What does MFD mean?
i have a 1.6 tdi 2011 skoda fabia cr,
when i start it up it says "MFD" on the dash,
why does it says this and what does it mean?
also, what does the "CR" stand for?
cheers guys!
Multi Function Display
Common Rail.
MFD - Multi Function Device, the trip computer.
CR - Common Rail,  the diesel injectors are supplied with diesel from a common rail containing high pressure Diesel.
worse than Pumpe Duse IMO :(
cheers guy!
when i have traveled in my car and i turn the ignition off, theres a noise that sounds like someone is shuffling there feet, does it about 4 time,
is this the CR?
I've learned something.  I always thought it was multi function display for some reason. :D
According to the manual, MFD stands for Multi Function Display not Multi Function Device.
We all call it Maxidot anyway so I don't think it matters that much what it means.
'You say potato and I say potarto'
Thought it was MDF :)
cheers guy! when i have traveled in my car and i turn the ignition off, theres a noise that sounds like someone is shuffling there feet, does it about 4 time, is this the CR?
Its the throttle valve cycling, quite normal.
Maxi dot isn't MFD.  Maxi dot is the full screen.  Pikeys like me with a Monte (and other models) will have MFD - the basic Instant MPG, Av MPG, range, time driving, etc.
And Nathan - if you ask the feet shuffling question again, someone might answer it!! ;-)
That's four times in seperate threads!
Its the throttle valve cycling, quite normal. :rofl:
I thought MFD was like wooden sheets which kitchens are made from.
Looks like I got that one wrong :)
I already have.
That is MDF ( medium density fibreboard) ;)
And MFD is multi function display as most have said :)
MFD  could be 'multi functional drawers' in which case we are back to MDF and kitchen units! :giggle:
I give up      :x
