help please...
recently got my hands on a R reg black felicia estate 1.3 mpi.
i have no front wiper function unless its at top speed and then it dosnt park itself just stops where i switch it off
also no front or rear wash or horn
does anyone know of any problems that may cause this or is it a trial and error game?
ive tried to look for this problem in the forum but no joy ive checked all fuses and relays no problems there
any help would be appreciated
thanks in advance stuart
Edited by stu_d69
I'd say your windscreen/washer switch needs to be replaced, unless you have an obvious wrong/bad wiring.
About the horn: might be as simple as the steering wheel contact, or the horn itself is toast.
I had an intermittent horn. Found out it was the contact (mentioned above) by pressing (and holding) the horn button and rotating/wiggling the steering wheel.
i would say motor for wipers or stark. try power to washer pump i did have a problem where the stork died and had no washers but had wipers had my donor car so knicked it off that
