My VRS prescription has arrived
a bit of luggage in the back, i think they fill the arches perfectly here, not too high or too low :)
Looks a good ride height there, Eibach would be the safe bet I guess, would like to find some better pic's of a car on the H&R springs before I part with cash and its too cold at moment to be out side playing with the car, i'll wait till better weather gets here and will look at the bilstien dampers at same time so I don't need to pull it apart twice. It does sit very high!!
Edited by wrightcnc2009
  • Replies 57
  • Views 4.2k
  • wrightcnc2009
    wrightcnc2009
    It's late/early and only got my phone to hand so will write in more detail with pictures very soon when on the pc but in short, I am the very proud owner of the third shade of grey and despite the wea
  • wrightcnc2009
    wrightcnc2009
    Review time!   Done a few miles now, 350+ infact and all is good, I'm treating donkey under bonnet with respect, only using up to approximately half throttle and reving to a little over 5000 rpm whe
  • I can vouch for Hartside Pass, it's about 45 mins to an hour's drive away from me and it's as close to being the most perfect driving road you'll find in the UK. Used to go for Sunday blasts on my CB
On stilts
sorry for the random "on stilts" pic didn't attach, operator error :@
Here's a couple of shots of mine on H&R's Wrighty, it's potentially settled a little more since then, but I don't think the H&R's look a great deal lower than the Eibach's when settled. Sharkrider's car looks pretty low for the claimed 15/25mm
22AFCE4F-2AF2-4A52-A793-D9D818604CD4-110
BBDE4F56-4C62-4853-8B16-DC1B90A56F3C-110
F0B25F51-FD11-437C-9A49-62FC257D9A82-110
F5F3F8A4-9F7C-4EC7-AA45-4CDA1CCE40CE-110
I think the fronts look pretty much the same sparkly, odd that... the back of yours is much lower though,the higher rate higher estate springs show out....
Sparkly, that looks the nuts! have you got spacers on as well, the rear looks bit wider or is that because it is sitting lower? I'm thinking that I will wade straight in and do dampers at same time so's that I don't have to take apart twice, I'm just not sure what way to go on springs as H&R and the Eibach look near enough the same from the pic's of yours and Sharkrider's (yours looks the nuts too Sharkrider!), bit weird as the two company's state quite different measurements but from what reference is any body's guess??
Thanks, no the car isn't spaced, althought I have some 15mm spacers I just need bolts for which I will try on the rear.  At the right angle they are still a bit tucked away.
I think my car has settled a little further front and back, but the difference isn't so much as to make you choose one spring or the other.
The deciding factor for me Wrighty would be that Eibach and Bilstein seem to have partnered on the B12 kit with both fully endorsing the pairing.  The H&R's I believe are a slightly firmer spring again so might be even sharper than the Eibachs but I have no basis to say this is true, equally you might surmise that the Eibach's bring more comfort.
FYI Awesome GTI will fit and align your car after for £150.00 if you buy the kit from them, I would push for any supplier to match that.
First wash today
Also fitted some rear mud flaps, the dealer said they don't make rear flaps for the vrs but we all know they do, anyways these one's are off ebay all the way from China (come in a set of 4) and are a bit smaller than the genuine skoda items
