hi there
Ive got a 2000 skoda octavia 1.9 sdi, the non air con model, and i was wondering if anyone can tell me if the heater dials on the center console are meant to work because mine haven't since i bought the car.
and if so can anyone offer any solutions?
thanks very much for any comments.
sorry the lights for the heater dials on the center cosole.
Hi there
I will move this to a more relevant section, where you will get more views and replies
The Introduce Yourself section is basically just for saying hello
Best of luck
Damo
I would expect that the lights behind the centre console have burnt out.  This was certainly the case on my parents mk3 Astra (L reg) - I have replaced the bulbs a few times as they are on all the time the ignition is on.  I should say this is a guess, as I have a climatronic unit on 2001 old girl (with 222,222miles on the clock)
Edited by mbames
Try the search facility.  I seem to remember an old thread a couple of years ago about pulling off the dial knobs and then using a piece of rubber tubing to pull out the old bulbs.
THeres a little bulb (i'll check what size, i haz a spare one) that lives behind the middle dial on the blower.
put it to number 2, grip it with a vice grip and some rubber to not mark it, and pull.
pop out the dead one and replace. 2 min job :-)
Edited by mac11irl
thats cudve been my theread pikpilot!  i just used the pliers on my leatherman to pull out the bulb - small little 5W 1 i think.
theres just the one, the other dials light up off some refracting plastic from the middle one.
thankyou very much for your help it worked a treat.
Glad to help. reallt have to root out that spare bulb i got, just after popping tot the shop, and the little W****r bulb is blown again... typical.
