Coding / Adaptation Help required
I'll give you a tip - there is a file created in your c:\ross-tech\vcds\debug folder called coding.log
This is a record of every change you have ever made.
Start at the end and reverse every single change until you have it back to factory then start again SLOWLY and making sure you don't miss any steps.
  • Replies 295
  • Views 86.8k
  • To code High Beam Assist (for vehicles with Lane Assist fitted) - All Std mk3 vRS's Access Module 09 - enter security code 31347 Go to (2) Assistant light functions - Menu light assistant and change
  • I've cracked it and it works!!! Will post up details later when I get 5 :-)
  • Auric Goldfinger
    Auric Goldfinger
    Be very careful , I made a few changes to mine and I didn't know what I was doing   I now have Six reverse gears and one forward........................             Joking apart, Andyvee's yo
Thanks Andy,
I got my mirror dip to work!
So if I try going through adaptions again, it wouldn't work?
I should reverse what I've done then do again?
Have you got a baseline of the car before you started (full scan and adaptation maps)?
If not, trying to unpick things when you don't know what you have actually changed can be next to impossible, unless you understand the impact of the changes you are making.
I'm still learning on the MQB platform after 18 months!
When you code something and it doesn't work as expected then reverse those changes before changing anything else.
Joking apart, Andyvee's you man
I think I just did a normal scan, not sure if it's baseline. I'll tinker tomorrow again. Her indoors thinks I'm mad!
By baseline I meant do you have a full set of data as the car was before it started - so a saved scan and a saved adaptation map for any controllers you have been playing with the adaptation channels, usually 09 and 5F is all you need as they have by far the most settings and also the areas where you can do the most damage.
Found the log!!!
Address 09:5Q0 937 084 AJ recoded (ADP-(1)-Leuchte25KZL HA59-Lasttyp 25) from 18 - 2* 5W  to 43 - allgemeine LED   Friday,27,March,2015,12:32:56:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(4)-Leuchte26NSL LA72-Lichtfunktion A 26) from not active  to Nebelschlusslicht wenn kein Anhaenger gesteckt   Friday,27,March,2015,12:53:16:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(4)-Rear Window Wiper-Traenenwischen Heck) from not active  to active   Friday,27,March,2015,12:57:10:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(17)-Windshield wiper-Traenenwischen Front Status) from not active  to active   Friday,27,March,2015,12:58:08:59745
Address 17:5E0 920 947  recoded (Long Coding) from 27A501006980A60001082A021000000000000000 to 27AD01006984A60001083A021000000000000000  (73430/031/00138)  Friday,27,March,2015,13:02:08:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(17)-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt) from not active  to active   Friday,27,March,2015,13:06:16:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(22)-Access control 2-Menuesteuerung Spiegelabsenkung) from not active  to active   Friday,27,March,2015,13:09:14:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(5)-Leuchte12NL LB45-Lichtfunktion B 12) from not active  to Abblendlicht links   Friday,27,March,2015,18:41:00:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(12)-Leuchte13NL RB5-Lichtfunktion E 13) from not active  to Abbiegelicht rechts   Friday,27,March,2015,18:41:36:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(5)-Leuchte8FL LB39-Lichtfunktion B 8) from not active  to Abblendlicht links   Friday,27,March,2015,18:42:52:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(5)-Leuchte9FL RB2-Lichtfunktion B 9) from not active  to Abblendlicht rechts   Friday,27,March,2015,18:43:22:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(4)-Leuchte26NSL LA72-Lichtfunktion A 26) from Nebelschlusslicht wenn kein Anhaenger gesteckt  to Nebelschlusslicht wenn kein Anhaenger gesteckt   Friday,27,March,2015,18:45:30:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(4)-Leuchte27NSL RC6-Lichtfunktion A 27) from Nebelschlusslicht wenn kein Anhaenger gesteckt  to Nebelschlusslicht wenn kein Anhaenger gesteckt   Friday,27,March,2015,18:46:32:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(6)-Leuchte26NSL LA72-Dimmwert AB 26) from 0  to 100   Friday,27,March,2015,18:48:30:59745
Address 52:5Q4 959 392 B recoded (Long Coding) from 001C00208001040000001100 to 001C00208C01040000001100  (73430/790/00138)  Friday,27,March,2015,18:51:24:59745
Address 5F:5E0 035 842 A recoded (ADP-(63)-Vehicle function list BAP-traffic_sign_recognition_0x21) from not activated  to activated   Friday,27,March,2015,18:53:13:59745
Address 5F:5E0 035 842 A recoded (ADP-(151)-Vehicle menu operation-menu_display_road_sign_identification) from not activated  to activated   Friday,27,March,2015,18:53:43:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(16)-Leuchte2SL VLB10-Lichtfunktion G 2) from not active  to Blinken rechts Hellphase   Friday,27,March,2015,19:35:51:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(18)-Leuchte2SL VLB10-Dimmwert GH 2) from 0  to 25   Friday,27,March,2015,19:36:23:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(19)-Leuchte2SL VLB10-Dimming Direction GH 2) from maximize  to minimize   Friday,27,March,2015,19:36:44:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(16)-Leuchte3SL VRB21-Lichtfunktion G 3) from not active  to Blinken links Hellphase   Friday,27,March,2015,19:37:32:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(18)-Leuchte3SL VRB21-Dimmwert GH 3) from 0  to 25   Friday,27,March,2015,19:37:52:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(19)-Leuchte3SL VRB21-Dimming Direction GH 3) from maximize  to minimize   Friday,27,March,2015,19:38:05:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(5)-Assistance light functions-Fernlichtassistent Reset) from active  to active   Friday,27,March,2015,19:40:05:59745
Address 09:5Q0 937 084 AJ recoded (ADP-(2)-Assistance light functions-Menuesteuerung Fernlichtassistent) from Not Present  to present   Friday,27,March,2015,19:45:50:59745
Address 09:5Q0 937 084 AJ recoded (Long Coding) from 0F000A42C24722FB07A04082B10C07280000000000000000000000000000 to 0F000B42C24722FB07A04082B10C07280000000000000000000000000000  (73430/790/00138)  Friday,27,March,2015,19:47:58:59745
Address A5:5Q0 980 653 F recoded (Long Coding) from 0100000001030300000400000000010100 to 0100020001030300000400000000010100  (73430/790/00138)  Friday,27,March,2015,19:49:10:59745
Address A5:5Q0 980 653 F recoded (ADP-Activation speed for high beam assistant) from 57 km/h to 20 km/h  Friday,27,March,2015,19:50:09:59745
Address A5:5Q0 980 653 F recoded (ADP-Speed threshold for high beam recommendation off) from 27 km/h to 10 km/h  Friday,27,March,2015,19:50:25:59745
Just by looking at that I can see what I did wrong on this line for the intermittent DRL/indicator cflash
Should be
(16)Leuchte3SL VRB21-Lichtfunktion G 3 auf "not active" to "Blinken rechts Hellphase"
I did
And here for the fog cornering
Should be
(5)-Leuchte13NL RB5-Lichtfunktion B 13 to Abbiegelicht rechts
I did
I must say that I admire your bravery. Doing all these adaptation randomly and not knowing exactly what you are doing.
Though, maybe this is something else, not courage. :devil:
I think it's few things rolled in to one!
I'm struggling to find this bit on HBA:
Access Module A5
Go to Long Coding, change byte 2 Bit 0 to a "1" or use drop down menu to select "Coding_light_assist High_beam_assist"
Where is the problem? You do not have it on Byte 2 bit 0?
Do I need to do this?
Then I've done this,
But struggle with this
Where access module A5?
However I see on VCDS that you can search the module in the lower left hand side, as I can't find A5 on any of the tabs, electronic 1/2 etc
Also, Reversed the HBA and sign recognition last night. This morning my cornering fogs have started working when yesterday they weren't working?!
So when I get home next week, I'll have another play.
If you do an autoscan of your car you should see module A5 which is the lane assist camera.
You just select it to code the same as any other module, it is probably the next to last module on the 'Installed' tab, which is the default view.
Sent from my HTC One_M8 using Tapatalk
Bang on Andy as usual, it was in the first 'Installed Tab'.
Really struggling with this!
Ive tried twice now and get the light assist error!
Address 09:5Q0 937 084 AJ recoded (Long Coding) from 0F000A42C24722FB07A04082B10C07280000000000000000000000000000 to 0F000B42C24722FB07A04082B10C07280000000000000000000000000000  (73430/790/00138)  Friday,03,April,2015,13:27:58:59745
Address A5:5Q0 980 653 F recoded (Long Coding) from 0100010001030300000400000000010100 to 0100020001030300000400000000010100  (73430/790/00138)  Friday,03,April,2015,13:30:02:59745
Address A5:5Q0 980 653 F recoded (Long Coding) from 0100020001030300000400000000010100 to 0100020101030300000400000000010100  (73430/790/00138)  Friday,03,April,2015,13:40:49:59745
Your coding on A5 is incorrect.
TBH It is documented perfectly clearly, if you can't follow instructions and don't know the impact of what you are changing I would stop right now if I were you before you do something that is irreversible.
Why have you changed on A5:
Byte 2 from 01 to 02
Byte 3 from 00 to 01 - Byte 3 has nothing to do with HBA
Try changing the coding on A5 back to
0100010001030300000400000000010100 assuming you don't want traffic sign recognition active
Your changes on 09 look correct.
Make sure your lights are turned to off when you are making the changes.
I'm not sure why that has happened.
This is what I get following the instructions (screen shots on my VCDS)
Go to (2) Assistant light functions - Menu light assistant and change to 'PRESENT'
Access Module A5
Damn just realised you need to check the coding of the 09 CCM as well BYTE 2 bit 0-2, if doesn't have light assist selected then you will need to do so. I've set mine to come on at 10lx in the A5 adaptations and it seems to work much better!
But reading the earlier bit of the thread, it appears that vrsalan struggled possibly with the same problem I have (step 2). As per my 3 screen grabs above, my coding doesn't look like this one below?
Thanks in advance for help (and patience) with me!
On A5 why have you set Byte 2 Bit 0 to 02 - it needs to be 01 as per the instructions???
Your BCM (09) needs Byte 2 to have 03 set as the value across bits 0-2 - so the binary needs to read xxxxx011
Get a screenshot of how yours is coded for Byte 2 on A5 and 09 and then maybe we can work out what you have done.
Looks like this:
That is correct then. Are your lights turned to off when you have been making the changes.
If you go into infotainment and car settings do you have a tick box for light assist? Is it selected?
Just got your PM - give me half an hour and that sounds like an idea
Yes to both, Turned lights off before doing this. Yes the HBA is showing in the infotainment, I have ticked and unticked. Still get the error. Sent another PM
Dipped beams automatically switch on 140km/h iirc. Would it possible to lower this speed?
The only reference to 140 that could be connected to this is this one:
(7)-Characteristic curve-y1_0,0  (8)-Characteristic curve-y1_1,40  (9)-Characteristic curve-y1_2,90  (10)-Characteristic curve-y1_3,140  (11)-Characteristic curve-y1_4,190  (12)-Characteristic curve-y1_5,245
Also other numbers around it could be speeds, so maybe this is it. Though, maybe could someone else give a thought about this...
