OBD ABS warning Codes
Hi
On my sons Felicia we have a problem with the ABS and Brakes warning light. Have plugged in the code reader and it gives the following codes
1044 - Transmission control module incorrectly coded.
668 - Battery power voltage supply (terminal 30)
1130 - ABS Operation - signal outside range of tolerance
Recently have had to have new keys, originals lost, so car has been re-coded.
I am abit lost as to where to start.
Would anyone know of a good point to?
Many Thanks
Mike
hi there abs control module is on the pump there are some fuses near battery see if there ok other than that the abs is easy it trace out i striped a slxi with abs and found out there is not much wireing to them it takes its power from battery by 2 fuses 30amp in its own little fuse box and one wire to dash light and one to brake peddle switch and one to obd k line and wires to each wheel sensor hope this is some help to you if your near bedfordshire i could take a look for you
still got to fit abs to mine yet.....
i have vag com too
Edited by uma1998
hi uma, thanks for the above. i will have a look at this and see what i can find.
cheers
mike
Edited by mike j
there is 3 fuses for abs 2x 30amp and 1x 10amp they are in engine bay on bulkhead as i just looked at my abs loom
Hi uma
Have found the fuses, the 10A had blown.
Wonder what caused it, the elctrical diagrams in the manual are a bit vague....
no problems glad i could help ya i have air con and there is no diagram for this and about 3 realys 4 fuses and loads off wires in with engine loom...
