Daniels Blue 182
Long time no update!
I haven't really done much as simply put I don't think it needs much doing exterior wise bar a Cup spoiler and lowering :)
Today however I had a good friend come over and we detailed his CTR EP3 and my car. Finished it with some of his HD wax which has beaded lovely :)
Happy with the finish :D
15035526162_25d995640e_b.jpgDSCN2567 by dann2707, on Flickr
14849144779_b7f9b7a2d8_b.jpgDSCN2568 by dann2707, on Flickr
14849133899_960eece6b8_b.jpgDSCN2569 by dann2707, on Flickr
14849264408_27f99e272b_b.jpgDSCN2570 by dann2707, on Flickr
15035483992_17798b9d7b_b.jpgDSCN2571 by dann2707, on Flickr
15032781721_8267fb4a04_b.jpgDSCN2572 by dann2707, on Flickr
15035819385_7e882b5522_b.jpgDSCN2574 by dann2707, on Flickr
15012812166_d32b265e9a_b.jpgDSCN2575 by dann2707, on Flickr
15035797135_f3b870dd87_b.jpgDSCN2576 by dann2707, on Flickr
14849236097_76e66a3997_b.jpgDSCN2578 by dann2707, on Flickr
15035774185_d1477cab51_b.jpgDSCN2579 by dann2707, on Flickr
Also sealed the windows with Gtechniq G1 :) Amazing stuff and will always do my cars wit it :D
15035762415_296274a023_b.jpgDSCN2580 by dann2707, on Flickr
More beading
15032678031_db40050115_b.jpgDSCN2582 by dann2707, on Flickr
15032667091_977e2fdc42_b.jpgDSCN2583 by dann2707, on Flickr
15012708066_383c1e5315_b.jpgDSCN2584 by dann2707, on Flickr
  • Replies 282
  • Views 28.8k
  • Got my wheels back from the powder coaters, £90 all in at Cas coatings in bradford
  • Well today I bit the bullet. It was already half getting there so decided to just go for it.   It's mad how much this weighs and adds up!   20160710_134952 by dann2707, on Flickr   20160710_14
  • Thanks mate. All lacquered!   Really pleased with them for a rattle can job. I don't expect them to last forever / be super durable but they've got to be better than this...     DSCN2074 by dann270
Cup spoiler and stubby aerial! It looks good as it is now anyway mate
I need one! Not sure where the get the aerial from though.
Today I got some goodies in the post :D
15042390261_2ac79aa16f_b.jpgDSCN2585 by dann2707, on Flickr
Which happened to be new track rods and track rod ends after realising that mine had lots of play when I went for my cambelt doing
15022461606_d05b52e866_b.jpgDSCN2587 by dann2707, on Flickr
I peeled back the rubber gaitor to reveal the connection. This is my first time playing around with steering components properly, they usually go right above my head so it's really really good to learn how they work :)
14858739449_b7ce5e0127_b.jpgDSCN2586 by dann2707, on Flickr
I then cracked the TRE nut off (16mm for reference). To enable the ball joint to stop spinning I jacked it up so that the weight of the spring acted upon the taper, when this force is equal or more than the force on the taper it stops it from spinning and comes off.
14858878128_f46ded4477_b.jpgDSCN2592 by dann2707, on Flickr
14858755579_a650df4451_b.jpgDSCN2596 by dann2707, on Flickr
Car in the most fun position, wheel off and me playing with it :)
15022471506_d4fd8cc52e_b.jpgDSCN2594 by dann2707, on Flickr
I then went and got a viscous fan spanner. This has a 32mm and 36mm end on it but I only required the 32mm side.
15042399961_afdc611835_b.jpgDSCN2588 by dann2707, on Flickr
Due to lack of room where the inner track is, the tool has to be cut down to enable to undo the nut
15022477756_e05fff7301_b.jpgDSCN2598 by dann2707, on Flickr
14858761659_592882732e_b.jpgDSCN2599 by dann2707, on Flickr
All off :) and as guessed, loads and loads of play in both ball sockets. Very sloppy feeling.
15045124132_b407ec98cc_b.jpgDSCN2600 by dann2707, on Flickr
I then measured the old track rod and adjusted the new track rod and end to suit. Screwed it back on.
14858829320_9f60cbf4f4_b.jpgDSCN2602 by dann2707, on Flickr
Lots of copper grease applied and the new one was tightened up :)
15042425851_ca10dba68a_b.jpgDSCN2603 by dann2707, on Flickr
15045133782_59644c70e6_b.jpgDSCN2604 by dann2707, on Flickr
I then tackled the other side. A lot easier than the other simply because I knew what I was doing and had the tool ready.
15022496766_0cbc6b3bac_b.jpgDSCN2605 by dann2707, on Flickr
14858781249_23fbc8a3de_b.jpgDSCN2606 by dann2707, on Flickr
Old vs New
15022503286_ff38e828b5_b.jpgDSCN2607 by dann2707, on Flickr
14858851128_8c05812e65_b.jpgDSCN2608 by dann2707, on Flickr
That was all sorted, went for a drive and it's not pulling at all to any one side so looks like my measurement worked. Ideally I will be getting it properly tracked again in the future once I get some new rubber on but i'm glad it's okay for now :)
I then dressed the plastics with AF revive and washed the wheels and sealed them with a third coat of Poorboys wheel sealant. Really happy with how it's turned out now. I really need to take some decent photos in some better places! Apologies for the standard driveway shots.
Great work again Dan
Was it Matthew that called for a detailing session?
He booked in with me last night for some machine polishing on the CTR
Thank you buddy!
Yes, that was him. He's coming on the 11th right? It's a shame i'm at work through the day as I would have loved to have got some tips as I really want to machine polish mine soon but i'm not sure if i'm doing it as well as I can. Will have to get him to pass the knowledge on haha
You can always bring yours for an instructional Detail at a later date
Cheaper rates, as you do most of it yourself, with my guidance
Changed the coilpack and leads the other day as it keeps coming up with a misfire on the dash. Seems to drive so much better now, really does purr.
Some pics!
I changed them at 10pm as I got back from the pub and saw the parcel :D Making the most of the garage being empty. Usually filled with dad's mid life crisis ie Boxter S haha
14910921880_341763ea93_b.jpgDSCN2611 by dann2707, on Flickr
14910918240_716daa6bbf_b.jpgDSCN2613 by dann2707, on Flickr
New one to go on!
14910874729_d92208dd8d_b.jpgDSCN2614 by dann2707, on Flickr
Old removed
15097545315_a47df2ffbd_b.jpgDSCN2615 by dann2707, on Flickr
The day before I got it hunter aligned after changing the track rod ends and inners. Only £40 including VAT which is a steal of a price. A place near me called Bram Racing. The other place near me wanted £75 PLUS!! VAT mental.
Some pics!
New one to go on!
Old removed
15097194902_eaafc60e12_b.jpg2014-08-30 09.23.16 by dann2707, on Flickr
Good news! My cruddy 1.2 had a lead snap on the coil pack and it was half working but causing a lot of backfiring
Snap? Jesus that's not good haha
Btw who voted this thread as 3 stars. How very strange :( haha
Yup got caught and snapped in the bit that goes on to the spark plug
How did you rate Bram? Seems like a good price.
Thought you were more Leeds than Wakefield, then again I can see why you'd want people to think that :P
My mum/dad originate from that way.
Thought you were more Leeds than Wakefield, then again I can see why you'd want people to think that :p
Really decent. Unit is lovely. When they realised I did automotive engineering at Uni the owner pulled out a folding chair for me to watch them do it whilst chatting cars to them which I really appreciated. Rather than being shoved in a waiting room :) Also printed out a load more information for me such as the vehicle wheelbase etc etc as they knew I was an engineer and would be interested.
Where abouts are you from?
Halifax now. Parents are from Normanton/Pontefract, but I never lived in Yorkshire until I came here at 18.
Bit of progress, albeit boring progress haha
Finally changed my mirror glass. From my picking up the car it had one of those stick on wing mirror glass as the current one was broken. I had absolutely no idea I could just buy the glass replacements from eBay haha. So changed it... realised that this pic is just showing my crotch haha
15136947946_969586de7d_b.jpg2014-09-04 18.43.23 by dann2707, on Flickr
So annoying how it wasn't even put on at the right angle haha
14973385147_03a7736fc3_b.jpg2014-09-04 18.43.34 by dann2707, on Flickr
Glass popped off and the terminals for the heated elements disconnected.
14973378548_b263fc7623_b.jpg2014-09-04 18.44.28 by dann2707, on Flickr
And the new one on. Not sure why the pic is showing up that distortion on the top right :/ it's clear in real life haha
14973366798_3b1d36f564_b.jpg2014-09-04 18.46.03 by dann2707, on Flickr
Random pic from the garage.
14973361748_6bf056fd28_b.jpg2014-09-04 18.46.22 by dann2707, on Flickr
And finally remapped it with the 98RON map...
15159931945_5bba14b759_b.jpgIMG_20140905_191154 by dann2707, on Flickr
Jesus it's made such a great difference. The car just feels way more eager, you can now blip the throttle for a revmatch downshift and it just revs instantly. Car idles much better and sets off smoother. Seems to pull much faster now. Really am so happy with it :D It won't have made much power if any at all but it's just made the driveability of the car so much nicer.
rstuner? I'm tempted by this. How much you selling the rstuner for? Assuming it's not already sold. They sell really quick on cliosport.
Yeah buddy! can't recommend it enough! I'm selling it now :) £120 posted i'm after for it man. It's the latest one that does "pops and bangs" apparently. The best thing is, you can just sell it on afterwards and the total sum is £75 for the map and license. Let me know if you want it buddy :)
PM sent :)
You'll have to do a trackday and get a video of it all :)
Chris, if you read this, Matty tells me you've been singing my praises about the car today, thank you so much for that I really appreciate the kind words :D Hope you and Matt had a great day.
I've got a lovely and boringish update haha but it's something that's been bugging me for a while.
Completely changed the brake discs and pads all around. The discs were worn a lot and just didn't feel confidence inspiring. This coupled in by the fact that the rear o/s wheel bearing was humming at 35mph+ and the bearing being a part of the disc just made sense to change it all.
This was the front.
15023738550_31d20b9cf6_b.jpgDSCN2617 by dann2707, on Flickr
15023846847_69f333213e_b.jpgDSCN2618 by dann2707, on Flickr
I simply undid the two bolts holding the disc on and hit it gently with a soft mallet and it came off :)
15210426615_63fbc6bf52_b.jpgDSCN2619 by dann2707, on Flickr
New vs old
15023851177_429e457a08_b.jpgDSCN2620 by dann2707, on Flickr
New discs on. I went for Brembo HC's as heard they work really well with the clio set up. Lots of copper grease on the hub to prevent the disc seizing on.
15207373591_4d8185e5aa_b.jpgDSCN2621 by dann2707, on Flickr
And then I changed the pads. I went for Mintex M1144's
15023644549_a54420d613_b.jpgDSCN2622 by dann2707, on Flickr
All on
15210050552_3504ec900a_b.jpgDSCN2624 by dann2707, on Flickr
Then two days later (Today) I changed the rears. Started by jacking Boris up.
15023863217_e3da83f5c5_b.jpgDSCN2625 by dann2707, on Flickr
This was the state of the rears. Quite a large lip on the edge of the discm on both the fronts too actually
15023865547_6c4c1ed8e1_b.jpgDSCN2626 by dann2707, on Flickr
17mm nut on the rear of the carrier and it simply comes off allowing changing of the pads. I then undid the 30mm hub nut.
15210057832_f4a8974b2d_b.jpgDSCN2627 by dann2707, on Flickr
All off.
15210061832_c34110862d_b.jpgDSCN2628 by dann2707, on Flickr
15023768800_6df70f79d6_b.jpgDSCN2629 by dann2707, on Flickr
This is the washer that i'd heard so much about, people not re-fitting them back to the new hubs/discs after changing and it giving massive problems afterwards. I made a note of which side up it was when removing.
15023665489_ab61db9745_b.jpgDSCN2630 by dann2707, on Flickr
New stuff.
15023667859_a62110c5c9_b.jpgDSCN2631 by dann2707, on Flickr
15210458525_9d487d7958_b.jpgDSCN2632 by dann2707, on Flickr
Made a right mess of my carriers from all the grease. Need to clean them down when I get the time.
15023884288_355e210797_b.jpgDSCN2633 by dann2707, on Flickr
And finally all on.
15023736230_729b5de444_b.jpgDSCN2634 by dann2707, on Flickr
15207358661_b38930db89_b.jpgDSCN2635 by dann2707, on Flickr
Great work as usual Dan
Your thread and skills are a great addition to this Forum
Well done!!
So when am I polishing it? ;)  B)
And I thought the Celica's rear setup was weird with its disc/drum combo. Crazy Renaults.
Update time.
This arrived, so happy with it, made a massive difference in my opinion. It's a c2 stubby aerial.
Before:
After:
I'm getting a wandering feel when driving at speed, accelerating etc pulling left and right so im trying to find the root of the issue! New shiny parts always makes me happy :D
15260898645_c4e877a8b2_b.jpgDSCN2636 by dann2707, on Flickr
Got the old ones off
15257797751_e726893057_b.jpgDSCN2637 by dann2707, on Flickr
I haven't driven it yet but i'm hoping it's solved the problem :)
I had crazy pulling to the right when under WOT. Replacing the ball joints sorted it :)
Looking good. You don't see many of these around
Sent from my Galaxy S5
Nice one dude, that fills me with confidence. Did they have much play when you removed them?
How are you getting on with the RS tuner?
Thanks buddy!
