Front passenger side window switch problem
Hi there :)
Apologies that my first post here is a problem! I recently became the owner of a Skoda Fabia I 2002 plate. Love the car, but since I've bought it, it's had a small problem that's been bugging me. The front passenger window is operable both up and down from the drivers side control but the one on the passenger door doesn't work. I assumed the switch was dodgy but after using the one from the rear passenger window that I know works, it still wouldn't work. After this I checked the fuse and that was fine. Could this be a wiring issue or does anybody have any other ideas? I did a search both on the Google and this forum before posting and found topics regarding windows sticking or not working at all but none this specific.
Thanks in advance!
Josh
Hi guys..
Just an update if it helps diagnose the problem. The front switch itself is fine as it works in the rear passenger window. Using a multimeter I determined that there is definitely power going to the connector in the front passenger door and the window definitely works as it can be controlled from the drivers side. I cannot fathom why the window cannot be operated from the passenger.. Any input would be greatly appreciated!
