Daniels Blue 182
Soooooo today was ****ing awesome! Did my first track day in the Clio (organised by the trials biking forum so it was a closed event to just 12 or so of us)
Absolutely loved it so much and there will be loads of pics later on but for now I had some footage from inside the car. I felt like the car was really decent on track and i'm loving the coilovers so much. They're pretty soft but felt like they handled the abuse really well.
I definitely need more tuition but I wasn't there to set record times, just there for fun and it was exactly that. The main things I had trouble with was wheel spinning out of corners and I imagine that's why people say LSD's make such a difference on track. I just found it hard to be smooth with the throttle and ended up losing quite a bit of time there, along with where to brake but I guess that will all come with time. I felt myself progress through the day which is sweeeeeeeeeet.
Here are some clips, the first two clips are the first clips of the day if you look at the time stamp in the corner at the bottom left of the screen. Then it jumps to around 3.15pm where hopefully you might be able to notice some progression :)
  • Replies 282
  • Views 28.8k
  • Got my wheels back from the powder coaters, £90 all in at Cas coatings in bradford
  • Well today I bit the bullet. It was already half getting there so decided to just go for it.   It's mad how much this weighs and adds up!   20160710_134952 by dann2707, on Flickr   20160710_14
  • Thanks mate. All lacquered!   Really pleased with them for a rattle can job. I don't expect them to last forever / be super durable but they've got to be better than this...     DSCN2074 by dann270
Some preliminary pics so far. Thanks to Mike on the forum for these!!
1604667_10155241092930587_68957701936518
11045383_10155241093085587_4233153154958
Me pointing out something I have no idea, random shoes at the back also haha
10443390_10155241094745587_4679847272754
11054458_10155241095290587_1986198982309
10407904_10155241097360587_9126734901720
10403217_10155241098525587_1146426954940
11043118_10155241098630587_4854773907673
These were the final times when we started doing the timed laps
Such an awesome array of cars, 1.6 MX5's, 225 seat leon turbos, saab turbos, mr2's
Quite happy with that time for the first day on track :D
Looks like a good day budd.
How'd you rate the handling of the car? I read the clios are incredible for handling round a track?
Any more action shots including other cars?
Hey man
Yeah I absolutely loved it, the car handled so well to say the coilovers its on are really quite soft in comparison to other coilys. It is literally point and shoot! I experienced slight understeer but that was when really hammering it. Overall I was so impressed with the car though as it performed flawlessly over 70 miles on track!! :p
The two fastest cars that went around the track happened to be the only two clios there so that probably says what they're like and that's against a 300bhp golf gti, 225 golf leons etc
I'll post a few more pics.
10401611_10152944073997935_5160070963699
11046673_10152944072362935_6243206919237
10930112_10152944072197935_5573297425046
10997993_10152944072152935_8112359505050
10168198_10152944072042935_1375072389467
11052496_10152944071947935_4849548525739
11021264_10152944071957935_8195114572452
11024692_10152944071697935_9017340031060
11037331_10152945744127935_4290253549579
I need to write down a few niggles that are annoying me so that if I keep seeing them i'll get them sorted. They're only small things but they've been building up and I don't want to just let stuff pass me by. So -
  • The exhaust is blowing at the cat to cat back section which needs to be sleeved. I need to go out and measure the diameters of the pipe so I can order some tubing to be welded to the cat back and cat.
  • Need to raise the left exhaust a bit but it's proving difficult with the mounts. Not sure how to fix.
  • The ABS sensor fault is still there (car over revving when coming to a stop, juddery set off). I am going to try and move the target further away from the driveshaft as when fitting the new one I might have put it too far on so that the sensor isn't picking it up properly.
  • The cruise control function isn't operating correctly however the speed limiting function is working absolutely great, implicating that my wiring on the steering wheel is spot on. Everything works as it should however the cruise control just simply doesn't activate. I wonder if it's related to the above fault as the vehicle speed isn't available = cruise won't activate.
  • Need to change gearbox oil as I changed it ages ago but not with the correct stuff
  • Fit the correct locking nut to the top of the topmounts. Currently using a random massive one and it looks stupid
  • Tabs have broken off on the gearstick gaitor so going to be ordering a second hand one asap.
On the plus side i've just bought a whiteline antiroll bar which will be here sometime next week :)
They're all really small things that just need sorting asap really.
Use a cable tie to try and pull up one side of the backbox. Worth a shot.
I used the power flex universal exhaust mount. Just cut down to size.
The cat the back section is a pain. I'm going to try the silicone sealant locate stuff next.
I've done a few things, thank god :D
I fitted new black powerflex steering rack bushes the other day. It was a bit of a fiddly job but nothing my gay little piano fingers couldn't sort haha. Amazing guide on here for it too which really helped so thank you for that whoever did it :) My old bushes weren't too bad at all but it's nice knowing they're harder now.
16634632389_5212bea026_b.jpg20150311_140826 by dann2707, on Flickr
16794884096_575c7b1844_b.jpg20150311_140829 by dann2707, on Flickr
I then received a whiteline ARB however the L bracket seen here that connect the arb to the shock weren't present as the seller couldn't find them. No worries though
Went for a drive to wickes and B and Q and they didn't have any decent angle iron that I could use! All so short. Took a blurry as tits photo though
16819687291_30141ab176_b.jpg20150314_135936 by dann2707, on Flickr
I then went to my local automotive shop up the road this place is an absolute godsend @bashracing will no doubt agree!! I found this from towing a caravan or something? No idea
16198430574_377be88672_b.jpg20150314_143026 by dann2707, on Flickr
I then marked where I needed to cut thanks to @1812lsd giving me a drawing from his brackets :) And all done, not the neatest job in the world but jesus it's stiff!!
16820778565_6b9e7dca28_b.jpg20150314_153718 by dann2707, on Flickr
Then reversed the car up.
16794928446_9666ca17d9_b.jpg20150314_155558 by dann2707, on Flickr
Fitted perfectly :D
16819727241_7f682d26eb_b.jpg20150314_160453 by dann2707, on Flickr
16198461464_650d614074_b.jpg20150314_163259 by dann2707, on Flickr
16613510377_50b7519c2d_b.jpg20150314_164318 by dann2707, on Flickr
16633426190_fa38d6bb4b_b.jpg20150314_164322 by dann2707, on Flickr
16819747131_c85d0f76d5_b.jpg20150314_164332 by dann2707, on Flickr
Have I overtightned these bushes? They're not deformed or anything? @debussetti
Then started to de-wiper
Not sure if I like it, but I kind of do. I'm not really sure.
Edited by Dann2707
Put the rear wiper back on lol
Personally, I like the rear wiper on mate. I also love having a rear wiper on the fabia, don't know what I'd do without it! Lol
Regardless of personal preference, it's a lovely looking car, you've done a cracking job with it.
sent from my Galaxy Note 4
looks great mate .. i had one of these a while back .. really nippy cars but i couldn't get it over 25 mpg haha every time i tried i just thought bugger it il overake him and him and him ect haha  1236445_10201695720265348_86338230_n.jpg
Cheers mate but going to give it a miss, think i'd like to do an open pit lane one next time!!
Changed my gearbox mount today but first...
We went clay pigeon shooting today which i've never done before :D It was bloody awesome, even had my jumper off and nearly got a tan:
16986147636_95cb693256_b.jpgIMG_0279 by dann2707, on Flickr
Matty with something bulging in his pocket and i'm fairly certain that isn't his wallet:
16824685170_f1e2d97c7e_b.jpgIMG_0281 by dann2707, on Flickr
So we started with the mount. Checked out the original and it looked like something been rubbing through it :S :S
16825955539_b7a3a53f27_b.jpgIMG_0255 by dann2707, on Flickr
16804766467_ed870799b0_b.jpgIMG_0256 by dann2707, on Flickr
Got it all off
17011273531_878d205570_b.jpgIMG_0257 by dann2707, on Flickr
17010726302_08747567b3_b.jpgIMG_0259 by dann2707, on Flickr
17011264991_c2f2f16885_b.jpgIMG_0260 by dann2707, on Flickr
17012139245_5480f30c9e_b.jpgIMG_0261 by dann2707, on Flickr
That was literally all the pics I took as we were just cracking on with it hahah! A video of me being annoying was captured though
Then a random pic from my friends house in Manchester as I liked the contrast!
16986194026_9cfcb8103d_b.jpgIMG_0144 by dann2707, on Flickr
I also got a parking ticket the other day :( But took some pics as thought it might be contest worthy but apparently not but at least you can see how the car's looking atm hahah always smiling :D
16826079669_c53e33b203_b.jpgIMG_0228 by dann2707, on Flickr
16804885587_fcfd8f222d_b.jpgIMG_0230 by dann2707, on Flickr
16824523678_129f1d526c_b.jpgIMG_0231 by dann2707, on Flickr
16392148673_ff88b88d7e_b.jpgIMG_0233 by dann2707, on Flickr
I changed the other mount today. Jeeeeeesus that was incredibly easy compared to yesterday haha, literally 8 bolts!
I haven't had chance to fully spank it and test it but so far so good, no horrible noises and the engine doesn't move AT all now which is ace :D
Old!
16813878337_9876b80bd8_b.jpgIMG_0321 by dann2707, on Flickr
We love an action shot haha
16835063879_2ffd9d508f_b.jpgIMG_0322 by dann2707, on Flickr
16398850604_36d4291e89_b.jpgIMG_0323 by dann2707, on Flickr
mmmm rusty
16401122863_49ef9ba393_b.jpgIMG_0324 by dann2707, on Flickr
And the gaping hope hehe! I found a nut in there so today was a good day :)
16401119003_7ef5809fd0_b.jpgIMG_0325 by dann2707, on Flickr
  • 4 weeks later...
Decided to bite the bullet and go for a spin to buttertubs. Took a few pics (SO many pics of the same position from different angles oops hahaha)
Filled up with only the best from Shell
17276639522_e76f2f77f4_b.jpgIMAG0010 by dann2707, on Flickr
This was on the way, but I stopped in this layby thing as I really wanted a babybel
17277934291_ec913a462f_b.jpgIMAG0014 by dann2707, on Flickr
Then onto the actual pass
17090648928_e1e18de382_b.jpgIMAG0016 by dann2707, on Flickr
Some fantastic scenery to take in :)
17092214159_6f611820a0_b.jpgIMAG0017 by dann2707, on Flickr
17070980967_3cd862fef9_b.jpgIMAG0018 by dann2707, on Flickr
17277903291_ed51435ace_b.jpgIMAG0019 by dann2707, on Flickr
Pulled in for some pics
17276596302_526cb25829_b.jpgIMAG0020 by dann2707, on Flickr
16655936834_c1839b88ca_b.jpgIMAG0021 by dann2707, on Flickr
17277880881_bcdb0c5d1a_b.jpgIMAG0023 by dann2707, on Flickr
17278368545_75216365f0_b.jpgIMAG0027 by dann2707, on Flickr
17090830940_69edf6d40f_b.jpgIMAG0031 by dann2707, on Flickr
17277858921_289a7c979f_b.jpgIMAG0033 by dann2707, on Flickr
One of my fav pics
17090580088_e1554377f3_b.jpgIMAG0034 by dann2707, on Flickr
16658111533_6bca74ac17_b.jpgIMAG0037 by dann2707, on Flickr
17278333355_59d5f7aeec_b.jpgIMAG0041 by dann2707, on Flickr
Size difference between my car and the other hahaha
17070903347_3133c7748c_b.jpgIMAG0042 by dann2707, on Flickr
17252354246_87d79c7bb1_b.jpgIMAG0043 by dann2707, on Flickr
17276514682_2bdf598a6a_b.jpgIMAG0048 by dann2707, on Flickr
17252336376_e760be1c39_b.jpgIMAG0049 by dann2707, on Flickr
My passenger is so helpful at taking pics :D :D :D  cheers dave
17252316446_1b935295b0_b.jpgIMAG0055 by dann2707, on Flickr
17090511788_68ae60f6df_b.jpgIMAG0056 by dann2707, on Flickr
17090740410_e3a9a2d317_b.jpgIMAG0057 by dann2707, on Flickr
17278260985_c7ce0378c5_b.jpgIMAG0058 by dann2707, on Flickr
Beware of random sheep that eat stuff from the road
17277745881_1b0d0d476d_b.jpgIMAG0063 by dann2707, on Flickr
Then they just strut off not giving a **** hahaha
16658007883_a8bfb27bb1_b.jpgIMAG0064 by dann2707, on Flickr
17252266326_a8fcffabc0_b.jpgIMAG0070 by dann2707, on Flickr
My impressions are: The road is decent don't get me wrong but i'd be disappointed coming from any further away. It's fun but I much preferred the B roads getting there! I think it's the whole, massive summit that kinda puts me off. But other than that I loved it and glad it's finally off the bucket list :D
My headlamps have always annoyed me, mainly because one of them won't adjust and the other adjuster has always been broken so one headlight has always pointed down and the other pointing up so i've never really had the true "xenon experience" so I thought i'd look out for some 172 headlights as I love the black inserts [uSER=57717]@incy-spider[/uSER] knows my feels
This is what they turned up like. SO FADEDDDDDDDDDDDDDD
17273165870_e186b48e56_b.jpgIMAG0090 by dann2707, on Flickr
So I sanded them back. I'm going to do the thing that EVERYONE does on here, if you look at some other threads where people have restored their headlights they always say something along the lines of "They're not perfect, but they're much better than before" hahah exactly the same this time
Anyway this was before, grey insert doesn't really go too well I think
After!
16837960534_d9a6c0d51c_b.jpgIMAG0100 by dann2707, on Flickr
Car is filthy atm btw, always collects at the bottom of the splitter
17460535675_7496700be1_b.jpgIMAG0098 by dann2707, on Flickr
16838048474_e6fc9c00ce_b.jpgIMAG0096 by dann2707, on Flickr
17272929478_af68e2ff78_b.jpgIMAG0093 by dann2707, on Flickr
I've just been to tescos just now and thought i'd go in the underground car park for some cliché shots
17276852330_c2b5fc5313_b.jpgIMAG0115 by dann2707, on Flickr
17276678028_6462b3d2c9_b.jpgIMAG0114 by dann2707, on Flickr
16841943364_5968f438dd_b.jpgIMAG0112 by dann2707, on Flickr
17464540535_4e30ff8500_b.jpgIMAG0110 by dann2707, on Flickr
16842004144_0829b5df96_b.jpgIMAG0109 by dann2707, on Flickr
17464272491_34e4c38774_b.jpgIMAG0105 by dann2707, on Flickr
17464297291_b5460b680c_b.jpgIMAG0104 by dann2707, on Flickr
17462615882_36626734c7_b.jpgIMAG0103 by dann2707, on Flickr
Also, on the way home I thought i'd take a detour on some decent back roads. I've done a few other things today but jesus the car feels WAY more responsive.
I added a lot more oil as it was getting low and cleaned the TDC sensor.
The car makes me smile SO MUCH haha just the way it handles it's amazing and so fun, I know I say it a lot on here but I think it's easy to just splooge loads of pics of the car on a website but not actually say about the car and how it's driving. Loving it!
Today I gave the car some TLCCCCCCCCCCCCCC!
After changing the gearbox oil a few weeks ago, it started to leak. Well it has always leaked throughout my ownership from the gearbox selector seal. So I bought a kit from @mgd which arrived stupidly quickly, cheers again man.
17734989682_658d164143_b.jpgIMAG0134 by dann2707, on Flickr
I then started fitting it today, it wasn't a pain really. I expected it to be much worse but after watching the youtube video guide it made things really clear. The main bit I struggled with was fitting the new seal and o-rings. As it's a split design it doesn't evenly go into the gearbox, you really have to make sure you're putting equal pressure on it whilst pushing it on. It's a ****ing tight fit when it goes in and I was a little worried I was going to snap it and be left without both seals. All sorted though in the end :D
Just a pic to show the seal you're replacing, you have to cut that ****er off and when I say ****er I genuinely mean an absolute ******. It's not just plastic it's metal too
17549989150_cabb838e28_b.jpgIMAG0138 by dann2707, on Flickr
This is it dropped down ready to be cut
17115034124_2bc448c4d3_b.jpgIMAG0139 by dann2707, on Flickr
All on and cleaned
17117163623_19eb6f36c1_b.jpgIMAG0137 by dann2707, on Flickr
I then repalced the gearbox oil and engine oil and filter. I also fitted a ramair panel filter the other day as my standard filter was a state. This was only £20 on eBay. Not sure if it's made any difference but it's good to know that the car has been fully serviced now.
17735009242_222e7c527c_b.jpgIMAG0133 by dann2707, on Flickr
Random wheely shot
17117234673_10908de311_b.jpgIMAG0136 by dann2707, on Flickr
I also tightened my topmounts up or attempted to (PMS solid mounts, still loose though :(, think the bearing has gone in them both maybe??) and I slipped with the spanner. I've put a horrible scratch in my wing :( Really really annoyed at myself for that.
WANT 15" WHEELS
RANDOM SHOUTING
:P
I received some wheels (team dynamic 1.2s in 15") and I think i'm in love. Obviously the colour isn't staying but I had to test fit them to see how they're going to fit and I think they look sooooooooo much better, especially as the rears are wider and stick out a bit more. Will be lowering the car more to suit when they're refurbed but here are some pics for now.
Please excuse our green bin. Really need to get rid of that disgusting overspray
17843265633_560c00d429_b.jpgIMAG0208 by dann2707, on Flickr
18465451271_910edd55e7_b.jpgIMAG0209 by dann2707, on Flickr
18275934950_9954fe4e09_b.jpgIMAG0210 by dann2707, on Flickr
18463577615_73e6a2e040_b.jpgIMAG0212 by dann2707, on Flickr
17842878193_07012a11bc_b.jpgIMAG0213 by dann2707, on Flickr
Stick out a lot more at the rear :smiley: I didn't fit the left side
17840891184_aeed081d43_b.jpgIMAG0214 by dann2707, on Flickr
18277293719_2f5f5d9009_b.jpgIMAG0215 by dann2707, on Flickr
Before
17842794893_ddc5cfc0f1_b.jpgIMAG0217 by dann2707, on Flickr
After
18463475475_fb550d78fc_b.jpgIMAG0216 by dann2707, on Flickr
Edited by Dann2707
Im so glad youre ditching the blue on the wheels Dan... :clap:  :sun:
looking good
looking good
Is it not good stuff? Totally clueless when it comes to oil I won't lie!
How can you see my post i edited it. Well after i posted i googled it and it appeared to be more expensive than i thought it was.
Its just not a brand i have heard of before. Which doesn't really mean its bad
I would have stuck some castrol edge / mobil 1 esp / fuchs titan something branded like that. Especially as you use vpower in it and its obviously a car made for driving hard
Or some ELF stuff I'd be tempted to throw in,
