Coding / Adaptation Help required
Very pleased with the HBA, although the fog can confuse the camera! :lol:
So, changing the lux from 3 to 10, does that enable them to work more in lighter conditions?
  • 4 months later...
  • Replies 295
  • Views 86.8k
  • To code High Beam Assist (for vehicles with Lane Assist fitted) - All Std mk3 vRS's Access Module 09 - enter security code 31347 Go to (2) Assistant light functions - Menu light assistant and change
  • I've cracked it and it works!!! Will post up details later when I get 5 :-)
  • Auric Goldfinger
    Auric Goldfinger
    Be very careful , I made a few changes to mine and I didn't know what I was doing   I now have Six reverse gears and one forward........................             Joking apart, Andyvee's yo
Help! Really struggling to find "module a5" for the last part of enabling HBA!
Cancel. We found it. Should have gone to specsavers
Sent from my LG-H815 using Tapatalk
Ha ha I was the same with that one! :D
This thread reminds me I still need to enable my one touch 5 indicator flashes!
Got it enabled but still get an HBA error when turning it on. May have to revert it or try again.
Make sure that when you code it that the ignition is on, the door is shut and the lights are turned off (not on AUTO).
Just try doing all of the settings again - are you using the latest version of VCDS?
Yay! Managed to recode with lights off and HBA is enabled! (strangely my car does not have the option to turn off/on driver activity monitor though but that is a different thread)
What's driver activity monitor?
Fatigue detection
Sent from my HTC One_M8 using Tapatalk
Oh yeah. Mine flashed up a cup of coffee. Is that all it does or does it monitor driver habits too?
That's the one. What year is your car aldouk?
Do you have the option for Driver Activity in your car settings?
It's early 2015, maybe even build December 2014. I'll have to check the setting, I've not noticed it?
Hi, can anyone help me on how to enable (2015 Octavia III GreenLine 1.6TDI):
Emergency Brake Flashing via Brake Lights
Emergency Brake Flashing via Turn Signals Active
I have this Cent. El. module:
Address 09: Cent. Elect. (J519)       Labels: None
   Part No SW: 5Q0 937 086 AH    HW: 5Q0 937 086 AH
   Component: BCM PQ37BOSCH 028 0162
   Revision: --------    Serial number: 86581908150717
   Coding: 0C0008424247005B47E04000000407080000000000000000000000000000
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 015002
   ROD: EV_BCMBOSCH_SK37.rod
   VCID: 8009765B1B81511E1BD-80D5
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119
   Component: WWS371 150628  041 0570
   Serial number:         150724013619
   Coding: 065DDD
They should be enabled by default on a O3, the brake light flash is.
Thank you.
One more question, which labe file to use for:
Edited by mlilasic
Had a go on a few last night.
So far only done the lap timer and the open/close via fob on the electic boot. So far they have been successful.
A fee I tried and they looked totally different to the screen shots (as was the descriptions) so I decided not to fiddle and break a one week old car!
LOL, my O3 is also a week old. Did a instruments sweep tweak so far.
The descriptions will change with different modules and different versions of VCDS, but not by much. On adaptation channels ignore the leading number in brackets, it is the description you are trying to match up.
Have you an example of what was different?
Thank you.
Which version of VCDS are you using? Just use the latest version and the correct label file is loaded.
Most changes are now made on the 1000's of adaptation channels on the BCM, not by coding.
I'll have another "play" one day this week and I will post some screen shots/more information. It was relating to HBA one of the ones that I was looking at.
The boot and lap timer went fairly easy, and as I'm "new" to VCDS I really didn't want to break something :)
Thank you for advice. I will double-check for version when I get my hands on the cable again, it was borrowed.
  • 4 weeks later...
Hi.
Writing for first time.
I'm having a problem. I can't see anywhere 01 coding_light assist High_beam_assist in A5 module long coding. Where to find it ? If I go in Lcode2 menu I dont have any faling menus or texts... only tiks.
Have some Idea ... if somebody wants to use team viewer ... :)
Just enable byte 2 bit 0
Also - why are you using Lcode2 ?
Tried this today on a 15 plate vrs
Address 09:5Q0 937 084 AJ recoded (ADP-(2)-Assistance light functions-Menuesteuerung Fernlichtassistent) from present  to present   Thursday,12,November,2015,17:32:22:45117
Address 09:5Q0 937 084 AJ recoded (Long Coding) from 0F001A46C24722FB07A04082B10C07280000000000000000000000000000 to 0F001B46C24722FB07A04082B10C07280000000000000000000000000000  (73430/790/00201)  Thursday,12,November,2015,17:34:15:45117
Address A5:5Q0 980 653 F recoded (Long Coding) from 0100000001030300000400000000010100 to 0100020001030300000400000000010100  (73430/790/00201)  Thursday,12,November,2015,17:35:00:45117
Realised I had selected the wrong one in A5 so changed:
Address A5:5Q0 980 653 F recoded (Long Coding) from 0100020001030300000400000000010100 to 0100010001030300000400000000010100  (73430/790/00201)  Thursday,12,November,2015,17:59:11:45117
However it was still not working giving an error on use.
I tried resetting everything and trying again with no luck so reset everything back to original and called it a night.
First time through I had not turned the lights off, however, they were when I tied again.
