Removing 2005 Fabia 1.2 engine cover/air box.
Hi.
My 2005 Fabia 1.2 12v has a HUGE cover over the engine. It seems to be solidly attached, but without any obvious fastening bolts, screws etc.
I've tried to lift it off by pulling hard on the edges, but I'm either not strong, or brave eneogh to move it.
Does anyone have any suggestions?
Thanks in advance.
  • Sponsor
Pull harder, vertically upwards, maybe with a bit of jiggling around. Probably best to disconnect the two air hoses on the battery side of the cover first in case it suddenly moves farther than they will stretch.
The airbox/engine cover is a pretty solid thing, you won't break it.
Once it's off, grease the four points where it fixes so that life is much easier next time you try.
