months ago exploded after 8 hours (REALLY - it blew the cable across the floor).
I never checked the exact voltage in China, but everything I took with me worked properly, even a cheap, plug-in mosquito killer from Lidl.
Link to comment
heres a spanner in the works.................................. :giggle:
Back in mid 80's I lived in USA for a few years...........................
My mum took her UK Singer sewing machine and her UK Kenwood mixer out to USA with her.................
Electrician just wired one "USA industrial" 220V? socket (by "strapping" two 110V cables together) in the kitchen and fitted respective plugs to the mixer and sewing machine.
Both appliances worked well.............and were still working after several years back in the UK when we came back!..the Hz difference didn't make any noticable effect on them!
Link to comment
yes that is entirely plausible, on USA three phase installations you can obtain 220v by wire across 2 live terminals, it's not good practice though especially for domestic stuff..
I've been thinking about the scaremongering that the 50/60hz brigade have been bleating about too and o can't even think of a good reason why you can't run a drill or a blender from either a 50 or 60 hz main, basically in a power drill there is a "universal ac-dc" motor which is probably half wave rectified and the way the speed is varied is by tapping into the field coil in various places, that just means the thing would run slightly faster on a 60hz supply.. This is all just theory though don't try this at home folks.
Link to comment
I had a rice cooker which I bought when I lived in Hong Kong in the late 70's. It lasted thirty years before it packed in, and even then the electical side of things were still working fine, the aluminium bowl got a hole in it.
Link to comment
Heavy duty appliances such as washing machines, cookers and possibly fridges in the USA are designed and wired for 230V running anyway as the 110v on it's own cannot cope (Anyone who's ever boiled a 110v kettle will know how long it takes),
Link to comment
Heavy duty appliances such as washing machines, cookers and possibly fridges in the USA are designed and wired for 230V running anyway as the 110v on it's own cannot cope ,
Not when i lived over there...............fridge, freezer, washing machine, tumble drier etc all 110v!.................................220V is USA version of our 480v 3 phase industrial.
Link to comment
The in laws live in the California and their washing machine is definately 230v as it's hooked up to a step up transformer for the supply voltage.
Link to comment
And look out for any US kit that says "110 -230v AC" . It might well be switched mode, but the input RF capacitors will most likely be rated at 110 ,and on connection -unit goes bang . Son had it with some kit he bought in US ( Californi to be precise). Think it was a PS3 -lot cheaper than here . Said "110-230" ,so he pluged it in for PSU to go bang . I opened it to find input cap had blown and deposited it's innards on most of the inside . New PSU for a few quid and all was well . If the drill is not metal ,then it's probably double insulated . If metal ,might be worth opening up and fitting three core cable ,and then get it PAT tested .
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
